The three musketeers failed backup
Pubaer
#1 Post by Pubaer » Tue Feb 23, 2016 10:54 pm
Hello world, hello forum,
I copy some of my DVD on Harddisk which is connected with WD-MediaPlayer to my Musicreeiver and Television, cause I want to save my disks in secure place.
Now I have tried some Blurays with makemkv. Most went well. So far so good.
Now I wanted to put my new bought BD The three musketeers to my HDD. It is a 3d-BD but plays also a 2D-Track. But ... I could not transfer it to HDD, not the film, not the whole BD.
My system:
Win 7, 64 bit, all updates etc installed
Bluray-Burner from LG, Type BH16NS40
MakeMKV v1.9.9 (for win 64 bit)
MakeMKV is showing the following info for my system:
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BH16NS40
Revision: 1.03
Serienummer: ....
Firmware-Datum: 2114-03-26 11:15:
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 53
Disk-Informationen
Label: DIE DREI MUSKETIERE
Zeitstempel: 2011-12-22 19:36:35
Datenkapazität: 42.94 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
MakeMKV v1.9.9 win(x64-release) gestartet
It starts Disk-Backup, Transfer-Rate around 7 M / 1,6x. But after short time, first errors happen and then the process is stopped.
There are about 84 files, 81 are copied before stopping, 00000.m2ts, 00001.m2ts and 00050.m2ts missing , no film, not 2D nor 3D.
makemkv shows in the "work-dialog"
Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als C:\Users\Main/MakeMKV_log.txt
Disk in Ordner kopieren "G:/Musketiere"
Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
Hash-Check von Datei /BDMV/STREAM/00009.m2ts an Offset 135653376 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00009.m2ts an Offset 135849984 fehlgeschlagen, Datei ist korrupt.
Hash-Check für /BDMV/STREAM/00009.m2ts: 0.24% korrupt, 99.67% korrekt, 99.91% überprüft.
Hash-Check von Datei /BDMV/STREAM/00011.m2ts an Offset 10020864 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00011.m2ts an Offset 10217472 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00011.m2ts an Offset 10414080 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00011.m2ts an Offset 10610688 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00011.m2ts an Offset 10807296 fehlgeschlagen, Datei ist korrupt.
Zu viele Hash-Checks bei Datei /BDMV/STREAM/00011.m2ts fehlgeschlagen.
Hash-Check für /BDMV/STREAM/00011.m2ts: 3.67% korrupt, 96.22% korrekt, 99.90% überprüft.
Hash-Check von Datei /BDMV/STREAM/00013.m2ts an Offset 41084928 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00013.m2ts an Offset 42067968 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00013.m2ts an Offset 42264576 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00013.m2ts an Offset 42657792 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00013.m2ts an Offset 42854400 fehlgeschlagen, Datei ist korrupt.
Zu viele Hash-Checks bei Datei /BDMV/STREAM/00013.m2ts fehlgeschlagen.
Hash-Check für /BDMV/STREAM/00013.m2ts: 1.56% korrupt, 98.41% korrekt, 99.98% überprüft.
Hash-Check von Datei /BDMV/STREAM/00043.m2ts an Offset 86894592 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00043.m2ts an Offset 87091200 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00043.m2ts an Offset 87287808 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00043.m2ts an Offset 87484416 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00043.m2ts an Offset 87681024 fehlgeschlagen, Datei ist korrupt.
Zu viele Hash-Checks bei Datei /BDMV/STREAM/00043.m2ts fehlgeschlagen.
Hash-Check für /BDMV/STREAM/00043.m2ts: 7.25% korrupt, 92.62% korrekt, 99.88% überprüft.
Hash-Check von Datei /BDMV/STREAM/00042.m2ts an Offset 172025856 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00042.m2ts an Offset 172222464 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00042.m2ts an Offset 172419072 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00042.m2ts an Offset 172812288 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00042.m2ts an Offset 173008896 fehlgeschlagen, Datei ist korrupt.
Zu viele Hash-Checks bei Datei /BDMV/STREAM/00042.m2ts fehlgeschlagen.
Hash-Check für /BDMV/STREAM/00042.m2ts: 7.08% korrupt, 92.82% korrekt, 99.91% überprüft.
Hash-Check von Datei /BDMV/STREAM/00010.m2ts an Offset 18475008 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00010.m2ts an Offset 18671616 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00010.m2ts an Offset 18868224 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00010.m2ts an Offset 19064832 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00010.m2ts an Offset 19261440 fehlgeschlagen, Datei ist korrupt.
Zu viele Hash-Checks bei Datei /BDMV/STREAM/00010.m2ts fehlgeschlagen.
Hash-Check für /BDMV/STREAM/00010.m2ts: 2.76% korrupt, 97.22% korrekt, 99.99% überprüft.
Hash-Check von Datei /BDMV/STREAM/00012.m2ts an Offset 91023360 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00012.m2ts an Offset 91219968 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00012.m2ts an Offset 93186048 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00012.m2ts an Offset 93382656 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei /BDMV/STREAM/00012.m2ts an Offset 93579264 fehlgeschlagen, Datei ist korrupt.
Zu viele Hash-Checks bei Datei /BDMV/STREAM/00012.m2ts fehlgeschlagen.
Hash-Check für /BDMV/STREAM/00012.m2ts: 1.74% korrupt, 98.23% korrekt, 99.97% überprüft.
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00050.m2ts' bei Offset '1665202176'
DEBUG: Code 0 at %]R6R1"mIi]'{~$?TvJ:121266120
DEBUG: Code 0 at \02lvOVlNMf<!.ZVXY@1:121265108
Backup fehlgeschlagen
Well, can anyone help me?
Many thanks
pubaer
(Fritz)
