BD Drive problem after 1.9.8/9 upgrade
Ripman
Post by Ripman » Wed Feb 10, 2016 2:52 pm
I get the "Overread auxiliary data by 32 bits" from the dca decoder code in Handbrake for the 3 BDs in the Bourne box purchased at BB. Here is a link with a similar report. http://www.makemkv.com/forum2/viewtopic.php?f=8&t=8654
The DTS-HD MA audio track from Bourne 1 movie is 3+ gb. I can send a piece of it if that makes sense - as can be seen in the attached HB log, the errors occur in chapter 13. Tbh, though, I am thinking that the external LG drive is locked now. Win8.1 shows the drive has 5 region selections remaining.
I upgraded from 1.9.4 to 1.9.8 during the first week of 2016. (I upgraded to 1.9.9 yesterday.) On line 6 of each of the posted logs, there is a "DEBUG" message. I have received this message with every rip since upgrading to 1.9.8. I never received this message prior to upgrading to 1.9.8. Perhaps it's drive related; sometimes I start MakeMKV and if there is a BD in the drive, I get thousands of DEBUG messages, which causes me to reboot. I'm using an external LG BD drive with both USBs connected to ports on a Win8.1 machine.
I tried ripping a DVD from the drive, and that worked, but also gave the "DEBUG" message.
Attached are the 3 MakeMKV logs from the Bourne box, and an HB log for Bourne 1. I also put the log of a DVD rip from the LG drive. In the zip, all of my MakeMKV logs since upgrading to 1.9.8. Interestingly, for the rips in the zip that had DTS audio tracks, I put all of them back through ffmpeg/HB - converting the DTS-HD MA audio track to ac3 5.1, ac3 stereo, and aac stereo - and none gave the "overread" error. Even more interesting is the timing of the events: 1. on 1/6 at 7.30pm completed backup of The Third Man BD; 2. on 1/6 at 8pm upgraded to 1.9.8 to process Speedy with aacs v57 - this is the first rip with 1.9.8; and 3. after the 1.9.8 upgrade on 1/6, the external BD drive I use is not functioning normally.
I am OK grabbing a new drive bc that's the nature of this beast. But MakeMKV isn't supposed to process things that aren't 100% spot-on. And in the case of the Bourne BDs or other DVD I posted about, this did not happen. Also, given the timing of events and the supporting logs, it would seem that something in the 1.9.8 upgrade locked my BD drive.
And, even as the external BD drive is not functioning properly, I created some 20-30 mkv's in the last month. Should I redo all of those once I grab a new drive? (I've watched them all, and as mentioned above, ran them all through ffmpeg/HB to convert the respective DTS-HD MA audio tracks to see if there were any "overread" errors reported.)
Any ideas are helpful. Thanks.
Bourne 1 MakeMKV 1.9.9 log
Debug log started at Tue Feb 09 21:18:17 2016 , written by MakeMKV v1.9.9 win(x64-release)
001005:0000 MakeMKV v1.9.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Jeff/MakeMKV_log.txt
DEBUG: Code 2147483648 at <slXx\[d-S,|-ORN:121265315
DAFD=PAAAADAAAAEABDQkEFgACAQ==
DCE=5h1lafD/CJbJSkzbDE6uPr1PcOgWtK4CCbkdgWvhwc9PTkTb1781+WXq/oMmjcpiyokcUdUPRNbAUw13oZHd2Haf1Ae8885Luc68opntFwXzab5asivSSsrwAtB5U8Heko+ms3Bk4XJuZ+bhDDIxxRh5zbEwCcwiVg==
DCE=jgQ+bO0kqOJOyJ4VC/zt0KpQUQkgmNg5k5RcV28Sih0ciHBrJSWbdBX/nH9n2rSm/44f+dTJsXqKzsqlryENkdSCwaDeAlTB7k6BaZVy8zJ4B0DaGw0tH69/Ghc+lj2KE0l3ahzAmClY67iBTnLh5g0Jf0PpkjCp/A==
DISCID=171EAE2E6331FD1A0EC3733E00A06B21CB94F0EA
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00010.mpls was added as title #1
003307:0000 File 00040.mpls was added as title #2
003307:0000 File 00036.mpls was added as title #3
003307:0000 File 00055.mpls was added as title #4
003307:0000 File 00061.mpls was added as title #5
003307:0000 File 00062.mpls was added as title #6
003307:0000 File 00063.mpls was added as title #7
003307:0000 File 00064.mpls was added as title #8
003307:0000 File 00065.mpls was added as title #9
003307:0000 File 00066.mpls was added as title #10
003307:0000 File 00067.mpls was added as title #11
003307:0000 File 00068.mpls was added as title #12
003309:0000 Title 00504.mpls is equal to title 00000.mpls and was skipped
003307:0000 File 00586.mpls was added as title #13
003025:0000 Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #14
003307:0000 File 00010.m2ts was added as title #15
003307:0000 File 00012.m2ts was added as title #16
003307:0000 File 00013.m2ts was added as title #17
003307:0000 File 00050.m2ts was added as title #18
003307:0000 File 00056.m2ts was added as title #19
003307:0000 File 00060.m2ts was added as title #20
003307:0000 File 00061.m2ts was added as title #21
003307:0000 File 00062.m2ts was added as title #22
003309:0000 Title 00064.m2ts is equal to title 00061.mpls and was skipped
003309:0000 Title 00065.m2ts is equal to title 00062.mpls and was skipped
003309:0000 Title 00066.m2ts is equal to title 00063.mpls and was skipped
003309:0000 Title 00067.m2ts is equal to title 00064.mpls and was skipped
003309:0000 Title 00068.m2ts is equal to title 00065.mpls and was skipped
003309:0000 Title 00069.m2ts is equal to title 00066.mpls and was skipped
003309:0000 Title 00070.m2ts is equal to title 00067.mpls and was skipped
003309:0000 Title 00071.m2ts is equal to title 00068.mpls and was skipped
