Hi Mike!
I have an issue with the BluRay 'Manon'! It's not possible to save it to disc! Could you please help?
Logs and Infos are attached!
Best regards
H
Failed to save title from BluRay 'Manon'
setarip_old
Re: Failed to save title from BluRay 'Manon'
@Helios61
Hi!
1) Is this the November 2008 BluRay release of "Manon"?
2) There is no information in your log. Did you put a checkmark next to "Log debug messages" under "Preferences"
3) Examine the disc for either physical damage or dirt/grease/fingerprints/peanut butter and jelly, etc.
4) Can you play the original disc on your PC?
Hi!
Hi setarip_old!
Big Thanks for your reply!
This one -> http://www.amazon.de/Jules-Massenet-Blu ... 766&sr=8-8
ups, sorry, will send a new one later!
It's not a physical disc, it's folderstructure!
Playback of the .m2ts - file is working fine!
setarip_old wrote:@Helios61
Hi!
setarip_old wrote:2) There is no information in your log. Did you put a checkmark next to "Log debug messages" under "Preferences"
setarip_old wrote:3) Examine the disc for either physical damage or dirt/grease/fingerprints/peanut butter and jelly, etc.
setarip_old wrote:4) Can you play the original disc on your PC?
New Logfile also added to first posting:
Debug log started at Sun Apr 18 09:54:25 2010 , written by MakeMKV v1.5.4 beta win(x86-release)
001005:0000 MakeMKV v1.5.4 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Michael/MakeMKV_log.txt
003006:0000 Opening files on harddrive at L:/Manon/
003305:0000 AACS directory not present, assuming unencrypted disc
003307:0000 File 00001.mpls was added as title #0
003025:0000 Title #00001.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00007.m2ts was added as title #1
003307:0000 File 00008.m2ts was added as title #2
003307:0000 File 00009.m2ts was added as title #3
003307:0000 File 00010.m2ts was added as title #4
003025:0000 Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory L:/
001003:0020 DEBUG: Code 0 at j,*WXH2-WeDric:121267063
001003:0020 DEBUG: Code 0 at <%`LM&{AQa"(&W|.a2F1:213133457
001003:0020 DEBUG: Code 0 at ^4&\sXm#;v+5Jct;!?y@r:29397449
001003:0020 DEBUG: Code 0 at ADd;tmo&s|'B-U<zl]q:29395379
001003:0020 DEBUG: Code 25 at <%`LM&{AQa"(&W|.a2F1:213133181
FS ID=<FAILED> C=0
005003:0000 Failed to save title 0 to file L://title00.mkv
005004:0000 0 titles saved, 1 failed
setarip_old
I believe this is indicative of a bad rip (Despite the fact that the .M2TS file plays from your hard drive).
Try re-ripping your original, commercial BluRay disc...
- Contact:
The error log indicates a badly encoded h264 stream. The next program version might correct the problem.
Thanks again
H
I think, you are right! I have tried it with DSMux and the .mkv file was not working!mike admin wrote:The error log indicates a badly encoded h264 stream. The next program version might correct the problem.
Thanks again
H
