Cannot rip disc, makemkv reports many different errors
J0SH44
Post by J0SH44 » Wed Feb 03, 2016 11:38 pm
I have been using Handbrake along with Passkey to rip my videos to disc so that I can play them back over my Plex server. However, I have been having issues with my Minion bluray disc today. I posted in the Handbrake forum and was advised to try out MakeMKV and then use Handbrake to encode to the format of preference. Unfortunately, it looks like I am receiving quite a few errors using makeMKV as well. I have copied a few below but it is only a small sample (most are the 'The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 839448576, attempting to work around' error with a different number).
I am not sure what makemkv is trying to tell me but I am sure it is trying to tell me something useful. Any help is appreciated.
Windows 8.1 install and version 1.99 makeMKV.
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 838858752, attempting to work around
Hash check failed for file 00800.m2ts at offset 838920192, file is corrupt.
Too many hash check errors in file 00800.m2ts.
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '838926336'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '838926336'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '839055360'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '839448576'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '839448576'
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 840560640, attempting to work around
Failed to save title 0 to file E:/MKV/Minions/Minions_t00.mkv
0 titles saved, 1 failed
Re: Cannot rip disc, makemkv reports many different errors
Post by Woodstock » Wed Feb 03, 2016 11:51 pm
Were there errors prior to these?
A suggestion - try doing backup with decryption instead of open/save. I'm working with Mike on one of my disks that gives the same sort of errors on 3 titles out of 20. If the backup succeeds, that means the disk itself is readable, but there is an issue with how the m2ts file is constructed.
handbrake can work with the backup, provided you point it at the right place. That's currently how I got my 3 "missing" titles processed. Going directly for the m2ts files doesn't work so well.
J0SH44
Post by J0SH44 » Wed Feb 03, 2016 11:59 pm
Hi Woodstock,
There window at the bottom of the GUI is loaded with errors, most of them are 'The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 835319808, attempting to work around' with a different number for the offset. The errors that I have listed appear to be all the errors listed in the window--they just end up getting repeated for different offset numbers. One thing to note is that I was able to save two other titles on the disc--I assume they were two of the 'mini movies' advertised on the cover.
I will see if i can do a backup with the decryption box checked--just started it now. Will update with results.
J0SH44
Post by J0SH44 » Thu Feb 04, 2016 5:28 am
Results are in.
When the proc was complete I was presented with a box stating "Backup done but 1 files failed hash check."
The following was in the window at the bottom of the GUI
Backing up disc into folder "E:/MKV/backup/MINIONS2D_NA"
Hash check failed for file /BDMV/STREAM/00800.m2ts at offset 844818432, file is corrupt.
Hash check failed for file /BDMV/STREAM/00800.m2ts at offset 845801472, file is corrupt.
Hash check failed for file /BDMV/STREAM/00800.m2ts at offset 846194688, file is corrupt.
Hash check failed for file /BDMV/STREAM/00800.m2ts at offset 846391296, file is corrupt.
Hash check failed for file /BDMV/STREAM/00800.m2ts at offset 847570944, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00800.m2ts.
Hash check for /BDMV/STREAM/00800.m2ts : 0.00% corrupt, 99.98% correct, 99.99% checked.
I thought, what the hell, I will see what HandBrake does with it. So I sourced the folder in HB, loaded up my settings (mp4, 22, film, fast) and started the encoding proc. After a couple of hours HB completed the task without a single complaint (at least in the GUI) and a good looking 3GB video. I have a copy of the log (in case it is helpful in any way) below:
HandBrake 0.10.3.0 - 64bit Version
OS: Microsoft Windows NT 6.2.9200.0 - 64bit
CPU: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
Ram: 12279 MB,
GPU Information:
  NVIDIA GeForce GTX 560  - 10.18.13.6143
Screen: 1920x1080
Temp Dir: C:\Users\j\AppData\Local\Temp\
Install Dir: E:\Program Files\Handbrake
Data Dir: C:\Users\j\AppData\Roaming\HandBrake Team\HandBrake\0.10.3.0
CLI Query:  -i "E:\MKV\backup\Minions (2015)" -t 155 --angle 1 -c 1-21 -o "I:\Movies\Minions (2015)\Minions (2015).m4v"  -f mp4  -w 1920 --crop 22:22:0:0 --loose-anamorphic  --modulus 2 -e x264 -q 22 --vfr -a 1 -E av_aac -6 dpl2 -R Auto -B 160 -D 0 --gain 0 --audio-fallback ac3 --markers="C:\Users\j\AppData\Local\Temp\Minions (2015)-155-chapters.csv" --encoder-preset=fast  --encoder-tune="film"  --encoder-level="4.0"  --encoder-profile=main  --verbose=1
[20:54:58] hb_init: starting libhb thread
HandBrake 0.10.3 (2016012200) - MinGW x86_64 - https://handbrake.fr
8 CPUs detected
Opening E:\MKV\backup\MINIONS (2015)...