003307:0000 File 00072.m2ts was added as title #23
003307:0000 File 00073.m2ts was added as title #24
003307:0000 File 00074.m2ts was added as title #25
003307:0000 File 00075.m2ts was added as title #26
003307:0000 File 00076.m2ts was added as title #27
003307:0000 File 00077.m2ts was added as title #28
003307:0000 File 00078.m2ts was added as title #29
003307:0000 File 00079.m2ts was added as title #30
003307:0000 File 00080.m2ts was added as title #31
003307:0000 File 00081.m2ts was added as title #32
003307:0000 File 00082.m2ts was added as title #33
003307:0000 File 00083.m2ts was added as title #34
003307:0000 File 00084.m2ts was added as title #35
003307:0000 File 00085.m2ts was added as title #36
003307:0000 File 00086.m2ts was added as title #37
003307:0000 File 00087.m2ts was added as title #38
003307:0000 File 00088.m2ts was added as title #39
003307:0000 File 00089.m2ts was added as title #40
003307:0000 File 00090.m2ts was added as title #41
003307:0000 File 00091.m2ts was added as title #42
003307:0000 File 00092.m2ts was added as title #43
003307:0000 File 00346.m2ts was added as title #44
003307:0000 File 00347.m2ts was added as title #45
003307:0000 File 00348.m2ts was added as title #46
003307:0000 File 00349.m2ts was added as title #47
003307:0000 File 00350.m2ts was added as title #48
003025:0000 Title #00351.m2ts has length of 3 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00352.m2ts has length of 2 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00353.m2ts has length of 3 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00354.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00355.m2ts has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00356.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00357.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00358.m2ts has length of 2 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00359.m2ts has length of 2 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00360.m2ts has length of 2 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00361.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00362.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00363.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00364.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00365.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00366.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00367.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00368.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00369.m2ts has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00370.m2ts has length of 3 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00371.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/30
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Tue Feb 09 21:48:52 2016
Bourne 1 HB 0.10.2 log
HandBrake 0.10.2.7286 - 64bit Version
OS: Microsoft Windows NT 6.2.9200.0 - 64bit
CPU: Intel(R) Celeron(R) CPU  N2830  @ 2.16GHz
Ram: 3982 MB,
GPU Information:
  Intel(R) HD Graphics - 10.18.10.3355
Screen: 1366x768
Temp Dir: C:\Users\Jeff\AppData\Local\Temp\
Install Dir: C:\Program Files\Handbrake
Data Dir: C:\Users\Jeff\AppData\Roaming\HandBrake\HandBrake\0.10.2.7286
CLI Query:  -i "C:\30\The_Bourne_Identity_t00.mkv" -t 1 --angle 1 -c 13 -o "C:\01\The Bourne Identity DTS HB.mkv"  -f mkv  -w 1920 --crop 132:132:0:0 --loose-anamorphic  --modulus 2 -e x264 -q 51 --vfr -a 1,1,1 -E av_aac,ac3,ac3 -6 stereo,stereo,5point1 -R Auto,48,48 -B 448,640,640 -D 0,0,0 --gain 0,0,0 --audio-fallback ac3 --markers="C:\Users\Jeff\AppData\Local\Temp\The Bourne Identity DTS HB-1-chapters.csv" --encoder-preset=ultrafast  --encoder-level="3.2"  --encoder-profile=main  --verbose=2
hb_qsv_info_init: mfxExtCodingOption2 check failed (0x20435641, 0x104, -17)
[19:33:34] hb_init: starting libhb thread
[19:33:34] thread 215c4c0 started ("libhb")
HandBrake 0.10.2 (2015060900) - MinGW x86_64 - https://handbrake.fr
2 CPUs detected
Opening C:\30\The_Bourne_Identity_t00.mkv...
[19:33:34] CPU: Intel(R) Celeron(R) CPU  N2830  @ 2.16GHz
[19:33:34]  - Intel microarchitecture Silvermont
[19:33:34]  - logical processor count: 2
[19:33:34] OpenCL device #1: Intel(R) Corporation Intel(R) HD Graphics
[19:33:34]  - OpenCL version: 1.2
[19:33:34]  - driver version: 10.18.10.3355
[19:33:34]  - device type:    GPU
[19:33:34]  - supported:      YES
[19:33:34] Intel Quick Sync Video support: yes
[19:33:34]  - Intel Media SDK hardware: API 1.7 (minimum: 1.3)
[19:33:34]  - H.264 encoder: yes
[19:33:34]     - preferred implementation: hardware (any)
[19:33:34]     - capabilities (hardware):  api1.6
[19:33:34]  - H.265 encoder: no
[19:33:34] hb_scan: path=C:\30\The_Bourne_Identity_t00.mkv, title_index=1
[19:33:34] thread 215eda0 started ("scan")
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening C:\30\The_Bourne_Identity_t00.mkv/BDMV/index.bdmv
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening C:\30\The_Bourne_Identity_t00.mkv/BDMV/BACKUP/index.bdmv
libbluray/bluray.c:2182: nav_get_title_list(C:\30\The_Bourne_Identity_t00.mkv) failed
[19:33:34] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 5.0.1
libdvdread: Encrypted DVD support unavailable.
