Hi Guys
any chance figuring out which playlist to use, I see 100s of them...?
Thx!!
Man Up (2015) playlist?
Re: Man Up (2015) playlist?
00589.mpls
Segment Map:
114, 116, 102, 107, 112, 101, 111, 108, 105, 109
Segment Map:
May I ask how you figured that out, as this is the first DB I've come across that has several very similar segments?
I have heard that anyDVD will mimic BD Player processing to figure out the correct .mpls.
Thanks very much! I did a scene-by-scene comparison with the blu-ray and this is spot-on.
ekael86 wrote:00589.mpls
Segment Map:
- Contact:
Please do if you can - http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330
