UHD Blu-ray
UHD Blu-ray
UHD Blu-ray (4K) movies are shipping now and people are starting to get them. A few people on AVS have tested them in BDXL drives and Windows doesn't even recognize it as a readable disc. I intend on testing this as well using my BD drives and was curious if there were any data that would be useful to people here. Word is that some UHD Blu-ray movies are shipping on existing BD-50 discs, while others are shipping on BDXL triple layer discs, but no one seems to know exactly what the file structure is - let alone the copy protection in place.
Will MakeMKV support UHD or offer an upgrade? I'd love a free update, but I'd also love to support the devs.
Re: UHD Blu-ray
U-HD BDs will use two layer types - the conventional 25 GB per layer type used in BD SL and DL type discs and the 33 GB per layer higher density type used in BDXL TL and QL discs. Some U-HD BDs that are dual layer may have 66 GB capacity due to the use of the higher density layer type.nathanddrews wrote:UHD Blu-ray (4K) movies are shipping now and people are starting to get them. A few people on AVS have tested them in BDXL drives and Windows doesn't even recognize it as a readable disc. I intend on testing this as well using my BD drives and was curious if there were any data that would be useful to people here. Word is that some UHD Blu-ray movies are shipping on existing BD-50 discs, while others are shipping on BDXL triple layer discs, but no one seems to know exactly what the file structure is - let alone the copy protection in place.
Re: UHD Blu-ray
I got sick of waiting for my Amazon shipment, so I walked into Best Buy and bought "The Martian" 4K UltraHD Blu-ray. Tested on:
Windows 7 Pro
ASUS BC12B1ST (did not recognize)
LG WH14NS40 (recognized)
LG WH16NS40 (recognized)
Obviously, I can't do anything beyond this yet.
Windows 7 Pro
Re: UHD Blu-ray
Log file of the attempted backups.
- MakeMKV_log.txt
- (309 Bytes) Downloaded 921 times
Re: UHD Blu-ray
There sure isn't much on that log file, did you follow the instructions in this tutorial ?nathanddrews wrote:Log file of the attempted backups.
/faq/item/8
Re: UHD Blu-ray
According to the tutorial, I did it correctly. I agree that it's short.JeffR1 wrote:There sure isn't much on that log file, did you follow the instructions in this tutorial ?nathanddrews wrote:Log file of the attempted backups.
/faq/item/8
Re: UHD Blu-ray
You aren't going to be able to back it up, even if you get a drive that will read the disc. The 4K releases have to use AACS 2.0, which has not been busted, yet. The DVDFab owner's put out a release that said they have zero plans to do so.nathanddrews wrote:I got sick of waiting for my Amazon shipment, so I walked into Best Buy and bought "The Martian" 4K UltraHD Blu-ray.
Re: UHD Blu-ray
I wonder if MakeMKV rely on SlySoft servers, or have they decrypted AACS 1.0 (up to v57) using their unique own method...
Re: UHD Blu-ray
We'll give it a few days then, I'm sure it will be quite simple to deal with and they'll get right on it...nathanddrews wrote:According to the tutorial, I did it correctly. I agree that it's short.JeffR1 wrote:There sure isn't much on that log file, did you follow the instructions in this tutorial ?nathanddrews wrote:Log file of the attempted backups.
/faq/item/8
Re: UHD Blu-ray
My guess is Mike has his own method, although there is provisions within MakeMKV to use the "volume key database" maintained by others. That way, if a key in that publicly-available database gets revoked, it does not affect MakeMKV.James Freeman wrote:I wonder if MakeMKV rely on SlySoft servers, or have they decrypted AACS 1.0 (up to v57) using their unique own method...
Re: UHD Blu-ray
Capt. Obvious is obvious.MrVideo wrote:You aren't going to be able to back it up, even if you get a drive that will read the disc. The 4K releases have to use AACS 2.0, which has not been busted, yet. The DVDFab owner's put out a release that said they have zero plans to do so.nathanddrews wrote:I got sick of waiting for my Amazon shipment, so I walked into Best Buy and bought "The Martian" 4K UltraHD Blu-ray.
Re: UHD Blu-ray
The way some of the posts were written, it read like backing up the disc was going to be a possibility. So, out came Capt Obvious to make sure.nathanddrews wrote:Capt. Obvious is obvious.MrVideo wrote:You aren't going to be able to back it up, even if you get a drive that will read the disc. The 4K releases have to use AACS 2.0, which has not been busted, yet. The DVDFab owner's put out a release that said they have zero plans to do so.nathanddrews wrote:I got sick of waiting for my Amazon shipment, so I walked into Best Buy and bought "The Martian" 4K UltraHD Blu-ray.
Re: UHD Blu-ray
You must have missed the last sentence of that post "Obviously, I can't do anything beyond this yet.". I only wanted to get the discs in my hands to test out which of my BD drives would recognize or read the discs. I had no expectation of adding it to my library yet.MrVideo wrote:The way some of the posts were written, it read like backing up the disc was going to be a possibility. So, out came Capt Obvious to make sure.
Re: UHD Blu-ray
I am super excited to see that it works on the LG WH16NS40. This is the same drive that I have. You may need to upgrade your firmware though. I am on the latest 1.02-A0 and am going to test with that. Also, I plan on making an ISO copy of the movies until the encryption is busted so I can make a backup of my legally purchased movies, and play them back in the digital file format that I choose.nathanddrews wrote:I got sick of waiting for my Amazon shipment, so I walked into Best Buy and bought "The Martian" 4K UltraHD Blu-ray. Tested on:
Re: UHD Blu-ray
goaliebob99 wrote:I am super excited to see that it works on the LG WH16NS40. This is the same drive that I have. You may need to upgrade your firmware though. I am on the latest 1.02-A0 and am going to test with that. Also, I plan on making an ISO copy of the movies until the encryption is busted so I can make a backup of my legally purchased movies, and play them back in the digital file format that I choose.nathanddrews wrote:I got sick of waiting for my Amazon shipment, so I walked into Best Buy and bought "The Martian" 4K UltraHD Blu-ray. Tested on:
Drats.... F*ING LG! It appears I have the older one... Ordering a new one on Amazon.com now.... Just read through the thread over at AVS...