[20:54:58] CPU: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
[20:54:58]  - logical processor count: 8
[20:54:58] OpenCL device #1: NVIDIA Corporation GeForce GTX 560
[20:54:58]  - OpenCL version: 1.1 CUDA
[20:54:58]  - driver version: 361.43
[20:54:58]  - device type:    GPU
[20:54:58]  - supported:      no
[20:54:58] OpenCL device #2: NVIDIA Corporation GeForce GTX 560
[20:54:58] Intel Quick Sync Video support: no
[20:54:58] hb_scan: path=E:\MKV\backup\Minions (2015), title_index=155
[20:54:58] scan: BD has 160 title(s)
[20:54:58] bd: scanning title 155
[20:54:58] bd: playlist 00800.MPLS
[20:54:58] bd: duration is 01:30:57 (5457994 ms)
[20:54:58] bd: video id=0x1011, stream type=H.264, format 1080p
[20:54:58] bd: aspect = 1.77778
[20:54:58] bd: audio id=0x761100, lang=English (AC3), 3cc=eng
[20:54:58] bd: audio id=0x721100, lang=English (TrueHD), 3cc=eng
[20:54:58] bd: audio id=0x1101, lang=Espanol (AC3), 3cc=spa
[20:54:58] bd: audio id=0x1102, lang=Francais (AC3), 3cc=fra
[20:54:58] bd: audio id=0x1103, lang=English (AC3), 3cc=eng
[20:54:58] bd: subtitle id=0x1200, lang=English, 3cc=eng
[20:54:58] bd: subtitle id=0x1201, lang=Espanol, 3cc=spa
[20:54:58] bd: subtitle id=0x1202, lang=Francais, 3cc=fra
[20:54:58] bd: subtitle id=0x1203, lang=Espanol, 3cc=spa
[20:54:58] bd: subtitle id=0x1204, lang=Francais, 3cc=fra
[20:54:58] bd: chap 1 packet=768, 339839 ms
[20:54:58] bd: chap 2 packet=1874407296, 349098 ms
[20:54:58] bd: chap 3 packet=3784963008, 326200 ms
[20:54:58] bd: chap 4 packet=5536690752, 333291 ms
[20:54:58] bd: chap 5 packet=7282621056, 270603 ms
[20:54:58] bd: chap 6 packet=8768414784, 355605 ms
[20:54:58] bd: chap 7 packet=10757001408, 274232 ms
[20:54:58] bd: chap 8 packet=12278072448, 209959 ms
[20:54:58] bd: chap 9 packet=13398727872, 270478 ms
[20:54:58] bd: chap 10 packet=14818831488, 234776 ms
[20:54:58] bd: chap 11 packet=16169248704, 258967 ms
[20:54:58] bd: chap 12 packet=17602111296, 201868 ms
[20:54:58] bd: chap 13 packet=18648021888, 272021 ms
[20:54:58] bd: chap 14 packet=20102852352, 257757 ms
[20:54:58] bd: chap 15 packet=21497000640, 120537 ms
[20:54:58] bd: chap 16 packet=22075872384, 203912 ms
[20:54:58] bd: chap 17 packet=23197774656, 253503 ms
[20:54:58] bd: chap 18 packet=24638119296, 340173 ms
[20:54:58] bd: chap 19 packet=26571008064, 431931 ms
[20:54:58] bd: chap 20 packet=28721021952, 152986 ms
[20:54:58] bd: chap 21 packet=29567840256, 250 ms
[20:54:58] bd: title 155 has 21 chapters
[20:54:58] scan: decoding previews for title 155
[20:54:58] scan: title angle(s) 1
[20:54:58] scan: audio 0x1103: ac3, rate=48000Hz, bitrate=192000 English (AC3) (2.0 ch) (Dolby Surround)
[20:54:58] scan: audio 0x761100: ac3, rate=48000Hz, bitrate=640000 English (AC3) (5.1 ch)
[20:54:58] scan: audio 0x1101: ac3, rate=48000Hz, bitrate=640000 Espanol (AC3) (5.1 ch)
[20:54:58] scan: audio 0x1102: ac3, rate=48000Hz, bitrate=640000 Francais (AC3) (5.1 ch)
[20:54:58] scan: audio 0x721100: truehd, rate=48000Hz, bitrate=200000 English (TrueHD) (7.1 ch)
Scanning title 1 of 1, preview 1, 10.00 %
Scanning title 1 of 1, preview 2, 20.00 %
Scanning title 1 of 1, preview 3, 30.00 %
Scanning title 1 of 1, preview 4, 40.00 %
Scanning title 1 of 1, preview 5, 50.00 %
Scanning title 1 of 1, preview 6, 60.00 %
Scanning title 1 of 1, preview 7, 70.00 %
