X-Files Blu-Ray Season 3 - Twin episodes on each disc?
bottleneck70
Post by bottleneck70 » Sat Feb 27, 2016 6:36 pm
Hello Everyone,
I was ripping the new X-Files season 3 on Blu-ray and it appears there are the same episodes twice on each disc. Can anyone confirm or tell me which ones are the correct ones?
Order:
s03e01
s03e02
s03e03
s03e04
s03e01
s03e02
s03e03
s03e04
taseldor
Re: X-Files Blu-Ray Season 3 - Twin episodes on each disc?
Post by taseldor » Sat Feb 27, 2016 9:14 pm
They're all correct. For some reason some seasons of some shows have duplicate episodes, some with the western language/subtitle options and another with the Japanese subtitle options. Not sure why that is. You probably want the ones that don't have the Japanese subs -- probably the first batch, not the second.
bottleneck70
Post by bottleneck70 » Sat Feb 27, 2016 10:55 pm
Thanks for the pointer.
matt198t
Post by matt198t » Sat Feb 27, 2016 11:46 pm
taseldor wrote:They're all correct. For some reason some seasons of some shows have duplicate episodes, some with the western language/subtitle options and another with the Japanese subtitle options. Not sure why that is. You probably want the ones that don't have the Japanese subs -- probably the first batch, not the second.
I've seen it with films as well.
Both are completely identical but they are separated in MakeMkv as you say one with English + multiple western subs the other with English + Japanese subs only.
I am yet to discover the difference.
MrVideo
Post by MrVideo » Sun Feb 28, 2016 10:15 am
bottleneck70 wrote:I was ripping the new X-Files season 3 on Blu-ray and it appears there are the same episodes twice on each disc. Can anyone confirm or tell me which ones are the correct ones?
Order:
s03e01
s03e02
s03e03
s03e04
s03e01
s03e02
s03e03
s03e04
I downloaded S3-D1 in order to look at what was going on. First off, no disc ever has more than one of anything. That would be a total waste of space. The differences are handled, for the most part, by playlists.
The four episodes are M2TS files: 2436, 2437, 2362 and 2363 I do not know the order.
The following play lists handle the M2TS files:
500 800 801 850 851 - 2436
501 802 803 852 853 - 2437
502 804 805 854 855 - 2362
503 806 807 856 857 - 2363
I have no clue as to why there are 5 play lists for each episode. Each of the episodes have all of the languages and subtitles.
I have a WAG. It is possible the playlists are for different country releases, whereby only certain languages, and/or subtitles, are enabled to be selected. The differences would be handled by a different menu for the particluar release, which would call the appropriate play list. Like I said, a WAG.
Info gleamed by using the BDEdit program.
