Hello, Using win7, Pioneer is on 800 FW in BYTECC case and Matshita is internal, paid version of MakeMKV...currently v1.9.9 64bit, disc player info below. I want to understand what I need to do to be able to "use" higher versions of AACS. Is that what "Highest AACS version" means.....able to be "used" by the system or MakeMKV ? Thank You much.
Primary:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.20
Serial number:
Firmware details: intf=SAT gen=8600 krnl=ID60 main=ID60 ver=0000
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 46
Secondary:
OS device name: E:
Manufacturer: MATSHITA
Product: BD-MLT UJ267AM
Revision: 1000
Serial number:
Why is the version of AACS my disc players can use v46 only?
NShameA
Re: Why is the version of AACS my disc players can use v46 o
The "Highest AACS" is the most recent version the drive has seen, not the limit on what it can read. If you put a disk in that has AACS v56, that will change to 56.
/svq/ has more information with some links.
