Cloverfield will not finish or complete?
dpompell
Post by dpompell »
MakeMKV v1.9.9 win(x64-release) started
File 00000.mpls was added as title #0
File 00002.mpls was added as title #1
File 00003.mpls was added as title #2
File 00004.mpls was added as title #3
File 00010.mpls was added as title #4
File 00013.mpls was added as title #5
File 00005.mpls was added as title #6
Title #00006.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #7
Title #00007.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.m2ts was added as title #8
File 00012.m2ts was added as title #9
File 00013.m2ts was added as title #10
File 00014.m2ts was added as title #11
File 00015.m2ts was added as title #12
File 00016.m2ts was added as title #13
Title #00017.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00021.m2ts was added as title #14
Title #00022.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/Cloverfield
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257426432, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257432576, attempting to work around
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '22257438720'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '22257438720'
Failed to save title 0 to file D:/Video/Cloverfield/Cloverfield_t00.mkv
0 titles saved, 1 failed
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257451008, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257475584, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257481728, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257506304, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257524736, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257530880, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257537024, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257543168, attempting to work around
Hash check failed for file 00000.m2ts at offset 22257592320, file is corrupt.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257696768, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257709056, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257715200, attempting to work around
Hash check failed for file 00000.m2ts at offset 22257788928, file is corrupt.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257844224, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257930240, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257967104, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257979392, attempting to work around
Hash check failed for file 00000.m2ts at offset 22257985536, file is corrupt.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22257991680, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22258003968, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22258010112, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22258096128, attempting to work around
Hash check failed for file 00000.m2ts at offset 22258182144, file is corrupt.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 22258200576, attempting to work around
Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '22258243584'
Re: Cloverfield will not finish or complete?
Based on the log, I'm going to suggest two things.
First, follow the instructions in the FAQ in my signature and pack up the log and the required files and send them off to Mike at support@makemkv.com .
The second is to try making an unencrypted backup (rather than open/save, like you're doing), and see if that completes. Mike will probably want the log from that, too... he did when I hit a disk like this last month. And he might ask for more information after he looks at this; he'll email you with what he needs.
bhampster
Post by bhampster »
My copy of Cloverfield looked fine (it's actually hard to tell because the top side is supposed to have sort of a scrapped up damaged look) and it played fine but I could never back it up with MakeMKV.
I cleaned it maybe 10 or 20 times. But never going to work.
I picked up a used copy at a local shop for around $5 and worked first try. Threw my old copy away even though it was sort of still use-able... I knew it was somewhat damaged and that was enough of a reason to toss it out.