libdvdread:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdread:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[19:33:34] dvd: not a dvd - trying as a stream/file instead
Input #0, matroska,webm, from 'C:\30\The_Bourne_Identity_t00.mkv':
  Metadata:
    title           : The Bourne Identity
  Duration: 01:58:17.42, start: 0.000000, bitrate: N/A
    Chapter #0.0: start 0.000000, end 387.804083
    Metadata:
      title           : Chapter 01
    Chapter #0.1: start 387.804083, end 514.805958
    Metadata:
      title           : Chapter 02
    Chapter #0.2: start 514.805958, end 698.489458
    Metadata:
      title           : Chapter 03
    Chapter #0.3: start 698.489458, end 817.942125
    Metadata:
      title           : Chapter 04
    Chapter #0.4: start 817.942125, end 1183.265417
    Metadata:
      title           : Chapter 05
    Chapter #0.5: start 1183.265417, end 1540.997792
    Metadata:
      title           : Chapter 06
    Chapter #0.6: start 1540.997792, end 1755.420333
    Metadata:
      title           : Chapter 07
    Chapter #0.7: start 1755.420333, end 2196.277417
    Metadata:
      title           : Chapter 08
    Chapter #0.8: start 2196.277417, end 2636.508875
    Metadata:
      title           : Chapter 09
    Chapter #0.9: start 2636.508875, end 2907.696458
    Metadata:
      title           : Chapter 10
    Chapter #0.10: start 2907.696458, end 3112.150708
    Metadata:
      title           : Chapter 11
    Chapter #0.11: start 3112.150708, end 3721.342625
    Metadata:
      title           : Chapter 12
    Chapter #0.12: start 3721.342625, end 4201.280417
    Metadata:
      title           : Chapter 13
    Chapter #0.13: start 4201.280417, end 4724.886833
    Metadata:
      title           : Chapter 14
    Chapter #0.14: start 4724.886833, end 5039.617917
    Metadata:
      title           : Chapter 15
    Chapter #0.15: start 5039.617917, end 5500.119625
    Metadata:
      title           : Chapter 16
    Chapter #0.16: start 5500.119625, end 5919.246667
    Metadata:
      title           : Chapter 17
    Chapter #0.17: start 5919.246667, end 6312.973333
    Metadata:
      title           : Chapter 18
    Chapter #0.18: start 6312.973333, end 6693.645292
    Metadata:
      title           : Chapter 19
    Chapter #0.19: start 6693.645292, end 7097.423667
    Metadata:
      title           : Chapter 20
    Stream #0.0(eng): Video: vc1 (Advanced), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 1k tbn, 47.95 tbc
    Metadata:
      BPS-eng         : 29758984
      DURATION-eng    : 01:58:17.423666666
      NUMBER_OF_FRAMES-eng: 170168
      NUMBER_OF_BYTES-eng: 26401512721
      SOURCE_ID-eng   : 001011
      _STATISTICS_WRITING_APP-eng: MakeMKV v1.9.9 win(x64-release)
      _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 21:22:18
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
    Stream #0.1(eng): Audio: dca (DTS-HD MA), 48000 Hz, 5.1, fltp, 1536 kb/s (default)
    Metadata:
      title           : Surround 5.1
      BPS-eng         : 4314952
      DURATION-eng    : 01:58:17.429333333
      NUMBER_OF_FRAMES-eng: 665384
      NUMBER_OF_BYTES-eng: 3828133912
      SOURCE_ID-eng   : 001100
    Stream #0.2(eng): Audio: dca (DTS), 48000 Hz, 5.1, fltp, 1536 kb/s
    Metadata:
      BPS-eng         : 1509000
      NUMBER_OF_BYTES-eng: 1338752608
    Stream #0.3(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
    Metadata:
      title           : Stereo
      BPS-eng         : 192000
      DURATION-eng    : 01:58:17.440000000
      NUMBER_OF_FRAMES-eng: 221795
      NUMBER_OF_BYTES-eng: 170338560
      SOURCE_ID-eng   : 001103
    Stream #0.4(eng): Subtitle: pgssub
    Metadata:
      BPS-eng         : 29166
      DURATION-eng    : 01:50:16.922812500
      NUMBER_OF_FRAMES-eng: 2263
      NUMBER_OF_BYTES-eng: 24123690
      SOURCE_ID-eng   : 001200
[19:33:34] Found ffmpeg 20 chapters, container=matroska,webm
[19:33:34] Added chapter 1, name='Chapter 1', dur=34902367, (00:06:28)
[19:33:34] Added chapter 2, name='Chapter 2', dur=11430169, (00:02:07)
[19:33:34] Added chapter 3, name='Chapter 3', dur=16531515, (00:03:04)
[19:33:34] Added chapter 4, name='Chapter 4', dur=10750740, (00:01:59)
[19:33:34] Added chapter 5, name='Chapter 5', dur=32879096, (00:06:05)
[19:33:34] Added chapter 6, name='Chapter 6', dur=32195914, (00:05:58)
[19:33:34] Added chapter 7, name='Chapter 7', dur=19298028, (00:03:34)
[19:33:34] Added chapter 8, name='Chapter 8', dur=39677138, (00:07:21)
[19:33:34] Added chapter 9, name='Chapter 9', dur=39620831, (00:07:20)
[19:33:34] Added chapter 10, name='Chapter 10', dur=24406883, (00:04:31)
[19:33:34] Added chapter 11, name='Chapter 11', dur=18400882, (00:03:24)
[19:33:34] Added chapter 12, name='Chapter 12', dur=54827273, (00:10:09)
[19:33:34] Added chapter 13, name='Chapter 13', dur=43194401, (00:08:00)