Scanning title 1 of 1, preview 8, 80.00 %
Scanning title 1 of 1, preview 9, 90.00 %
Scanning title 1 of 1, preview 10, 100.00 %[20:55:01] scan: 10 previews, 1920x1080, 23.976 fps, autocrop = 22/22/0/0, aspect 16:9, PAR 1:1
[20:55:01] stream: 8 good frames, 0 errors (0%)
[20:55:01] libhb: scan thread found 1 valid title(s)
+ title 155:
  + playlist: 00800.MPLS
  + duration: 01:30:57
  + size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 23.976 fps
  + autocrop: 22/22/0/0
  + support opencl: no
  + support hwd: no
  + chapters:
    + 1: cells 0->0, 0 blocks, duration 00:05:40
    + 2: cells 0->0, 0 blocks, duration 00:05:49
    + 3: cells 0->0, 0 blocks, duration 00:05:26
    + 4: cells 0->0, 0 blocks, duration 00:05:33
    + 5: cells 0->0, 0 blocks, duration 00:04:31
    + 6: cells 0->0, 0 blocks, duration 00:05:56
    + 7: cells 0->0, 0 blocks, duration 00:04:34
    + 8: cells 0->0, 0 blocks, duration 00:03:30
    + 9: cells 0->0, 0 blocks, duration 00:04:30
    + 10: cells 0->0, 0 blocks, duration 00:03:55
    + 11: cells 0->0, 0 blocks, duration 00:04:19
    + 12: cells 0->0, 0 blocks, duration 00:03:22
    + 13: cells 0->0, 0 blocks, duration 00:04:32
    + 14: cells 0->0, 0 blocks, duration 00:04:18
    + 15: cells 0->0, 0 blocks, duration 00:02:01
    + 16: cells 0->0, 0 blocks, duration 00:03:24
    + 17: cells 0->0, 0 blocks, duration 00:04:14
    + 18: cells 0->0, 0 blocks, duration 00:05:40
    + 19: cells 0->0, 0 blocks, duration 00:07:12
    + 20: cells 0->0, 0 blocks, duration 00:02:33
    + 21: cells 0->0, 0 blocks, duration 00:00:00
  + audio tracks:
    + 1, English (AC3) (5.1 ch) (iso639-2: eng), 48000Hz, 640000bps
    + 2, English (TrueHD) (7.1 ch) (iso639-2: eng)
    + 3, Espanol (AC3) (5.1 ch) (iso639-2: spa), 48000Hz, 640000bps
    + 4, Francais (AC3) (5.1 ch) (iso639-2: fra), 48000Hz, 640000bps
    + 5, English (AC3) (2.0 ch) (Dolby Surround) (iso639-2: eng), 48000Hz, 192000bps
  + subtitle tracks:
    + 1, English (iso639-2: eng) (Bitmap)(PGS)
    + 2, Espanol (iso639-2: spa) (Bitmap)(PGS)
    + 3, Francais (iso639-2: fra) (Bitmap)(PGS)
    + 4, Espanol (iso639-2: spa) (Bitmap)(PGS)
    + 5, Francais (iso639-2: fra) (Bitmap)(PGS)
Reading chapter markers from file C:\Users\j\AppData\Local\Temp\Minions (2015)-155-chapters.csv
[20:55:01] 1 job(s) to process
[20:55:01] starting job
[20:55:01] sync: expecting 130860 video frames
[20:55:01] job configuration:
[20:55:01]  * source
[20:55:01]    + E:\MKV\backup\Minions (2015)
[20:55:01]    + title 155, chapter(s) 1 to 21
[20:55:01]  * destination
[20:55:01]    + I:\Movies\Minions (2015)\Minions (2015).m4v
[20:55:01]    + container: MPEG-4 (libavformat)
[20:55:01]      + chapter markers
[20:55:01]  * video track
[20:55:01]    + decoder: h264
[20:55:01]      + bitrate 200 kbps
[20:55:01]    + filters
[20:55:01]      + Framerate Shaper (0:27000000:1126125)
[20:55:01]        + frame rate: same as source (around 23.976 fps)
[20:55:01]      + Crop and Scale (1920:1036:22:22:0:0)
[20:55:01]        + source: 1920 * 1080, crop (22/22/0/0): 1920 * 1036, scale: 1920 * 1036
[20:55:01]    + loose anamorphic
[20:55:01]      + storage dimensions: 1920 * 1036, mod 2
[20:55:01]      + pixel aspect ratio: 1 / 1
[20:55:01]      + display dimensions: 1920 * 1036
[20:55:01]    + encoder: H.264 (libx264)
