dvd made into separate chapters instead of one file
my dvd is being saved as many separate files instead of one title. what can i do?
Re: dvd made into separate chapters instead of one file
That depends upon the disk.
Let's start with a log of what is going on. The FAQ link in my signature tells you how to turn logging on. At the very least, the "scan" portion of opening the disk is necessary, to see what MakeMKV has to work with.
MakeMKV v1.9.9 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/marnialtman/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HE13d" opened in OS access mode.
Cells 36-end were skipped due to cell commands (structure protection?)
Title #1 was added (35 cell(s), 0:30:25)
Cells 4-end were skipped due to cell commands (structure protection?)
Title #2 was added (3 cell(s), 0:02:04)
Cells 7-end were skipped due to cell commands (structure protection?)
Title #2/0/1 was added (3 cell(s), 0:02:25)
Cells 11-end were skipped due to cell commands (structure protection?)
Title #2/0/2 was added (4 cell(s), 0:02:18)
Cells 14-end were skipped due to cell commands (structure protection?)
Title #2/0/3 was added (3 cell(s), 0:03:08)
Cells 19-end were skipped due to cell commands (structure protection?)
Title #2/0/4 was added (5 cell(s), 0:03:10)
Cells 22-end were skipped due to cell commands (structure protection?)
Title #2/0/5 was added (3 cell(s), 0:02:23)
Cells 26-end were skipped due to cell commands (structure protection?)
Title #2/0/6 was added (4 cell(s), 0:03:49)
Cells 30-end were skipped due to cell commands (structure protection?)
Title #2/0/7 was added (4 cell(s), 0:02:58)
Cells 34-end were skipped due to cell commands (structure protection?)
Title #2/0/8 was added (4 cell(s), 0:03:49)
Cells 35-end were skipped due to cell commands (structure protection?)
Title #2/0/9 was added (1 cell(s), 0:03:50)
Cells 3-end were skipped due to cell commands (structure protection?)
Title #3 was added (2 cell(s), 0:05:34)
Cells 5-end were skipped due to cell commands (structure protection?)
Title #4 was added (4 cell(s), 0:06:37)
Cells 9-end were skipped due to cell commands (structure protection?)
Title #5 was added (8 cell(s), 0:11:14)
Title #6 was added (6 cell(s), 0:02:21)
Cells 15-end were skipped due to cell commands (structure protection?)
Title #7 was added (14 cell(s), 0:04:08)
Title #8 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation successfully comple
It looks like title #1 is the "play all" option, and titles with #2 in them are the pieces that make up title #1.
Did you select all titles to rip, or did you exclude some of them?
oh! you are right that one title is the whole movie. thanks SO much for getting back to me so quick really appreciate it so much
Pale Rider
Odd, I am experiencing the same behavior. Previously, MakeMKV would always save my selected files into a single output file. Today, it broke my new Salt disc selection into 6 different files; I have the BluRay with the theatrical, extended, and director's cuts; I selected only the director's cut to rip. I haven't tried deleting five of them to see if what appears to be the main one will play by itself, but I will [have now done so, and it plays, so what is the point of all that?]. Thanks, and here is the log:
Debug log started at Fri Jan 22 15:35:57 2016 , written by MakeMKV v1.9.9 darwin(x86-release)
001005:0000 MakeMKV v1.9.9 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/~/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-XU03 1.02d" opened in OS access mode.