[19:33:34] Added chapter 14, name='Chapter 14', dur=47124577, (00:08:44)
[19:33:34] Added chapter 15, name='Chapter 15', dur=28325798, (00:05:15)
[19:33:34] Added chapter 16, name='Chapter 16', dur=41445154, (00:07:41)
[19:33:34] Added chapter 17, name='Chapter 17', dur=37721433, (00:06:59)
[19:33:34] Added chapter 18, name='Chapter 18', dur=35435400, (00:06:34)
[19:33:34] Added chapter 19, name='Chapter 19', dur=34260477, (00:06:21)
[19:33:34] Added chapter 20, name='Chapter 20', dur=36340053, (00:06:44)
[19:33:34] dxva2:DxFindVideoServiceConversion failed
[19:33:34] scan: decoding previews for title 1
[19:33:34] scan: preview 1
[19:33:34] fifo_close: trashing 0 buffer(s)
[19:33:34] scan: audio 0x1: dca, rate=48000Hz, bitrate=1536000 English (DTS-HD MA) (5.1 ch)
[19:33:34] scan: audio 0x2: dca, rate=48000Hz, bitrate=1536000 English (DTS) (5.1 ch)
[19:33:34] scan: audio 0x3: ac3, rate=48000Hz, bitrate=192000 English (AC3) (2.0 ch) (Dolby Surround)
Scanning title 1 of 1, preview 1, 10.00 %[19:33:34] scan: preview 2
Scanning title 1 of 1, preview 2, 20.00 %[19:33:34] scan: preview 3
Scanning title 1 of 1, preview 3, 30.00 %[19:33:35] scan: preview 4
Scanning title 1 of 1, preview 4, 40.00 %[19:33:35] scan: preview 5
Scanning title 1 of 1, preview 5, 50.00 %[19:33:35] scan: preview 6
Scanning title 1 of 1, preview 6, 60.00 %[19:33:35] scan: preview 7
Scanning title 1 of 1, preview 7, 70.00 %[19:33:36] scan: preview 8
Scanning title 1 of 1, preview 8, 80.00 %[19:33:36] scan: preview 9
Scanning title 1 of 1, preview 9, 90.00 %[19:33:36] scan: preview 10
Scanning title 1 of 1, preview 10, 100.00 %[19:33:36] scan: 10 previews, 1920x1080, 23.976 fps, autocrop = 132/132/0/0, aspect 16:9, PAR 1:1
[19:33:36] Freed 1 buffers of size 1024
[19:33:36] Freed 1 buffers of size 2048
[19:33:36] Freed 1 buffers of size 4096
[19:33:36] Freed 1 buffers of size 8192
[19:33:36] Freed 1 buffers of size 16384
[19:33:36] Freed 1 buffers of size 65536
[19:33:36] Freed 1 buffers of size 131072
[19:33:36] Freed 1 buffers of size 262144
[19:33:36] Freed 1 buffers of size 524288
[19:33:36] Freed 1 buffers of size 4194304
[19:33:36] Allocated 5209088 bytes of buffers on this pass and Freed 5209088 bytes, 0 bytes leaked
[19:33:36] thread 215eda0 exited ("scan")
[19:33:36] thread 215eda0 joined ("scan")
[19:33:36] libhb: scan thread found 1 valid title(s)
+ title 1:
  + stream: C:\30\The_Bourne_Identity_t00.mkv
  + duration: 01:58:17
  + size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 23.976 fps
  + autocrop: 132/132/0/0
  + support opencl: yes
  + support hwd: no
  + chapters:
    + 1: cells 0->0, 0 blocks, duration 00:06:28
    + 2: cells 0->0, 0 blocks, duration 00:02:07
    + 3: cells 0->0, 0 blocks, duration 00:03:04
    + 4: cells 0->0, 0 blocks, duration 00:01:59
    + 5: cells 0->0, 0 blocks, duration 00:06:05
    + 6: cells 0->0, 0 blocks, duration 00:05:58
    + 7: cells 0->0, 0 blocks, duration 00:03:34
    + 8: cells 0->0, 0 blocks, duration 00:07:21
    + 9: cells 0->0, 0 blocks, duration 00:07:20
    + 10: cells 0->0, 0 blocks, duration 00:04:31
    + 11: cells 0->0, 0 blocks, duration 00:03:24
    + 12: cells 0->0, 0 blocks, duration 00:10:09
    + 13: cells 0->0, 0 blocks, duration 00:08:00
    + 14: cells 0->0, 0 blocks, duration 00:08:44
    + 15: cells 0->0, 0 blocks, duration 00:05:15
    + 16: cells 0->0, 0 blocks, duration 00:07:41
    + 17: cells 0->0, 0 blocks, duration 00:06:59
    + 18: cells 0->0, 0 blocks, duration 00:06:34
    + 19: cells 0->0, 0 blocks, duration 00:06:21
    + 20: cells 0->0, 0 blocks, duration 00:06:44
  + audio tracks:
    + 1, English (DTS-HD MA) (5.1 ch) (iso639-2: eng)
    + 2, English (DTS) (5.1 ch) (iso639-2: eng), 48000Hz, 1536000bps
    + 3, English (AC3) (2.0 ch) (Dolby Surround) (iso639-2: eng), 48000Hz, 192000bps
  + subtitle tracks:
    + 1, English (iso639-2: eng) (Bitmap)(PGS)
Reading chapter markers from file C:\Users\Jeff\AppData\Local\Temp\The Bourne Identity DTS HB-1-chapters.csv
[19:33:36] thread 215eda0 started ("work")
[19:33:36] 1 job(s) to process
[19:33:36] starting job
[19:33:36] sync: expecting 11506 video frames
[19:33:36] work: only 1 chapter, disabling chapter markers
[19:33:36] job configuration:
[19:33:36]  * source
[19:33:36]    + C:\30\The_Bourne_Identity_t00.mkv
[19:33:36]    + title 1, chapter(s) 13 to 13
[19:33:36]    + container: matroska,webm
[19:33:36]  * destination
[19:33:36]    + C:\01\The Bourne Identity DTS HB.mkv
[19:33:36]    + container: Matroska (libavformat)
[19:33:36]  * video track
[19:33:36]    + decoder: vc1
[19:33:36]    + filters
[19:33:36]      + Framerate Shaper (0:27000000:1126125)
[19:33:36]        + frame rate: same as source (around 23.976 fps)
[19:33:36]      + Crop and Scale (1920:816:132:132:0:0)
[19:33:36]        + source: 1920 * 1080, crop (132/132/0/0): 1920 * 816, scale: 1920 * 816
[19:33:36]    + loose anamorphic
[19:33:36]      + storage dimensions: 1920 * 816, mod 2
