Mission Impossible Rouge Nation won't rip
FateSlicer815
#1 Post by FateSlicer815 » Fri Feb 19, 2016 11:00 pm
I attempted to rip Mission Impossilbe Rouge Nation today. It gets all the extras but fails to extract the main movie. I tried just ripping the main movie with the same problem. Anyone else have this problem? I'm looking for a ripper that will work but I don't want to have to buy another ripper.
Re: Mission Impossible Rouge Nation won't rip
#2 Post by Woodstock » Fri Feb 19, 2016 11:57 pm
If you could, make sure you have debug logging turned out (see the FAQ link in my signature), and post the log from the rip attempt. Not a lot we can offer without that...
FateSlicer815
#3 Post by FateSlicer815 » Sat Feb 20, 2016 1:47 am
Sorry about that. Here you go!
Debug log started at Sat Feb 20 01:23:42 2016 , written by MakeMKV v1.9.9 darwin(x86-release)
001005:0000 MakeMKV v1.9.9 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jeffreyrittenour/MakeMKV_log.txt
002010:0000 Optical drive "BD-ROM HL-DT-ST BD-RE UH12LS28 1.00d" opened in OS access mode.
005050:0000 Evaluation version, 29 day(s) out of 30 remaining
DEBUG: Code 2147483648 at N;KX^Rl4<!Ze}Fh<:121265315
DAFD=PAAAADAAAAEABDQkEHwEBAQ==
DCE=6kek/b56vic5gZ7Lmc3HEBnx40Fbq/KqikW+cWvXMtIKSsAAJneRHkr+8/4rLL/9HzSjnMw48r2eJSfegij84+aac5krA3bYMzOwlhstT8X3IxxxLp7BcsvydV+sL3FVY6CXjY/pHp80Wg+XJbH15IHL/hFANqYSgg==
DCE=2bLB1YJtQLauewuGsJnxQRVxOGsBoyg4Pk2RxnWLsYKllsjHK1jimcr7pfz3gc/vveixUINtGMCyb/XIX+hDb1oRZHx4WQL/G0KcycQsGdC1JeF3ZNVtnIVsDyNuz0rrkv1nqU8ylhekhBeYK2DNhUzKzKq4MjfNvQ==
DISCID=A6EC2F810AB326767C12CDB5E8E3C8BADBB1A7F8
003307:0000 File 00800.mpls was added as title #0
003025:0000 Title #00020.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00250.m2ts was added as title #1
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01066.m2ts was added as title #2
003307:0000 File 01067.m2ts was added as title #3
003307:0000 File 01068.m2ts was added as title #4
003307:0000 File 01069.m2ts was added as title #5
003307:0000 File 01070.m2ts was added as title #6
003307:0000 File 01071.m2ts was added as title #7
003025:0000 Title #00022.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005012:0104 No titles are selected. Nothing to do.
005014:0000 Saving 1 titles into directory /Volumes/Jeffs 4TB/Media/Blu-Ray
001003:0020 DEBUG: Code 1073741829 at >,\x[f/h?>+h0/f^:29393953
001003:0020 DEBUG: Code 101016576 at F>JXwv%D4 T>O,/t:121269731
001003:0020 DEBUG: Code 100806658 at F>JXwv%D4 T>O,/t:121269731
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8196519936'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8196519936'
DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:213130904
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8196521984'
001003:0020 DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:121262969
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8196519936'
DEBUG: Code 100806658 at !<t@/W*KKFu/M]@qE2:213130904
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8199665664'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8200058880'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8200058880'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8200060928'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8200126464'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8200126464'
DEBUG: Code 101016576 at !<t@/W*KKFu/M]@qE2:213130904
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8200126464'
001003:0020 DEBUG: Code 100806658 at !<t@/W*KKFu/M]@qE2:121262969
001003:0020 DEBUG: Code 0 at y0'(,k6zr!"t-8B-z*t<:121263291
001003:0020 DEBUG: Code 0 at _Z,(O/ A,th<R]rk8F>[:121262302
001003:0020 DEBUG: Code 0 at y0'(,k6zr!"t-8B-z*t<:213130812
001003:0020 DEBUG: Code 4003968 at y0'(,k6zr!"t-8B-z*t<:29393286
001003:0020 DEBUG: Code 0 at mG<:=b9W,P~ormm]K)|z[:29398967
005003:0000 Failed to save title 0 to file /Volumes/Jeffs 4TB/Media/Blu-Ray/Mission_Impossible_Rogue_Nation_t00.mkv
005004:0080 0 titles saved, 1 failed
001003:0020 DEBUG: Code 20 at Y`sVPMpId%+zxgK^i:29395011
Application exited at Sat Feb 20 01:47:38 2016
matt198t
#4 Post by matt198t » Sat Feb 20, 2016 11:57 am
hi jeff
#5 Post by Woodstock » Sat Feb 20, 2016 2:18 pm
Mike will have to translate the debug codes, but the posix errors are consistent with the drive going off-line.
If this were an external drive, I'd suspect the power supply, but the UH12LS28 is an internal drive, so it should have plenty of power to go full speed.
FateSlicer815
#6 Post by FateSlicer815 » Sat Feb 20, 2016 8:37 pm
Woodstock wrote:Mike will have to translate the debug codes, but the posix errors are consistent with the drive going off-line.
It actually is an internal drive in an external enclosure. I'm gonna try a couple things. It never says it unmounts though.