[20:55:01]      + preset:  fast
[20:55:01]      + tune:    film
[20:55:01]      + profile: main
[20:55:01]      + level:   4.0
[20:55:01]      + quality: 22.00 (RF)
[20:55:01]  * audio track 1
[20:55:01]    + decoder: English (AC3) (5.1 ch) (track 1, id 0x761100)
[20:55:01]      + bitrate: 640 kbps, samplerate: 48000 Hz
[20:55:01]    + mixdown: Dolby Pro Logic II
[20:55:01]    + encoder: AAC (libavcodec)
[20:55:01]      + bitrate: 160 kbps, samplerate: 48000 Hz
[20:55:01] encx264: min-keyint: 24, keyint: 240
[20:55:01] encx264: encoding at constant RF 22.000000
[20:55:01] encx264: unparsed options: level=4.0:ref=2:deblock=-1,-1:8x8dct=0:weightp=1:subme=6:psy-rd=1.00,0.15:vbv-bufsize=25000:vbv-maxrate=20000:rc-lookahead=30
x264 [info]: using SAR=1/1
[20:55:01] reader: first SCR 1044806 id 0x1011 DTS 1044806
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2
x264 [info]: profile Main, level 4.0
[20:55:01] h264: "Chapter 1" (1) at frame 0 time 3754
[20:55:01] sync: first pts is 3754
libbluray/decoders/m2ts_filter.c:194: missing sync byte. scrambled data ? Filtering aborted.
libbluray/bluray.c:619: m2ts filter error
[20:57:56] next_packet: sync lost @ 844693824, regained after 69508 bytes
[20:57:56] stream: error near frame 3819: continuity error: got 5 expected 11
[20:57:56] next_packet: sync lost @ 845742336, regained after 65476 bytes
[20:57:56] next_packet: sync lost @ 846004416, regained after 67588 bytes
[20:57:56] next_packet: sync lost @ 846201024, regained after 67588 bytes
[ac3 @ 0000000006647080] bandwidth code = 62 > 60
[ac3 @ 0000000006647080] error decoding the audio block
[ac3 @ 0000000006647080] frame sync error
[20:57:56] sync: adding 158 ms of silence to audio 0x761100  start 14304785, next 14290560
[20:57:56] next_packet: sync lost @ 847512384, regained after 64900 bytes
[ac3 @ 0000000006647080] exponent out-of-range
[20:57:56] next_packet: sync lost @ 847970496, regained after 67588 bytes
[20:57:56] next_packet: sync lost @ 848101632, regained after 65476 bytes
[20:57:56] next_packet: sync lost @ 848429376, regained after 69508 bytes
[20:57:56] next_packet: sync lost @ 848560320, regained after 67588 bytes
[20:57:56] next_packet: sync lost @ 848691456, regained after 65476 bytes
[20:57:56] sync: adding 96 ms of silence to audio 0x761100  start 14330705, next 14322063
[20:57:56] next_packet: sync lost @ 849019200, regained after 69508 bytes
[20:57:56] sync: adding 96 ms of silence to audio 0x761100  start 14345105, next 14336464
[20:57:56] next_packet: sync lost @ 850329792, regained after 67588 bytes
[20:57:56] next_packet: sync lost @ 850526400, regained after 67588 bytes
[20:57:56] next_packet: sync lost @ 850657536, regained after 65476 bytes
[20:57:57] next_packet: sync lost @ 851706048, regained after 67588 bytes
[20:57:57] next_packet: sync lost @ 851837184, regained after 65476 bytes
[20:57:57] next_packet: sync lost @ 851968320, regained after 69508 bytes
[20:57:57] next_packet: sync lost @ 852164928, regained after 69508 bytes
[ac3 @ 0000000006647080] bandwidth code = 63 > 60
[20:57:57] sync: adding 128 ms of silence to audio 0x761100  start 14394065, next 14382544
[20:57:57] next_packet: sync lost @ 853606656, regained after 65476 bytes
[h264 @ 0000000006649d40] reference picture missing during reorder