[19:33:36]      + pixel aspect ratio: 1 / 1
[19:33:36]      + display dimensions: 1920 * 816
[19:33:36]    + encoder: H.264 (libx264)
[19:33:36]      + preset:  ultrafast
[19:33:36]      + profile: main
[19:33:36]      + level:   3.2
[19:33:36]      + quality: 51.00 (RF)
[19:33:36]  * audio track 1
[19:33:36]    + decoder: English (DTS-HD MA) (5.1 ch) (track 1, id 0x1)
[19:33:36]      + bitrate: 1536 kbps, samplerate: 48000 Hz
[19:33:36]    + mixdown: Stereo
[19:33:36]    + encoder: AAC (libavcodec)
[19:33:36]      + bitrate: 448 kbps, samplerate: 48000 Hz
[19:33:36]  * audio track 2
[19:33:36]    + encoder: AC3 (libavcodec)
[19:33:36]      + bitrate: 640 kbps, samplerate: 48000 Hz
[19:33:36]  * audio track 3
[19:33:36]    + mixdown: 5.1 Channels
[19:33:36] thread 59729a0 started ("Reader")
[19:33:36] thread 5972180 started ("Framerate Shaper")
[19:33:36] Seeking to chapter 13: starts 334920836, ends 378115237, AV pos 3721342622
[19:33:36] thread 5972320 started ("Crop and Scale")
[19:33:36] thread 59724c0 started ("AudioSynchronization")
[19:33:36] thread 598e250 started ("AudioSynchronization")
[19:33:36] thread 598fab0 started ("AudioSynchronization")
[19:33:36] thread 598e3f0 started ("Video decoder (libavcodec)")
[19:33:36] encx264: min-keyint: 24, keyint: 240
[19:33:36] encx264: encoding at constant RF 51.000000
[19:33:36] hb_apply_h264_level [warning]: frame size (1920x816, 6120 macroblocks) too high for level 3.2 (max. 5120 macroblocks)
[19:33:36] encx264: unparsed options: level=3.2:ref=1:scenecut=0:bframes=0:no-deblock=1:cabac=0:analyse=none:8x8dct=0:weightp=0:me=dia:subme=0:mixed-refs=0:trellis=0:vbv-bufsize=20000:vbv-maxrate=20000:aq-mode=0:mbtree=0:rc-lookahead=0
[19:33:36] encx264: opening libx264 (pass 0)
x264 [info]: using SAR=1/1
x264 [warning]: frame MB size (120x51) > level limit (5120)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2
x264 [info]: profile Constrained Baseline, level 3.2
[19:33:36] thread 598e730 started ("H.264/AVC encoder (libx264)")
[19:33:36] reader: first SCR 334920870 id 0x0 DTS 334920870
[19:33:36] thread 598e590 started ("Audio decoder (libavcodec)")
[19:33:36] thread 598ff90 started ("AVCodec Audio encoder (libavcodec)")
[19:33:36] thread 598f0f0 started ("Audio decoder (libavcodec)")
[19:33:36] thread 598e8d0 started ("AVCodec Audio encoder (libavcodec)")
[19:33:36] thread 598ec10 started ("Audio decoder (libavcodec)")
[19:33:36] thread 598edb0 started ("AVCodec Audio encoder (libavcodec)")
[19:33:36] thread 598ef50 started ("Video Synchronization")
[19:33:36] Writing Metadata to output file...
[19:33:36] thread 598f430 started ("Muxer")
[19:33:36] thread 598f5d0 started ("Muxer")
[19:33:36] thread 598fdf0 started ("Muxer")
[dca @ 0000000005c63480] Overread auxiliary data by 32 bits
[dca @ 0000000005c63480] error decoding block
[dca @ 0000000005c66960] Overread auxiliary data by 32 bits
[dca @ 0000000005c66960] error decoding block
[dca @ 0000000005c65d20] Overread auxiliary data by 32 bits
[dca @ 0000000005c65d20] error decoding block
[19:43:09] ffmpeg_read starting chapter 14 at 378118980
[19:43:09] reader: end of chapter 13 (media 13) reached at media chapter 14
[19:43:09] reader: done. 1 scr changes
[19:43:09] thread 59729a0 exited ("Reader")
[19:43:11] work: average encoding speed for job is 20.053877 fps
[19:43:11] thread 598ef50 exited ("Video Synchronization")
[19:43:11] thread 598e3f0 exited ("Video decoder (libavcodec)")
[19:43:11] thread 598ef50 joined ("Video Synchronization")
[19:43:11] sync: got 11508 frames, 11506 expected
[19:43:11] thread 598e730 exited ("H.264/AVC encoder (libx264)")
[19:43:11] thread 5972180 exited ("Framerate Shaper")
[19:43:11] thread 5972180 joined ("Framerate Shaper")
[19:43:11] render: lost time: 0 (0 frames)
[19:43:11] render: gained time: 0 (0 frames) (0 not accounted for)
[19:43:11] fifo_close: trashing 0 buffer(s)
[19:43:11] thread 598fdf0 exited ("Muxer")
[19:43:11] thread 598edb0 exited ("AVCodec Audio encoder (libavcodec)")
[19:43:11] thread 598f5d0 exited ("Muxer")
[19:43:11] thread 598fab0 exited ("AudioSynchronization")
[19:43:11] thread 598e8d0 exited ("AVCodec Audio encoder (libavcodec)")
[19:43:11] thread 598ec10 exited ("Audio decoder (libavcodec)")
[19:43:11] thread 598e250 exited ("AudioSynchronization")
[19:43:11] thread 598f430 exited ("Muxer")
[19:43:11] thread 598f0f0 exited ("Audio decoder (libavcodec)")
[19:43:11] thread 598ff90 exited ("AVCodec Audio encoder (libavcodec)")
[19:43:11] thread 59724c0 exited ("AudioSynchronization")
[19:43:11] thread 598e590 exited ("Audio decoder (libavcodec)")
[19:43:11] thread 5972320 exited ("Crop and Scale")
[19:43:11] thread 5972320 joined ("Crop and Scale")
[19:43:11] thread 59724c0 joined ("AudioSynchronization")
[19:43:11] thread 598e250 joined ("AudioSynchronization")
[19:43:11] thread 598fab0 joined ("AudioSynchronization")