DEBUG: Code 2147483648 at N;KX^Rl4<!Ze}Fh<:121265315
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=5LVRaWzMYKkt/lriBGABgKN6NWlSqXZVwXh8yj4Ai+tdUC/ywgEsDN1k3xtYopbB41+DUC3XbZIpOgDMCms6hfWehzwH1tPMgcAraaH/sGWPiLIHgWSlzhMOGxqV1TWOga4tOaGt4qICOTu42CEguZqENcywSQqtng==
DCE=0SlCzlKLtG5oTuDRGHCeZzqUY0UXFZXA4+tlolm/LF7t/+KRMzrKgr4tVY57B0le3Xc0uV7KNhbjvgcsIQZ1olaewTtcZqUANgeLw3MrsGeTh0pp3HRZP9RwaSEVcokB2l6oS3r3MMIVzmkKVxnWuoEMeNAaCRMdQA==
DISCID=8166065F235F792B0855AC2D7337012182F62DFD
003025:0000 Title #00102.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00095.mpls has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00096.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00004.mpls was added as title #1
003307:0000 File 00002.mpls was added as title #2
003307:0000 File 00003.mpls was added as title #3
003025:0000 Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00105.m2ts was added as title #4
003307:0000 File 00106.m2ts was added as title #5
003307:0000 File 00107.m2ts was added as title #6
003307:0000 File 00108.m2ts was added as title #7
003307:0000 File 00109.m2ts was added as title #8
003307:0000 File 00110.m2ts was added as title #9
003307:0000 File 00111.m2ts was added as title #10
003025:0000 Title #00162.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00163.m2ts was added as title #11
003307:0000 File 00164.m2ts was added as title #12
003025:0000 Title #00165.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00166.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00167.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00168.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00169.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00170.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00140.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00114.m2ts was added as title #13
003025:0000 Title #00115.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00116.m2ts was added as title #14
003025:0000 Title #00117.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00118.m2ts was added as title #15
003025:0000 Title #00119.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00120.m2ts was added as title #16
003025:0000 Title #00121.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00122.m2ts was added as title #17
003025:0000 Title #00123.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00124.m2ts was added as title #18
003025:0000 Title #00125.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00126.m2ts was added as title #19
003025:0000 Title #00127.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00128.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00129.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00130.m2ts was added as title #20
003307:0000 File 00131.m2ts was added as title #21
003307:0000 File 00132.m2ts was added as title #22
003025:0000 Title #00133.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00134.m2ts was added as title #23
003025:0000 Title #00135.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00136.m2ts was added as title #24
003025:0000 Title #00137.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00138.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00139.m2ts was added as title #25
003025:0000 Title #00143.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00144.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00145.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00146.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00147.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00148.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00149.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00150.m2ts was added as title #26
003025:0000 Title #00151.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00152.m2ts was added as title #27
003307:0000 File 00153.m2ts was added as title #28
003025:0000 Title #00154.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00155.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00156.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00157.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00158.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00159.m2ts was added as title #29