[h264 @ 0000000006649d40] Missing reference picture
[21:01:50] h264: "Chapter 2" (2) at frame 8142 time 30589134
[21:08:13] h264: "Chapter 3" (3) at frame 16512 time 62008021
[21:14:22] h264: "Chapter 4" (4) at frame 24333 time 91366100
[21:20:22] h264: "Chapter 5" (5) at frame 32324 time 121362316
[21:25:16] h264: "Chapter 6" (6) at frame 38812 time 145716646
[21:32:21] h264: "Chapter 7" (7) at frame 47338 time 177721119
[21:37:43] h264: "Chapter 8" (8) at frame 53913 time 202402025
[21:41:47] h264: "Chapter 9" (9) at frame 58947 time 221298402
[21:46:42] h264: "Chapter 10" (10) at frame 65432 time 245641471
[21:51:47] h264: "Chapter 11" (11) at frame 71061 time 266771330
[21:56:19] h264: "Chapter 12" (12) at frame 77270 time 290078364
[21:59:48] h264: "Chapter 13" (13) at frame 82110 time 308246514
[22:04:33] h264: "Chapter 14" (14) at frame 88632 time 332728471
[22:09:49] h264: "Chapter 15" (15) at frame 94812 time 355926646
[22:11:57] h264: "Chapter 16" (16) at frame 97702 time 366774984
[22:16:06] h264: "Chapter 17" (17) at frame 102591 time 385127067
[22:21:15] h264: "Chapter 18" (18) at frame 108669 time 407942360
[22:28:15] h264: "Chapter 19" (19) at frame 116825 time 438557945
[22:32:36] h264: "Chapter 20" (20) at frame 127181 time 477431780
[22:34:28] reader: done. 2 scr changes
[22:34:28] h264: "Chapter 21" (21) at frame 130835 time 491147982
[22:34:29] work: average encoding speed for job is 21.921139 fps
[22:34:29] sync: got 130854 frames, 130860 expected
[22:34:29] render: lost time: 0 (0 frames)
[22:34:29] render: gained time: 0 (0 frames) (0 not accounted for)
[22:34:29] h264-decoder done: 130854 frames, 0 decoder errors, 0 drops
x264 [info]: frame I:1679  Avg QP:19.86  size:163163
x264 [info]: frame P:77996 Avg QP:22.67  size: 30489
x264 [info]: frame B:51179 Avg QP:24.10  size: 11561
x264 [info]: consecutive B-frames: 35.7% 32.9% 10.8% 20.6%
x264 [info]: mb I  I16..4: 36.3%  0.0% 63.7%
x264 [info]: mb P  I16..4:  3.8%  0.0%  4.1%  P16..4: 43.8% 11.5%  8.1%  0.0%  0.0%    skip:28.6%
x264 [info]: mb B  I16..4:  6.3%  0.0%  0.6%  B16..8: 16.3%  3.5%  0.3%  direct:14.4%  skip:58.6%  L0:38.7% L1:51.4% BI: 9.9%
x264 [info]: coded y,uvDC,uvAC intra: 52.9% 83.1% 50.1% inter: 12.5% 34.3% 3.1%
x264 [info]: i16 v,h,dc,p: 27% 21% 23% 28%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 19% 20%  6%  8%  7%  7%  6%  5%
x264 [info]: i8c dc,h,v,p: 53% 20% 19%  8%
x264 [info]: Weighted P-Frames: Y:2.5% UV:1.4%
x264 [info]: ref P L0: 68.4% 31.6%
x264 [info]: ref B L0: 71.4% 28.6%
x264 [info]: ref B L1: 95.6%  4.4%
x264 [info]: kb/s:4754.32
[22:34:29] ac3-decoder done: 0 frames, 0 decoder errors, 0 drops
[22:34:30] mux: track 0, 130854 frames, 3243596062 bytes, 4754.30 kbps, fifo 2048
[22:34:30] mux: track 1, 255841 frames, 109223824 bytes, 160.09 kbps, fifo 4096
[22:34:30] stream: 130855 good frames, 50 errors (0%)
[22:34:30] libhb: work result = 0
Encode done!
HandBrake has exited.
Post by Woodstock » Thu Feb 04, 2016 5:53 am
On Disney animated disks like Minions, there are "3 copies" of the movie, where 99% of the files are actually the same file, with the titles and credits swapped out to match the selected language (english/french/spanish) It is weird that there would be an issue with one copy, but not the other two, unless it was in the titles/credits.