[19:43:11] thread 598e3f0 joined ("Video decoder (libavcodec)")
[19:43:11] vc1-decoder done: 11508 frames, 1 decoder errors, 0 drops
[19:43:11] thread 598e730 joined ("H.264/AVC encoder (libx264)")
x264 [info]: frame I:48    Avg QP:48.15  size:  5972
x264 [info]: frame P:11460 Avg QP:50.84  size:   519
x264 [info]: mb I  I16..4: 100.0%  0.0%  0.0%
x264 [info]: mb P  I16..4:  2.7%  0.0%  0.0%  P16..4:  1.1%  0.0%  0.0%  0.0%  0.0%    skip:96.2%
x264 [info]: coded y,uvDC,uvAC intra: 0.2% 13.7% 0.1% inter: 0.0% 0.2% 0.0%
x264 [info]: i16 v,h,dc,p: 61% 24% 10%  5%
x264 [info]: i8c dc,h,v,p: 94%  3%  4%  0%
x264 [info]: kb/s:103.82
[19:43:11] thread 598e590 joined ("Audio decoder (libavcodec)")
[19:43:11] dca-decoder done: 0 frames, 0 decoder errors, 0 drops
[19:43:11] thread 598ff90 joined ("AVCodec Audio encoder (libavcodec)")
[19:43:11] encavcodeca: closing libavcodec
[19:43:11] thread 598f0f0 joined ("Audio decoder (libavcodec)")
[19:43:11] thread 598e8d0 joined ("AVCodec Audio encoder (libavcodec)")
[19:43:11] thread 598ec10 joined ("Audio decoder (libavcodec)")
[19:43:11] thread 598edb0 joined ("AVCodec Audio encoder (libavcodec)")
[19:43:11] thread 598f430 joined ("Muxer")
[19:43:11] thread 598f5d0 joined ("Muxer")
[19:43:11] thread 598fdf0 joined ("Muxer")
[19:43:11] mux: file size, 109117626 bytes
[19:43:11] mux: track 0, 11508 frames, 6227454 bytes, 103.79 kbps, fifo 2048
[19:43:11] mux: track 1, 22500 frames, 25634905 bytes, 427.23 kbps, fifo 4096
[19:43:11] mux: track 2, 15001 frames, 38402560 bytes, 640.01 kbps, fifo 2048
[19:43:11] mux: track 3, 15001 frames, 38402560 bytes, 640.01 kbps, fifo 2048
[19:43:11] mux: overhead, 7.03 bytes per frame
[19:43:11] thread 59729a0 joined ("Reader")
[19:43:11] Freed 320 buffers of size 1024
[19:43:11] Freed 32 buffers of size 2048
[19:43:11] Freed 32 buffers of size 4096
[19:43:11] Freed 32 buffers of size 8192
[19:43:11] Freed 29 buffers of size 16384
[19:43:11] Freed 21 buffers of size 32768
[19:43:11] Freed 23 buffers of size 65536
[19:43:11] Freed 22 buffers of size 131072
[19:43:11] Freed 31 buffers of size 262144
[19:43:11] Freed 17 buffers of size 524288
[19:43:11] Freed 1 buffers of size 1048576
[19:43:11] Freed 32 buffers of size 4194304
[19:43:11] Allocated 158646272 bytes of buffers on this pass and Freed 158646272 bytes, 0 bytes leaked
[19:43:11] thread 215eda0 exited ("work")
[19:43:11] thread 215eda0 joined ("work")
[19:43:11] libhb: work result = 0
Encode done!
[19:43:11] thread 215c4c0 exited ("libhb")
[19:43:11] thread 215c4c0 joined ("libhb")
HandBrake has exited.
Bourne 2 MakeMKV 1.9.9 log
Debug log started at Tue Feb 09 21:50:24 2016 , written by MakeMKV v1.9.9 win(x64-release)
DCE=MuGX5E2jPzpT9BLDSvyEAH0Onm+stZkMls4cK40ClyfSEwKoNz7K9VKpZOk1YPIjuw6yfSFfGdBv4Q+VT2B/QAuU/v5HIVXu0hfd98aaGUbSGOanzg2YsJLcE3VyNwEKMtkhPdVOiTspJp3s1lT8iH+qIqkIci6F1g==
DCE=Aqikik5R7tbI+sLMLBmWeRh/12zOq0LrbESyIp8FcMocUrv2dJM7E4SfPhWzIv8BR/ZufdPu44J/i193yGjFvBHX1kz4UUfdH+LJmuVevcgL6NqbOFvz/EuNUbKHLmAFU4zILC9EYdEHnHSEGZOGylx9aqwK9SEv2A==
DISCID=8AFA444CCD38F1C8AA29F49FD76F2978BED6D47B
003307:0000 File 00061.mpls was added as title #3
003307:0000 File 00062.mpls was added as title #4
003307:0000 File 00063.mpls was added as title #5
003307:0000 File 00064.mpls was added as title #6
003307:0000 File 00065.mpls was added as title #7
003307:0000 File 00066.mpls was added as title #8
003307:0000 File 00067.mpls was added as title #9
003307:0000 File 00068.mpls was added as title #10
003307:0000 File 00586.mpls was added as title #11
003307:0000 File 00002.m2ts was added as title #12
003307:0000 File 00010.m2ts was added as title #13
003307:0000 File 00011.m2ts was added as title #14
003307:0000 File 00012.m2ts was added as title #15
003307:0000 File 00013.m2ts was added as title #16
003307:0000 File 00050.m2ts was added as title #17
003307:0000 File 00056.m2ts was added as title #18
003307:0000 File 00060.m2ts was added as title #19
003307:0000 File 00061.m2ts was added as title #20
003307:0000 File 00062.m2ts was added as title #21
003307:0000 File 00063.m2ts was added as title #22
003307:0000 File 00064.m2ts was added as title #23
003307:0000 File 00065.m2ts was added as title #24
003307:0000 File 00066.m2ts was added as title #25
003307:0000 File 00067.m2ts was added as title #26
003307:0000 File 00068.m2ts was added as title #27
003307:0000 File 00069.m2ts was added as title #28
003307:0000 File 00070.m2ts was added as title #29
003307:0000 File 00071.m2ts was added as title #30
003307:0000 File 00072.m2ts was added as title #31
003307:0000 File 00073.m2ts was added as title #32
003307:0000 File 00074.m2ts was added as title #33
003307:0000 File 00075.m2ts was added as title #34
003309:0000 Title 00077.m2ts is equal to title 00061.mpls and was skipped
003309:0000 Title 00078.m2ts is equal to title 00062.mpls and was skipped
003309:0000 Title 00079.m2ts is equal to title 00063.mpls and was skipped
