Seeking hardware recommendation: External USB Blu-Ray Player
rogodeter
Post by rogodeter »
I have a laptop that does not have a built-in blu-ray drive. I'm wondering if anybody has experience with external (USB) Blu-Ray players and if there are any issues/recommendations with respect to MakeMKV and external players (I'm on Linux if it matters)
Re: Seeking hardware recommendation: External USB Blu-Ray Pl
Biggest issue with external drives is getting them sufficient power, regardless of the operating system. When they spin fast, they need full-spec USB power (older ones need more than full spec), and any non-powered hub will not provide that. If the drive has its own power adapter, that is "better", in that you don't have the issue with power, just an extra wall wart and cord to deal with.
rogodeter
Post by rogodeter »
Woodstock wrote:Biggest issue with external drives is getting them sufficient power, regardless of the operating system. When they spin fast, they need full-spec USB power (older ones need more than full spec), and any non-powered hub will not provide that. If the drive has its own power adapter, that is "better", in that you don't have the issue with power, just an extra wall wart and cord to deal with.
Thanks for that tip, I will ensure I get one with an external power adapter. I don't need to use it through a hub, not really an issue.
Have you used any usb external blu ray players with particular success (assuming adequate power)?
No personal experience with USB BD so far, just USB DVD.
My old Sony is only brought out for ripping if I have a DVD that refuses to allow the blue laser to scan it... Some disks just only work with red!
NShameA
Post by NShameA »
Don't limit yourself by connection. you can use a case on internal drives to match many interfaces. BYTECC is what I use.
rogodeter
Post by rogodeter »
Thanks for the information all,
I decided that power is not an issue as portability is not much of a concern (I don't mind keeping it plugged in all the time). I went with the Buffalo bdXL, thinking that with cheap media I could replace a couple 5TB backup drives with a stack of 128GB bdXL's -- Guess I didn't do much research to find out that the media is prohibitively expensive and the format doesn't have a lot of support.
So I have the drive now and it burns Blu-Ray's very quickly, DVD-ROMs are slow, but my work has just ordered me a Macbook Pro so I'll wait and see if the driver support is better there than on my current setup (Linux)
MustangChris04
Post by MustangChris04 »
I've been using this player for 18 months now without any issues. I have played over 300 blu-rays on this player: http://www.amazon.com/Everpower-Externa ... op?ie=UTF8
Not sure why everybody is making a big issue about the power. My USB 2.0 port on my dell and macbook power this drive without any issues.
taylorwmj
Post by taylorwmj »
Without a doubt this is the best drive you can get IMO:
http://www.amazon.com/LG-Electronics-Su ... lg+blu+ray
There is no rip-lock and it it's incredibly reliable. Also worth noting that a new version of this (not advertised by LG, but it is a slight upgrade) that will supposedly play more friendly with UHD BD when we finally get to the point of getting past encryption.
I know you said you already bought a drive, but I currently am using this on Ubuntu Server w/MakeMKV w/no issues at all.
rogodeter
Post by rogodeter »
Thanks for the recommendation. I do already have the Buffalo, which is working ok so far, but if it dies I've got this one in my Amazon list for future reference.
taylorwmj wrote:Without a doubt this is the best drive you can get IMO:
JeffR1
Post by JeffR1 »
Maybe that new one from LG that's not advertised will eventually have the UHD Blu-ray logo on it.
