Region Code Error
kahasm
Region Code Error
Post by kahasm » Sun Feb 14, 2016 5:43 am
while trying to read Straight outta compton, I received the following message:
Region setting of drive PIONEER:BD-RW BDR-209M does not match the region of currently inserted disc, trying to work around...
DEBUG: Code 233 at 5A5LcnUEXOAvYWLuViaSLZEK:0
the dvd drive in question is region 1 ( which is the united states ) and the dvd is also region 1; plays fine on pc or on home audio dvd player
Re: Region Code Error
Post by Woodstock » Sun Feb 14, 2016 6:09 am
Region coding can give strange results from time to time. Did MakeMKV report that the title was saved? Normally, it does not CARE what region the drive or disk are.... I regularly rip out-of-region DVDs without issue, but with warnings.
Before I removed my DVD drive from the primary ripping computer (needed a second BD because of the shift in my purchases), it didn't even have a region selected...
h436d
Post by h436d » Mon Jan 09, 2023 1:20 am
I apologize to bump an old thread but since it is the first result for this error on google I figure I might as well put a solution here for others who might experience it.
I never used to get this error but I just started getting it with the latest beta update.
The error went away when I stopped running makemkv from a "snap" installation and started running it from a native debian ppa install.
Anyone else experiencing this issue may want to attempt the same thing. I suspect it may be related to some change in the access the unofficial snap version has to access the underlying hardware as the following error was showing up in dmesg.
[   94.576728] audit: type=1400 audit(1673224622.297:135): apparmor="DENIED" operation="open" profile="snap.makemkv.makemkv" name="/dev/sg0" pid=17817 comm="makemkvcon" requested_mask="w" denied_mask="w" fsuid=1000 ouid=0
[   98.294219] audit: type=1400 audit(1673224626.013:136): apparmor="DENIED" operation="open" profile="snap.makemkv.makemkv" name="/dev/sg0" pid=17817 comm="makemkvcon" requested_mask="w" denied_mask="w" fsuid=1000 ouid=0
Jeppedy
Post by Jeppedy » Mon Jan 23, 2023 6:51 pm
I'm getting the same issue. Ubuntu with Docker. Takes extra time, but no reason I can think of it should be having region issues
Qwerty27
Post by Qwerty27 » Sun Oct 29, 2023 1:18 am
h436d wrote: Mon Jan 09, 2023 1:20 am I apologize to bump an old thread but since it is the first result for this error on google I figure I might as well put a solution here for others who might experience it.
Do I have to put this in a terminal. Or reinstall make mkv with this. I tried it in terminal, and it came up with "syntax error near unexpected token '(' " and, so I changed it the '[' to '(' and it bash: syntax error near unexpected token audit:
Am I doing something wrong or am I not putting it in the right area? Or do I have to reinstall makemkv. I don't know. I am using Linux zoron os 15.1 and today was really the first day messing with terminal
Post by dcoke22 » Sun Oct 29, 2023 4:18 pm
h436d didn't provide any command line instructions. They merely posted some log files to show the error being discussed.