003309:0000 Title 00080.m2ts is equal to title 00064.mpls and was skipped
003309:0000 Title 00081.m2ts is equal to title 00065.mpls and was skipped
003309:0000 Title 00082.m2ts is equal to title 00066.mpls and was skipped
003309:0000 Title 00083.m2ts is equal to title 00067.mpls and was skipped
003309:0000 Title 00084.m2ts is equal to title 00068.mpls and was skipped
003307:0000 File 00346.m2ts was added as title #35
003307:0000 File 00347.m2ts was added as title #36
003307:0000 File 00348.m2ts was added as title #37
003307:0000 File 00349.m2ts was added as title #38
003307:0000 File 00350.m2ts was added as title #39
005014:0000 Saving 1 titles into directory C:/31
Application exited at Tue Feb 09 22:31:22 2016
Bourne 3 MakeMKV 1.9.9 log
Debug log started at Tue Feb 09 22:32:09 2016 , written by MakeMKV v1.9.9 win(x64-release)
DCE=pfql4G9RqIwDnsPJ5G6O7xaDR82BDgREynHeKeXqWHP3z/NFofnsoODjqfG3uvouJGYkpENE3K4Ida3HXgV1/412qOpbKB2FH8qh8LcuAyWy8Mr5BfpfaMpMZlLRMeO/ugZtlTu9rbQAMExBdxlPP/t0Q0HTsU4BYA==
DCE=an+QFsDlYdfvLcwDuz0rT4rK1l18QqXwhWAi+kBFZYbbo/bX5QIEjK0vzY1qdgjyIZaMMfE2cBGKml94+SMUAXk7eO+clLV7xDkmzcdxDTJMikHB8iYl9j4xLyNvWbLsqp0I/0FE+1d5SYE9+igfrHkB/vupzI4CTQ==
DISCID=E15DE3EAA7F69CDADDBB91B7C4B7A62645B53293
003307:0000 File 00051.mpls was added as title #3
003309:0000 Title 00559.mpls is equal to title 00000.mpls and was skipped
003307:0000 File 00061.mpls was added as title #4
003307:0000 File 00062.mpls was added as title #5
003307:0000 File 00063.mpls was added as title #6
003307:0000 File 00064.mpls was added as title #7
003307:0000 File 00065.mpls was added as title #8
003307:0000 File 00066.mpls was added as title #9
003307:0000 File 00067.mpls was added as title #10
003307:0000 File 00068.mpls was added as title #11
003307:0000 File 00586.mpls was added as title #12
003307:0000 File 00002.m2ts was added as title #13
003307:0000 File 00010.m2ts was added as title #14
003307:0000 File 00011.m2ts was added as title #15
003307:0000 File 00063.m2ts was added as title #23
003307:0000 File 00064.m2ts was added as title #24
003307:0000 File 00065.m2ts was added as title #25
003307:0000 File 00066.m2ts was added as title #26
003307:0000 File 00067.m2ts was added as title #27
003307:0000 File 00068.m2ts was added as title #28
003307:0000 File 00069.m2ts was added as title #29
003307:0000 File 00070.m2ts was added as title #30
003307:0000 File 00071.m2ts was added as title #31
003307:0000 File 00072.m2ts was added as title #32
003307:0000 File 00073.m2ts was added as title #33
003309:0000 Title 00075.m2ts is equal to title 00061.mpls and was skipped
003309:0000 Title 00076.m2ts is equal to title 00062.mpls and was skipped
003309:0000 Title 00077.m2ts is equal to title 00063.mpls and was skipped
003309:0000 Title 00078.m2ts is equal to title 00064.mpls and was skipped
003309:0000 Title 00079.m2ts is equal to title 00065.mpls and was skipped
003309:0000 Title 00080.m2ts is equal to title 00066.mpls and was skipped
003309:0000 Title 00081.m2ts is equal to title 00067.mpls and was skipped
003309:0000 Title 00082.m2ts is equal to title 00068.mpls and was skipped
003307:0000 File 00345.m2ts was added as title #34
003025:0000 Title #00350.m2ts has length of 3 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00351.m2ts has length of 2 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00352.m2ts has length of 3 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00353.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00354.m2ts has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00355.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00356.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00357.m2ts has length of 2 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00360.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00362.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00363.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00364.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00365.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00366.m2ts has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00368.m2ts has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00369.m2ts has length of 3 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00370.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/32
Application exited at Tue Feb 09 23:02:55 2016
DVD rip
Debug log started at Wed Feb 10 12:42:54 2016 , written by MakeMKV v1.9.9 win(x64-release)
003028:0000 Title #1 was added (16 cell(s), 1:41:42)
003028:0000 Title #2 was added (1 cell(s), 0:02:35)
003032:0000 Region setting of drive HL-DT-ST:BDDVDRW CP50NS20 does not match the region of currently inserted disc, trying to work around...
DEBUG: Code 0 at |tkt#-Oit[C]HqNk5:213130306
DEBUG: Code 0 at |tkt#-Oit[C]HqNk5:121265062
005014:0000 Saving 2 titles into directory C:/45
005005:0080 2 titles saved
005036:0104 Copy complete. 2 titles saved.
