Failed to rip The Martian on Blu Ray
jmsuter
Post by jmsuter »
I tried to rip The Martian twice but failed -please assist
Re: Failed to rip The Martian on Blu Ray
Um.... well.... how about you give us something to go on, other than the name of a move and, "It's Broke"?
See the FAQ link in my signature, enable debug logging, and show us the log...
iaanmbr
Post by iaanmbr »
Hi
I had the same problem this morning when I tried to rip The Martian with V1.9.8_osx.
When I upgraded to V1.9.9_osx it ripped perfectly.
This is my first post - I would like to take this opportunity to thank the developers for this brilliant software.
Regards, Ian
gmfm21
Post by gmfm21 »
I'm having this issue with MakeMKV 1.9.9 on Windows.
I'm pretty sure it's not an issue with a scratched disc as AnyDVD HD rips it to ISO just fine. Using MakeMKV to rip from the ISO also fails.
I got an error trying to attach the log files: "Sorry, the board attachment quota has been reached."
taran42
Post by taran42 »
Was a solution to this problem ever found? I can't seem to rip The Martian either. I am running version 1.10.6 on Windows. The error says it's a ready problem (either with the disc or my burner). I can rip other blu-ray movies fine, but not this one. I have even returned this copy and tried a second to no avail.
The dead are likely dull fellows, full of tedious complaints – 'the ground's too cold, my gravestone should be larger, why does he get more worms than I do...'
- "Dolorous" Edd Tollett
First of all, this topic is well over a year old, and applies to the Bluray version of The Martian, not the 4K UHD version. Are we discussing the correct disk?
1.10.6 is rather old; 1.10.9 has been out for a week or so now. I ripped The Martian BD with no issues using 1.10.8 last month.
If you got the "UHD + BD + Ultra" edition, make sure you inserted the correct disk.
taran42
Post by taran42 »
I realize the topic is old, but a solution was never posted and I'm having the same issue. I am hoping to garner one now. I am trying to rip the standard BD copy of The Martian, not something else.
I just started using MakeMKV back in January; I didn't realize my version was so out of date already. I'll update it and try again this evening.
taran42
Post by taran42 »
I upgraded to the newest version of MakeMKV and I'm still having problems ripping the BD. I double-checked to make sure it's not an ultra version, and it's not. I did notice a "copy protected" symbol on it. Is it possible that the encryption is too high for MakeMKV? I did read elsewhere of others having problems ripping The Martian (along with some other titles, with no solution there either).
I am able to rip other BD just fine (before and since this one). Does anyone have any ideas on what might be going on?
Every commercial disk out there is SUPPOSED to have the "copy protected" notification on its packaging somewhere.
But no, the CP on The Martian is not unknown; I ripped it just a month or so ago (BD and UHD versions).
You're probably getting read errors, but we can't tell from your "it doesn't work". What does your log say? (see the FAQ in my signature for how to turn on debug logging)
taran42
Post by taran42 »
Yes, I am getting a read error, which is supposed to indicate a problem with the burner or the disc. But my burner has ripped other BDs after this one successfully and this is the second The Martian BD I've tried to rip, both with the same result. Below is the log.
