Chinatown
Oreski1
Chinatown
#1 Post by Oreski1 » Fri Feb 26, 2016 10:37 am
MakeMKV v1.9.9 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Spock/MakeMKV_log_1.txt
File 00800.mpls was added as title #0
Title #00020.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00250.mpls was added as title #1
File 00250.m2ts was added as title #2
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01012.m2ts was added as title #3
File 01013.m2ts was added as title #4
File 01014.m2ts was added as title #5
File 01015.m2ts was added as title #6
File 01016.m2ts was added as title #7
File 01021.m2ts was added as title #8
File 01022.m2ts was added as title #9
Title #00022.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Chinatown
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '144635904'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '144635904'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '144637952'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '144642048'
DEBUG: Code 3221225628 at m\<}c9ZOfCO[p%-X"m:121262969
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '144642048'
DEBUG: Code 100864261 at m\<}c9ZOfCO[p%-X"m:121262969
DEBUG: Code 0 at ^sn-7'9lk#*zI%}tr!g-:121263291
DEBUG: Code 0 at n7~l+lH59WZ+0;g$ai?L:121262302
DEBUG: Code 0 at ^sn-7'9lk#*zI%}tr!g-:213130812
DEBUG: Code 70626 at ^sn-7'9lk#*zI%}tr!g-:29393286
DEBUG: Code 0 at 4W~5;,qVF!rkp['%ZSgF\:29398967
Failed to save title 0 to file C:/Video/Chinatown/Chinatown_t00.mkv
0 titles saved, 1 failed
Re: Chinatown
#2 Post by Woodstock » Fri Feb 26, 2016 2:43 pm
Your drive is having a problem reading part of the disk. First thing to try is to clean the disk and inspect it for scratches.