Application exited at Wed Feb 10 13:06:42 2016
All 1.9.8 logs
https://www.dropbox.com/s/gsoptfadotsoa ... s.zip?dl=0
Ripman
Re: BD Drive problem after 1.9.8/9 upgrade
Post by Ripman » Thu Feb 11, 2016 2:11 am
Ok, I am thinking that my BD drive is now "bricked" - at least to some extent (e.g., I can process BDs, but MakeMKV gives debug messages).
Is it reasonable to assume that I could have prevented this by upgrading to 1.9.8 before inserting an aacs v57 BD?
Going back to 1/6, I do have the mkb archive file that MakeMKV created, so I'll send that tomorrow.
Thanks again.
Post by Woodstock » Thu Feb 11, 2016 5:07 am
If the AACS version killed it, there should be a message in the log... which get overwritten with each start of the program. :roll:
An un-handled version of AACS would make the drive ignore any BD put in it, until it is given an AACS key that hasn't been revoked. But your logs are not consistent with AACS being the culprit.
Version 57 of AACS needs MakeMKV 1.9.7 and later. V58 bumps that to needing 1.9.9. If there is a newer version disk out there, you should have a .tgz file from when the disk was loaded by MakeMKV, with a name like "MKB_vNN_" and the name of the disk. If so, forward that file to svq@makemkv.com so that Mike can look at it.
Ripman
Post by Ripman » Fri Feb 12, 2016 12:00 am
I am kind of with you Woodstock - thanks for responding. It's not a totally bricked drive, and yet, it seems a suspect newer BD may have triggered things. Kinda funny considering the BD is a hundred year-old movie.
I sent the mkb v57 file to support. I also sent a v53 that got generated for a different CR BD.
My 2 approaches are: 1. wait for a new makemkv release; and 2. buy a new drive. I'll wait a few weeks to see if a new release helps.
Right now, my bigger concern would be the January rips - in other words, even though I got debug messages, are my mkv files clean?
Post by Woodstock » Fri Feb 12, 2016 3:33 am
One of the problems with AACS, though, is that you don't have to try ripping a movie for it to revoke the MakeMKV key... Just loading it in the drive will update the firmware copy of the AACS revoked keys table, and all access to AACS-protected BDs stops until the key is updated. Although I doubt that would happen unnoticed with most of us, since the first time a disk goes into the drive is to rip it!
It's definitely going to be on a disk issued in the last 4 months, regardless of when the movie was made. v57 was just coming up in October, and v58 in December. And since MakeMKV changed keys in January, the studios would not have had time to update AACS and get a disk to market by now.
Ripman
Post by Ripman » Mon Feb 22, 2016 2:49 pm
My op described a problem I've been having w certain BDs that have dts tracks. My list of BDs that give dts decoding errors follows: Bourne trilogy box; casino target steel book, & the conversation.
In the op and subsequent posts I thought that maybe my drive was partially bricked. I sent aacs v57 logs to the admin, & Woodstock offered insights. From my perspective, a new makemkv release may help.
Reading through past release notes, I wonder if the problem I am having is related to the dts decoder update in 1.9.5?
Ripman
Post by Ripman » Mon Feb 29, 2016 4:18 pm
I downgraded to 1.9.4. That got rid of the debug messages in the makemkv logs. But dts deciding still gives errors in hb 10.2.
So I'll upgrade to hb 10.5 & see if that helps.
Ripman
Post by Ripman » Tue Mar 01, 2016 3:15 pm
I ran the 5 "problem" BDs through 1.9.4 & then hb 10.5, and none had the dts decoding error. There is a weird sub track in the casino mkv that vlc doesn't recognize, so I'll investigate that when I can.
I'll retry the whole process w 1.9.9 when I finish the 1.9.4 testing.
Post by mike admin » Mon Mar 07, 2016 1:40 pm
If you are decoding DST with MakeMKV - MakeMKV changed the DST decoder from "dll hack" to open-source libdca between 1.9.4 and 1.9.9 . The version in 1.9.9 should work flawlessly, 1.9.8 had some issues. If you are not transcoding DTS with MakeMKV and only save as is - results should be identical.
Ripman
Post by Ripman » Fri Mar 25, 2016 12:45 am
I upgraded again to makemkv 1.9.9. I also upgraded handbrake from 0.10.2 to 0.10.5. This solved the "auxiliary over read " dts decoder error I was getting in hb. All BDs I posted having dts errors in hb have been successfully processed in 1.9.9 & 0.10.5 (e.g., casino steel book). I also successfully processed some new ones: all the president's men, Jurassic park vc1 2d, 7% solution...
In summary, the new dts code starting in makemkv 1.9.5 and in the most recent 1.9.9 was giving "auxiliary over read" errors with at least hb 0.10.2. The problem can be resolved by upgrading to hb 0.10.5. I did not try hb 0.10.3, and there is no 10.4.
The debug messages I was getting in makemkv 1.9.9 are probably caused by makemkv accessing my drives in a different way, or the drives not responding as makemkv expects. Either way, this seems to be a "red herring" that has no effect on creating successful rips.
Thanks for responding Woodstock & Mike.
Romansh
Post by Romansh » Wed Mar 30, 2016 2:31 pm
Ripman wrote:In summary, the new dts code starting in makemkv 1.9.5 and in the most recent 1.9.9 was giving "auxiliary over read" errors with at least hb 0.10.2. The problem can be resolved by upgrading to hb 0.10.5. I did not try hb 0.10.3, and there is no 10.4.
FWIW, it was never a MakeMKV issue, regardless of version.
The issue was in newer versions of the libavcodec DTS decoder. When I implemented support for additional metadata (embedded 5.1 -> stereo downmix coefficients), I also checked for over-reads via a length field described ion the specification, field which turned out to be unreliable/useless.
The real bug is in a DTS encoder somewhere (or arguably in the specification), but since enough real-world content is affected, the libavcodec decoder no longer checks for over-reads of this particular metadata segment.
