External Blu Ray Drive dosnt work with Make MKV
Hi Guys,
My External BD Drive LGBP40NS20 dosnt run with make MKV right now. Bevore (since 2 Years i have no Problem with Make MKV). They dont open de Blu Ray Disc, it runs Hours with no Option to Open it.
On Another Forum, i bekome the suggestion that i will create a new user Account to Test.
On the new User the Drive works Perfekt, with an Windows Laptop it Works Perfekt to.
Can you help me guys?
Log File:
Fehler 'Betriebssystemfehler - (ipc/send) invalid destination port' trat auf während des Auslesens von 'BD-RE HL-DT-ST BD-RE BP40NS20 ML04' bei Offset '2242560'
Fehler 'Betriebssystemfehler - (ipc/send) invalid destination port' trat auf während des Auslesens von '/AACS/MKB_RO.inf' bei Offset '0'
Fehler 'Betriebssystemfehler - (ipc/send) invalid destination port' trat auf während des Auslesens von '/BDSVM/00000.svm' bei Offset '0'
Fehler 'Betriebssystemfehler - (ipc/send) invalid destination port' trat auf während des Auslesens von '/AACS/Content000.cer' bei Offset '0'
Das Öffnen der Disk schlug fehl
Log File:
Re: External Blu Ray Drive dosnt work with Make MKV
Hello, Lights on, nobody home ), I've had this happen on drives when I needed to connect external power to them.
link to your drive, quick glance through,,,I missed anything about an external power supply.
oops
http://www.lg.com/us/burners-drives/lg- ... -dvd-drive
GL Sir
oops
GL Sir
The Drive uses 2 USB Ports to Power. And it Works well on Imac and Windows Laptop. But not with MY USER Account. With an Test Account on the same Imac it runs perfectly
NShameA wrote:Hello, Lights on, nobody home ), I've had this happen on drives when I needed to connect external power to them.
oops
GL Sir
That is a weird error situation. Definitely points to a permissions issue, but those should not change without intervention. Did you recently have to change your account permissions for something else?razor187 wrote:The Drive uses 2 USB Ports to Power. And it Works well on Imac and Windows Laptop. But not with MY USER Account. With an Test Account on the same Imac it runs perfectly
Woodstock wrote:That is a weird error situation. Definitely points to a permissions issue, but those should not change without intervention. Did you recently have to change your account permissions for something else?razor187 wrote:The Drive uses 2 USB Ports to Power. And it Works well on Imac and Windows Laptop. But not with MY USER Account. With an Test Account on the same Imac it runs perfectly
No it Makes Problems since el Capitan on my Account. Yesterday an User give me the tip, to Create new user to test. And it Works. And it Works on an Windows Laptop to.
I dont know whot i can do, to run this drive on my Account or whot is Wrong:(
Guys i Have the Problem Analysed. The APP Duet Display Makes the Problem. Is the APP Shuting Down, it Works Fine
Razor, you're fantastic! The app Duet Display was making my external drive totally unusable too. Quitting the app and restarting worked perfectly! I've been pulling my hair out trying to figure out what changed, and why I was no longer able to read discs.
Thank you!
Thank you!
My blu-ray drive doesn't work either! I purchased it b/c my DVD drive worked 100% fine.
If I open MakeMKV w/ the drive plugged in I get this error message: DEBUG: Code 0 at F>JXwv%D4 T>O,/t:213139736
I get no error code without the drive plugged in. Any suggestions?
