When backing this Blu-Ray up, I see (no exaggeration) probably 150 identical 19.6GB tracks, every one of them with identical audio/subtitle options. Should I just pick one random title and use that as the main movie track, or is there only one "correct" choice?
Also, by default, ALL tracks are selected. Is there an "Select/Unselect All" toggle button somewhere that I am missing, or am I going to have to click 149 times to unselect all the duplicate tracks?
The Last Witch Hunter
Re: The Last Witch Hunter
http://makemkv.com/forum2/viewtopic.php?f=8&t=14147
And you might want to explore what happens when you RIGHT click on the left-hand menu....