003307:0000 File 00160.m2ts was added as title #30
003309:0000 Title 00001.mpls is equal to title 00004.mpls and was skipped
005014:0000 Saving 6 titles into directory /Volumes/Areca/Blue Ray Video/Salt (Director's Cut)
AV sync issues in /Volumes/Areca/Blue Ray Video/Salt (Director's Cut)/Salt_t01.mkv
AV sync in 1,2 at 0:01:12.739 (7.333ms) : encountered overlapping frame, audio skew is +7.333ms
AV sync in 3 at 0:01:12.739 (28.666ms) : encountered overlapping frame, audio skew is +28.666ms
AV sync in 1,2 at 0:02:05.166 (9.958ms) : encountered overlapping frame, audio skew is +17.291ms
AV sync in 1,2 at 0:02:05.184 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +6.625ms
AV sync in 3 at 0:02:05.166 (20.625ms) : encountered overlapping frame, audio skew is +49.291ms
AV sync in 3 at 0:02:05.216 (32ms) : 1 frame(s) dropped to reduce audio skew to +17.291ms
AV sync in 1,2 at 0:12:39.967 (4.5ms) : encountered overlapping frame, audio skew is +11.125ms
AV sync in 1,2 at 0:12:39.978 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.458ms
AV sync in 3 at 0:12:39.967 (15.166ms) : encountered overlapping frame, audio skew is +32.458ms
AV sync in 3 at 0:12:40 (32ms) : 1 frame(s) dropped to reduce audio skew to +0.458ms
AV sync in 1,2,3 at 0:14:01.048 (7ms) : encountered overlapping frame, audio skew is +7.458ms
AV sync in 1,2,3 at 0:18:51.797 (3.208ms) : encountered overlapping frame, audio skew is +10.666ms
AV sync in 1,2 at 0:18:51.808 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync in 1,2 at 0:19:25.956 (6.208ms) : encountered overlapping frame, audio skew is +6.208ms
AV sync in 3 at 0:19:25.956 (16.875ms) : encountered overlapping frame, audio skew is +27.541ms
AV sync in 1,2 at 0:27:42.827 (3.291ms) : encountered overlapping frame, audio skew is +9.5ms
AV sync in 3 at 0:27:42.827 (24.625ms) : encountered overlapping frame, audio skew is +52.166ms
AV sync in 3 at 0:27:42.880 (32ms) : 1 frame(s) dropped to reduce audio skew to +20.166ms
AV sync in 1,2 at 0:28:03.306 (1.208ms) : encountered overlapping frame, audio skew is +10.708ms
AV sync in 1,2 at 0:28:03.317 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.041ms
AV sync in 3 at 0:28:03.306 (1.208ms) : encountered overlapping frame, audio skew is +21.375ms
AV sync in 1,2 at 0:30:30.912 (10.208ms) : encountered overlapping frame, audio skew is +10.25ms
AV sync in 3 at 0:30:30.912 (10.208ms) : encountered overlapping frame, audio skew is +31.583ms
AV sync in 1,2 at 0:32:18.019 (7.666ms) : encountered overlapping frame, audio skew is +17.916ms
AV sync in 1,2 at 0:32:18.037 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +7.25ms
AV sync in 3 at 0:32:18.019 (29ms) : encountered overlapping frame, audio skew is +60.583ms
AV sync in 3 at 0:32:18.080 (32ms) : 1 frame(s) dropped to reduce audio skew to +28.583ms
AV sync in 1,2 at 0:39:23.986 (6.125ms) : encountered overlapping frame, audio skew is +13.375ms
AV sync in 1,2 at 0:39:24 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +2.708ms
AV sync in 3 at 0:39:23.986 (16.791ms) : encountered overlapping frame, audio skew is +45.375ms
AV sync in 3 at 0:39:24.032 (32ms) : 1 frame(s) dropped to reduce audio skew to +13.375ms
AV sync in 1,2 at 0:40:00.272 (1.75ms) : encountered overlapping frame, audio skew is +4.458ms
AV sync in 3 at 0:40:00.272 (1.75ms) : encountered overlapping frame, audio skew is +15.125ms
AV sync in 1,2 at 0:43:31.692 (4.458ms) : encountered overlapping frame, audio skew is +8.916ms
AV sync in 3 at 0:43:31.692 (4.458ms) : encountered overlapping frame, audio skew is +19.583ms
AV sync in 1,2 at 0:45:10.749 (4.041ms) : encountered overlapping frame, audio skew is +12.958ms
AV sync in 1,2 at 0:45:10.762 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +2.291ms
AV sync in 3 at 0:45:10.749 (14.708ms) : encountered overlapping frame, audio skew is +34.291ms
AV sync in 3 at 0:45:10.784 (32ms) : 1 frame(s) dropped to reduce audio skew to +2.291ms
AV sync in 1,2 at 0:53:09.769 (9.125ms) : encountered overlapping frame, audio skew is +11.416ms
AV sync in 1,2 at 0:53:09.781 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.75ms
AV sync in 3 at 0:53:09.769 (19.791ms) : encountered overlapping frame, audio skew is +22.083ms
