007 spectre no fut errors may occur. Please update
jwbx007
Post by jwbx007 » Sun Feb 14, 2016 9:47 pm
007 spectre no fut obtained errors may occur error
Re: 007 spectre no fut errors may occur. Please update
Post by Woodstock » Mon Feb 15, 2016 1:43 am
Did you send the TGZ file created by MakeMKV to svq@makemkv.com so that Mike can analyze it?
jwbx007
Post by jwbx007 » Mon Feb 15, 2016 7:42 pm
No I didn't send it if anyone else has this problem can they please send it to be analyzed please thanks I will know to do so in the future never had this problem before
007 spectre please someone send it to be analyzed thanks again
jwbx007
Post by jwbx007 » Mon Feb 15, 2016 7:54 pm
I didn't get the blue error where I could send it it just came up errors may follow so I don't know what to do to fix this problem.other movies gave me a blue error script I could just report.can anyone else try this blu ray and see if I'm the only one having problems and please report it if u have the same problem thanks
Post by Woodstock » Tue Feb 16, 2016 12:10 am
What is a "blue error script"?
jwbx007
Post by jwbx007 » Tue Feb 16, 2016 10:16 pm
yes i have sent the required files to mike so he can analyse them and make the updates needed
mike if u have fixed the errors please reply a post so i know
thanks jwbx007
jwbx007
Post by jwbx007 » Wed Feb 17, 2016 7:45 pm
Anyone able to rip spectre 007 yet I emailed the files to be analyzed by Mike but haven't heard if the problem has been fixed yet
Mike please let me know
jwbx007
Post by jwbx007 » Thu Feb 18, 2016 9:12 pm
Has spectre 007 been updated yet so I can rip it error free I sent Mike files to be analyzed
Anyone having problems ripping blu ray spectre
How will I know if it has been updated error free
Post by Woodstock » Fri Feb 19, 2016 7:17 am
The fast way to tell (assuming someone has sent the TGZ file in for analysis, like has happened here) is to make sure you have automatic update checks turned on, and try ripping the disk again. SVQ updates will automatically be downloaded as needed and available, and the NO FUTs error will disappear.
The key is to make sure it's enabled. Good network practices say you should avoid leaving auto-update stuff turned on when you're not expecting an update, as many Windows users find out when the latest auto-update makes their machine unbootable. It is safe to turn off "Check web server for updates" in MakeMKV, turn it on when you NEED to do something like rip a NO FUTs disk, then turn it back off.
Fisk123
Post by Fisk123 » Tue Mar 01, 2016 5:44 pm
The same FTU-Message and picture errors here on a german Blu Ray. - So I guess it is still not working.
The Death Stalker
Post by The Death Stalker » Wed Mar 02, 2016 3:58 am
Fisk123 wrote:The same FTU-Message and picture errors here on a german Blu Ray. - So I guess it is still not working.
Same here
Fisk123
Post by Fisk123 » Wed Mar 02, 2016 2:12 pm
@The Death Stalker
Yesterday I have send in the dump-file and received a answer today, that the support team need another file. - I have send it in today, I hope the software will get an update soon...
The Death Stalker
Post by The Death Stalker » Wed Mar 02, 2016 2:56 pm
Roger that and thanks for your response.
blofeldscat
Post by blofeldscat » Thu Mar 03, 2016 5:58 am
I have the Region A BD of SPECTRE and also got the 'FUT' issue and broken picture on conversion.
I updated to v1.9.9 (from v1.9.7) and the 'FUT' error did NOT appear. The resultant mkv file was perfect.
The Death Stalker
Post by The Death Stalker » Thu Mar 03, 2016 11:30 am
I used 1.9.9 already before, I have the region B of the BD.
Even after a fresh installation of makemkv, the 'FUT' error still coming.
