0 titles saved, 1 failed error - help please!
RBHLondon
Post by RBHLondon »
I am new to MakeMKV and am currently trialing the software.
My ultimate goal is to create a reasonably high quality MP4 (which may be 5GB-ish) from a Blu Ray disc. I understand the best way to do this is to first create a MKV (which may be as large as 30GB-ish) via this software and then to use something like Handbrake to convert the MKV to MP4.
However, I am problem with the first step. I have taken a reasonably straight forward Blu Ray disc and get the following error. I've tried to attach a screenshot of the MakeMKV screen but get "Sorry, the board attachment quota has been reached."
Could you kindly recommend what I should do?
MakeMKV v1.9.9 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HE13d" opened in OS access mode.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS02d" opened in OS access mode.
Evaluation version, 19 day(s) out of 30 remaining
File 00004.mpls was added as title #0
Saving 1 titles into directory /Users/Robin/Movies/BRIDESMAIDS_SCREENER
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16625958912'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16625958912'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16626216960'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16626806784'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16626806784'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16626812928'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16628183040'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16628183040'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16628187136'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16628772864'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16628772864'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16628776960'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16630216704'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16630216704'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16630222848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16631070720'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16631070720'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16631592960'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16631592960'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16631595008'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16631857152'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16631918592'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16631918592'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16631922688'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '16632446976'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '16632446976'
Failed to save title 0 to file /Users/Robin/Movies/BRIDESMAIDS_SCREENER/title00.mkv
Re: 0 titles saved, 1 failed error - help please!
When I see this error string, my first thought is that the drive is going off line for some reason. It CAN come from a bad disk, or at least a dirty one. However, the rip continued a bit further after that the first error (the drive came back on line), some more reading occurred, then it went off line again. That repeated until the retry limit was reached.
Is the drive doing the ripping an external drive? If it is, is it powered by the USB bus, or does it have its own power supply?
RBHLondon
Post by RBHLondon »
Hi, thanks so much for coming back to me. :)
The drive I am using is an external drive. It is a Samsung and got good reviews on Amazon. This is the first time I am trying to rip Blu Ray DVDs. I have tried four DVDs and have been successful with 2 of the 4.
The second DVD that failed is giving me the below (I've tried it twice on two different large titles) ...
Title #00009.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00007.mpls was added as title #0
Title #00008.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00092.mpls was added as title #1
File 00092.mpls(1) was added as title #2
File 00100.mpls was added as title #3
Title 00091.mpls is equal to title 00100.mpls and was skipped
Title 00091.mpls(1) is equal to title 00092.mpls(1) and was skipped
Title 00101.mpls is equal to title 00092.mpls and was skipped
Title #00000.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00459.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00455.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00458.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00457.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00456.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/MASTER 3/MKV files to convert to MP4
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '26826700800'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26826700800'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26826702848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '26827290624'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26827290624'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26827292672'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '26827880448'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26827880448'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26827882496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '26829127680'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26829127680'
Failed to save title 1 to file /Volumes/MASTER 3/MKV files to convert to MP4/The_Dark_Knight_Rises_t01.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '26827616256'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '26828206080'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26828206080'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '26828210176'
Failed to save title 3 to file /Volumes/MASTER 3/MKV files to convert to MP4/The_Dark_Knight_Rises_t03.mkv
A quick google search for the drive shows that others have had issues with the SE-506CB on Macs if it wasn't plugged into a powered USB port. The first hit, in fact, said that because the supplied cord was so short, the drive was plugged into a hub, and failed burning disks, but worked fine after being plugged into the ports on the back of the iMac.
This isn't a new problem. USB power (especially 2.0) is limited on port, and using hubs limits it even more, unless the hub has its own power supply. Generally speaking, you want the drive plugged in as close to the power source as possible, which is the computer itself, and some older drives really need to be plugged into TWO USB ports for full speed operation.
The drives will generally work just fine at low speeds like playing back movies, but MakeMKV has no speed limiter right now...
RBHLondon
Post by RBHLondon »
Thanks so much for your reply. It is great to know about the USB drive. However, I think in this case that it is because of the DVDs themselves? I've now been successful in burning four Blu Ray DVDs and not successful in two. I'll try more!