Debug log started at Tue Jan 16 01:26:52 2018 , written by MakeMKV v1.10.9 win(x64-release)
001005:0000 MakeMKV v1.10.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\TaRan/MakeMKV_log.txt
DEBUG: Code 2147483648 at @^82~V 4Zm*Q6mN::121264602
DAFD=PAAAADAAAAEABDQEEAQEBAQ==
DCE=7RSUS8JJ85+zl7/2t5zorBjqjdoBDGGIr/UxbissgYrdYWtNABWwOXVbjJ5svYiBqaCPZPl0LyFJJMm49Qdy+qDkP2bYLEK4jSgDGo0qhwtaiJbzcEw31Zr0Nfy47QNrqv/1vvGZ4ylJbCkU80TqosmIunrZnSMxRA==
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003322:0000 Processing BD+ code using disc-specific SVQ from builtin/dsall.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=A63FF8ADA1EBBA892B15769BDC1078DFB619CD51
003025:0000 Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00350.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00351.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00352.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00227.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00231.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00230.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00199.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00801.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00957.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00233.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00952.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00197.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00192.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00193.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00194.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00195.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00196.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00727.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02167.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02168.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02169.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02166.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02152.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01757.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02195.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01780.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01781.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02176.m2ts was added as title #1
003307:0000 File 02177.m2ts was added as title #2
003307:0000 File 02178.m2ts was added as title #3
003307:0000 File 02179.m2ts was added as title #4
003025:0000 Title #02180.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #02181.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 02182.m2ts was added as title #5
003307:0000 File 02183.m2ts was added as title #6
003307:0000 File 02184.m2ts was added as title #7
003307:0000 File 02185.m2ts was added as title #8
003025:0000 Title #02188.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/Video/The_Martian
001003:0020 DEBUG: Code 3221225628 at zyHK2SGt`?yk]I>0Mpq%qXgyD:213131617
001003:0020 DEBUG: Code 3221225628 at oOk_&^aD"y&\L=B?:29393953
001003:0020 DEBUG: Code 100864000 at M)PJRin""XGKIRv(:121269823
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/02175.m2ts' at offset '650311680'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '650311680'
DEBUG: Code 3221225628 at i*xOXNB02\B"BbfA8j:213130904
001003:0020 DEBUG: Code 3221225628 at i*xOXNB02\B"BbfA8j:121262969
DEBUG: Code 100864000 at i*xOXNB02\B"BbfA8j:213130904
001003:0020 DEBUG: Code 100864000 at i*xOXNB02\B"BbfA8j:121262969
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/02175.m2ts' at offset '650508288'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '650508288'
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/02175.m2ts' at offset '650637312'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '650637312'
001003:0020 DEBUG: Code 0 at BMZJfxOZl8n]\Fg=tQT4:29395034
001003:0020 DEBUG: Code 0 at LiH"$9$[#h't{93O\G W:29394045
001003:0020 DEBUG: Code 0 at BMZJfxOZl8n]\Fg=tQT4:121262647
001003:0020 DEBUG: Code 317694 at BMZJfxOZl8n]\Fg=tQT4:213129593
001003:0020 DEBUG: Code 0 at U*(XDQT/}"2Z$X.ikDO#,:29399197
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 0 to file C:/Video/The_Martian/The_Martian_t00.mkv
002023:0000 Encountered 20 errors of type 'Read Error' - see /errors/read/
error=0x06031000 count=20 name=Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR
Encountered 18 unclassified errors
error=0xC000009C count=18 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 1 failed
Application exited at Tue Jan 16 01:39:58 2018
The errors you are getting are concentrated in one section of '/BDMV/STREAM/02175.m2ts', and start around offset '650311680'. The sector at that area does not pass the consistency check, so the system retries the read... issuing a NOT READY status after it times out.
Unfortunately, that segment map is the main feature:
Title information
Name: The Martian (English)
Source file name: 00800.mpls
Duration: 2:21:37
Chapters count: 32
Segment count: 1
Segment map: 2175
File name: The_Martian_t00.mkv
All I can say is that, in general, MakeMKV has no issue with The Martian, so long as your drive can read it.
Just because you've already replaced a disk is no guarantee you did not get another defective one. I went through 4 copies of one disk on Hercules to get one that was readable. When dealing with manufacturing defects, entire lots can have the same defect.
taran42
Post by taran42 »
So what you're saying is that, according to the logs, there's a section of the disc that can't be read due, probably, to a manufacturing defect?
I've tried trial copies of a few other ripping programs, just to see if it was MakeMKV having the problem, but they couldn't rip it either. I suppose this would explain that.
All we really know is that the spot is consistently unreadable. If it varied even a little, the more likely explanation would be dirt or a scratch, but it isn't varying, and that section on other disks (at least the one I own) does not have anything special about it in terms of being readable.
I'd still try cleaning it with a damp soft cotton cloth before getting it replaced...
rivey
Post by rivey »
I just recently ordered this movie from Amazon and it burned perfectly. I have since watched the movie with no problems what ever. I have had a few issues with other movies and they were always problems with older or dirty discs. I now make it a policy to burn the disks when I first receive them and only watch them from my server with Plex. I have also recently obtained a laser cleaner from my drive along with compressed air to make sure there are no other problems. Good luck.
taran42
Post by taran42 »
I tried cleaning the disk with a damp cloth last night. I still couldn't get it to burn. It looks like burning this disc is a lost cause for me. I think I'll see if I can't find it at Redbox, or borrow it from someone, and burn it then. That should take me out of the defective batch pile -
that or return the disc in a few months, when a new batch should be available. Thanks for all of the help. Now I know what to look for if I have this problem in the future.
