Mission Impossible Rouge Nation won't rip
FateSlicer815
Post by FateSlicer815 »
I attempted to rip Mission Impossilbe Rouge Nation today. It gets all the extras but fails to extract the main movie. I tried just ripping the main movie with the same problem. Anyone else have this problem? I'm looking for a ripper that will work but I don't want to have to buy another ripper.
Re: Mission Impossible Rouge Nation won't rip
If you could, make sure you have debug logging turned out (see the FAQ link in my signature), and post the log from the rip attempt. Not a lot we can offer without that...
FateSlicer815
Sorry about that. Here you go!
Debug log started at Sat Feb 20 01:23:42 2016 , written by MakeMKV v1.9.9 darwin(x86-release)
001005:0000 MakeMKV v1.9.9 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jeffreyrittenour/MakeMKV_log.txt
002010:0000 Optical drive "BD-ROM HL-DT-ST BD-RE UH12LS28 1.00d" opened in OS access mode.
005050:0000 Evaluation version, 29 day(s) out of 30 remaining
DEBUG: Code 2147483648 at N;KX^Rl4<!Ze}Fh<:121265315
DAFD=PAAAADAAAAEABDQkEHwEBAQ==
DCE=6kek/b56vic5gZ7Lmc3HEBnx40Fbq/KqikW+cWvXMtIKSsAAJneRHkr+8/4rLL/9HzSjnMw48r2eJSfegij84+aac5krA3bYMzOwlhstT8X3IxxxLp7BcsvydV+sL3FVY6CXjY/pHp80Wg+XJbH15IHL/hFANqYSgg==
DCE=2bLB1YJtQLauewuGsJnxQRVxOGsBoyg4Pk2RxnWLsYKllsjHK1jimcr7pfz3gc/vveixUINtGMCyb/XIX+hDb1oRZHx4WQL/G0KcycQsGdC1JeF3ZNVtnIVsDyNuz0rrkv1nqU8ylhekhBeYK2DNhUzKzKq4MjfNvQ==
DISCID=A6EC2F810AB326767C12CDB5E8E3C8BADBB1A7F8
003307:0000 File 00800.mpls was added as title #0
003025:0000 Title #00020.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00250.m2ts was added as title #1
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01066.m2ts was added as title #2
003307:0000 File 01067.m2ts was added as title #3
003307:0000 File 01068.m2ts was added as title #4
003307:0000 File 01069.m2ts was added as title #5
003307:0000 File 01070.m2ts was added as title #6
003307:0000 File 01071.m2ts was added as title #7
003025:0000 Title #00022.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005012:0104 No titles are selected. Nothing to do.
005014:0000 Saving 1 titles into directory /Volumes/Jeffs 4TB/Media/Blu-Ray
001003:0020 DEBUG: Code 1073741829 at >,\x[f/h?>+h0/f^:29393953
001003:0020 DEBUG: Code 101016576 at F>JXwv%D4 T>O,/t:121269731
001003:0020 DEBUG: Code 100806658 at F>JXwv%D4 T>O,/t:121269731
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8196519936'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8196519936'
DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:213130904
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8196521984'
001003:0020 DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:121262969
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8196519936'
DEBUG: Code 100806658 at !<t@/W*KKFu/M]@qE2:213130904
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8199665664'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8200058880'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8200058880'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8200060928'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8200126464'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk7' at offset '8200126464'
DEBUG: Code 101016576 at !<t@/W*KKFu/M]@qE2:213130904
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8200126464'
001003:0020 DEBUG: Code 100806658 at !<t@/W*KKFu/M]@qE2:121262969
001003:0020 DEBUG: Code 0 at y0'(,k6zr!"t-8B-z*t<:121263291
001003:0020 DEBUG: Code 0 at _Z,(O/ A,th<R]rk8F>[:121262302
001003:0020 DEBUG: Code 0 at y0'(,k6zr!"t-8B-z*t<:213130812
001003:0020 DEBUG: Code 4003968 at y0'(,k6zr!"t-8B-z*t<:29393286
001003:0020 DEBUG: Code 0 at mG<:=b9W,P~ormm]K)|z[:29398967
005003:0000 Failed to save title 0 to file /Volumes/Jeffs 4TB/Media/Blu-Ray/Mission_Impossible_Rogue_Nation_t00.mkv
005004:0080 0 titles saved, 1 failed
001003:0020 DEBUG: Code 20 at Y`sVPMpId%+zxgK^i:29395011
Application exited at Sat Feb 20 01:47:38 2016
matt198t
Post by matt198t »
hi jeff
Mike will have to translate the debug codes, but the posix errors are consistent with the drive going off-line.
If this were an external drive, I'd suspect the power supply, but the UH12LS28 is an internal drive, so it should have plenty of power to go full speed.
FateSlicer815
Woodstock wrote:Mike will have to translate the debug codes, but the posix errors are consistent with the drive going off-line.
It actually is an internal drive in an external enclosure. I'm gonna try a couple things. It never says it unmounts though.