AV sync in 1,2 at 0:56:00.648 (0.958ms) : encountered overlapping frame, audio skew is +1.708ms
AV sync in 3 at 0:56:00.648 (0.958ms) : encountered overlapping frame, audio skew is +23.041ms
AV sync in 1,2 at 0:57:49.591 (7.166ms) : encountered overlapping frame, audio skew is +8.875ms
AV sync in 3 at 0:57:49.591 (17.833ms) : encountered overlapping frame, audio skew is +40.875ms
AV sync in 3 at 0:57:49.632 (32ms) : 1 frame(s) dropped to reduce audio skew to +8.875ms
AV sync in 1,2 at 0:59:36.447 (1.916ms) : encountered overlapping frame, audio skew is +10.791ms
AV sync in 1,2 at 0:59:36.458 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.125ms
AV sync in 3 at 0:59:36.447 (23.25ms) : encountered overlapping frame, audio skew is +32.125ms
AV sync in 3 at 0:59:36.480 (32ms) : 1 frame(s) dropped to reduce audio skew to +0.125ms
AV sync in 1,2 at 1:02:15.440 (5.166ms) : encountered overlapping frame, audio skew is +5.291ms
AV sync in 3 at 1:02:15.440 (15.833ms) : encountered overlapping frame, audio skew is +15.958ms
AV sync in 1,2 at 1:07:45.936 (9.833ms) : encountered overlapping frame, audio skew is +15.125ms
AV sync in 1,2 at 1:07:45.952 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +4.458ms
AV sync in 3 at 1:07:45.936 (31.166ms) : encountered overlapping frame, audio skew is +47.125ms
AV sync in 3 at 1:07:45.984 (32ms) : 1 frame(s) dropped to reduce audio skew to +15.125ms
AV sync in 1,2 at 1:12:01.233 (9.958ms) : encountered overlapping frame, audio skew is +14.416ms
AV sync in 1,2 at 1:12:01.248 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +3.75ms
AV sync in 3 at 1:12:01.233 (31.291ms) : encountered overlapping frame, audio skew is +46.416ms
AV sync in 3 at 1:12:01.280 (32ms) : 1 frame(s) dropped to reduce audio skew to +14.416ms
AV sync in 3 at 1:12:42.358 (27.583ms) : encountered overlapping frame, audio skew is +42ms
AV sync in 3 at 1:12:42.400 (32ms) : 1 frame(s) dropped to reduce audio skew to +10ms
AV sync in 1,2 at 1:12:42.358 (6.25ms) : encountered overlapping frame, audio skew is +10ms
AV sync in 1,2,3 at 1:19:35.061 (0.041ms) : encountered overlapping frame, audio skew is +10.041ms
AV sync in 1,2 at 1:20:52.639 (1.166ms) : encountered overlapping frame, audio skew is +11.208ms
AV sync in 1,2 at 1:20:52.650 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.541ms
AV sync in 3 at 1:20:52.639 (22.5ms) : encountered overlapping frame, audio skew is +32.541ms
AV sync in 3 at 1:20:52.672 (32ms) : 1 frame(s) dropped to reduce audio skew to +0.541ms
AV sync in 1,2,3 at 1:23:44.602 (4.541ms) : encountered overlapping frame, audio skew is +5.083ms
AV sync in 3 at 1:25:11.981 (13.041ms) : encountered overlapping frame, audio skew is +18.125ms
AV sync in 1,2 at 1:25:11.981 (2.375ms) : encountered overlapping frame, audio skew is +7.458ms
AV sync in 1,2 at 1:27:08.097 (1.333ms) : encountered overlapping frame, audio skew is +8.791ms
AV sync in 3 at 1:27:08.097 (12ms) : encountered overlapping frame, audio skew is +30.125ms
004001:0000 Forced subtitles track #7 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #13 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #15 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #9 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #11 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #17 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #19 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #21 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #23 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #25 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #27 turned out to be empty and was removed from output file
005005:0080 6 titles saved
005036:0104 Copy complete. 6 titles saved.
Pale Rider
Here is another from the Blu-ray of Robocop, from which MakeMKV extracted 19 separate files:
DCE=4yR/Gz2QANJ459FDKmTw4cs7GxFX1nSXcSVo37kj3kGNQWp94z0AmhSez4gi680hMf14YRgSTdTReu9wtlKImgUqAkPUh7QM8VTkl4w0qF2a/TP/zgZZHANgAeHwliTOzPZi8mlqMS9o2Td9XuYQ7wmJruq+dMLjpg==
DCE=CWfFNe0hysrY5V/QtvAGQ2t2DCRVbMw+EFPtbnWTwFzOiyfUC5Y4KNNkAJ+HhDeotl+HAvBcgtgEuclOlMUMKQCK3ACtW+qVr5FPiLAlzde0IBQlzlUQdPs/5n/tsHFziJbR6JBqRLbO2gxRqfeTv9fzLrFM4HAhWA==
003338:0000 Downloading latest SVQ(s) to /Users/~/Library/MakeMKV ...
003317:0000 Loaded 8 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 3 clip(s)
DISCID=1B4BD2D60072643387F891D31F3C58CC44B77700
003025:0000 Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00253.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00270.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00801.mpls was added as title #1
003309:0000 Title 00851.mpls is equal to title 00801.mpls and was skipped
003307:0000 File 00303.mpls was added as title #2
003307:0000 File 00383.mpls was added as title #3
003307:0000 File 00302.mpls was added as title #4
003307:0000 File 00382.mpls was added as title #5
003307:0000 File 00313.mpls was added as title #6
003307:0000 File 00393.mpls was added as title #7
003307:0000 File 00320.mpls was added as title #8
003307:0000 File 00398.mpls was added as title #9
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.m2ts was added as title #10
003025:0000 Title #00234.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00220.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00157.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00161.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00174.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00177.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00178.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00181.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00184.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00133.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01288.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01395.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01290.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01291.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01524.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01540.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01541.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01542.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01544.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01545.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01546.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01547.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01548.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01549.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01551.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01552.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01557.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01560.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01563.m2ts was added as title #11
003307:0000 File 01570.m2ts was added as title #12
003307:0000 File 01571.m2ts was added as title #13
003025:0000 Title #00021.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00302.m2ts was added as title #14
003307:0000 File 00303.m2ts was added as title #15
003307:0000 File 00304.m2ts was added as title #16
003025:0000 Title #00305.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00306.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00307.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00308.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00309.m2ts was added as title #17
003307:0000 File 00310.m2ts was added as title #18
003025:0000 Title #00312.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01564.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01565.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01566.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01567.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01568.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 19 titles into directory /Volumes/~/Blue Ray Video/Robocop (Blu-ray)
AV sync issues in /Volumes/~/Blue Ray Video/Robocop (Blu-ray)/RoboCop_t00.mkv
AV sync in 1,2,3 at 0:16:36.537 (6.791ms) : encountered overlapping frame, audio skew is +6.791ms
AV sync in 1,2,3 at 0:24:35.474 (7.208ms) : encountered overlapping frame, audio skew is +14ms
AV sync in 1,2 at 0:24:35.488 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +3.333ms
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
AV sync issues in /Volumes/~/Blue Ray Video/Robocop (Blu-ray)/RoboCop_t01.mkv
AV sync in 1,2 at 0:16:36.537 (6.791ms) : encountered overlapping frame, audio skew is +6.791ms
AV sync in 1,2 at 0:24:35.474 (7.208ms) : encountered overlapping frame, audio skew is +14ms
004001:0000 Forced subtitles track #6 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #14 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #29 turned out to be empty and was removed from output file
AV sync issues in /Volumes/~/Blue Ray Video/Robocop (Blu-ray)/RoboCop_t08.mkv
AV sync in 1 at 0:01:17.110 (9.633ms) : encountered overlapping frame, audio skew is +9.633ms
AV sync in 1 at 0:01:33.193 (13.266ms) : encountered overlapping frame, audio skew is +22.9ms
AV sync in 1 at 0:02:00.019 (21.2ms) : encountered overlapping frame, audio skew is +44.1ms
AV sync in 1 at 0:02:00.064 (32ms) : 1 frame(s) dropped to reduce audio skew to +12.1ms
AV sync issues in /Volumes/~/Blue Ray Video/Robocop (Blu-ray)/RoboCop_t09.mkv
004001:0000 Forced subtitles track #33 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #41 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #47 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #49 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #51 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #57 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #59 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #61 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #63 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #65 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #69 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #71 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #73 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #75 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #45 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #53 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #55 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #67 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #31 turned out to be empty and was removed from output file
005005:0080 19 titles saved
005036:0104 Copy complete. 19 titles saved.
Pale Rider
Ripping the Blu-ray of Johnny Mnemonic yesterday, I got the behavior I expected/desired—a single file containing all the audio-video info:
Debug log started at Thu Feb 4 01:05:01 2016 , written by MakeMKV v1.9.9 darwin(x86-release)
001004:0000 Debug logging enabled, log will be saved as /Users/greghammond/MakeMKV_log.txt
DCE=zub51DQgbEKHqxqUH7AfWsPp9yZYkbf5ZkXRhk9v0OU8JMlivQ1qvpYQ3rYGEut9H5ea80/Dp8nx3zW5/uafXgdSVfsSJG+L1DyVJOWjOkzdfXTrJmi5wxd9MDd6My2LFFDYMuNMR56yz1Bh/bjQjkrjihvwWg7h/g==
DCE=KysrKyuQcUUS+NylBVNaJ3sZaGcILMT5y4mHdBuv4fjA4/V5n1rmr7I9tsktPyTNJlfIPiAGrJhdZRsmqfD3K4PeKYSbr87VegmGR+6siPeZHZcp/DdknfeoZmi6yc8nFp56fHpTESImSmUHifzL7HoUyHc/vfqkBw==
DISCID=BAE4D1592A774FE2E946534A77B8349C60B220FB
003025:0000 Title #00095.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00096.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00014.m2ts was added as title #1
005014:0000 Saving 1 titles into directory /Volumes/~/Blue Ray Video/Johnny Mnemonic
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
