The Last Witch HUnter playlist?
gamecaptor
Re: The Last Witch HUnter playlist?
Post by gamecaptor » Wed Feb 03, 2016 3:18 pm
BlakHol
Post by BlakHol » Wed Feb 03, 2016 3:55 pm
I have the Red Version (USA) of "The Last Witch Hunter" and have checked all segments against the original Blu-ray. The correct playlist is 995. As stated by other posters, Playlist 190 is INCORRECT. I compared Playlist 190 to the original Blu-ray and have verified the segments are out of order.
Here is the Info for Playlist 995:
Name: The Last Witch Hunter
Source file name: 00995.mpls
Duration: 1:46:34
Chapters count: 16
Segment count: 20
Segment map: 511,522,505,506,510,523,525,524,519,507,512,502,503,509,504,501,521,508,520,513
Hope this helps.
DJRumpy
Post by DJRumpy » Wed Feb 03, 2016 5:25 pm
Here's the script. Just make it executable and supply the path to the disc via the /Volumes folder. Just rename it to FindM2TS.pl
[Example]
./FindM2TS.pl /volumes/somebdtitle
FindM2TS.pl.txt
(1.36 KiB) Downloaded 3778 times
jrwalker4
Post by jrwalker4 » Wed Feb 03, 2016 7:30 pm
dashocker wrote: Can you provide the segment count, segment list and run time?
Sorry. Was out shopping and just came home to find your info request.
Here is the image from MakeMKV:
and here is the image of the rebuilt playlist as played by VLC for comparison with the original BD as played on my iMac in a BD player app:
As previously indicated, these images refer to UPC 0-31398-23471-5 as purchased on Amazon. Believe they contain all of the requested information even though there is a 2 second difference in runtime as reported by MakeMKV and VLC.
dashocker
Post by dashocker » Thu Feb 04, 2016 2:30 pm
thanks!
dashocker
Post by dashocker » Thu Feb 04, 2016 3:43 pm
BlakHol wrote:I have the Red Version (USA) of "The Last Witch Hunter" and have checked all segments against the original Blu-ray. The correct playlist is 995. As stated by other posters, Playlist 190 is INCORRECT. I compared Playlist 190 to the original Blu-ray and have verified the segments are out of order.
Duration: 1:46:34
Chapters count: 16
Segment count: 20
Hope this helps.
awesome! thanks!
bhampster
Post by bhampster » Fri Feb 05, 2016 5:41 pm
Just saying 995 worked for me.
Should have been called the last pls hunter.
I really enjoyed the movie though it was beat up on Rotten Tomatoes (16%)
DJRumpy
Post by DJRumpy » Fri Feb 05, 2016 8:22 pm
I didn't get the reviews either. Thought it was decent summer fair. Wasn't expecting Shakespeare. Hoping it gets another installment.
jrstickles
Post by jrstickles » Wed Feb 10, 2016 5:09 am
I tried both 216 and 995. 995 was the one that worked for me.... 216 was scrambled just like the others.
afletcher
Post by afletcher » Fri Mar 25, 2016 4:26 am
DJRumpy wrote:Here's the script. Just make it executable and supply the path to the disc via the /Volumes folder. Just rename it to FindM2TS.pl
[Example]
When I run this as described I eventually get an "out of memory" error and it kills itself. What may I be doing wrong?
DreamStatic
Post by DreamStatic » Sun Apr 03, 2016 11:01 pm
Thank you DJRumpy for the script. I was hoping it would fix me up on this disc but when I attempted to run it on OS X it came back with "Killed 9". I tried it on both the actual disc and a decrypted backup of the disc. Looks like this one may be a bigger pain than some. Just thought I would report the result in case it helps in troubleshooting the script. Let me know if there is anything more I can do to help test the script. Thanks again.
makememe
Post by makememe » Fri Apr 15, 2016 4:33 am
just purchased the last witch hunter to find the list of mpls. after procmon I confirm walker4 conclusion, 216, is correct for north american retail. Added because I see a post suggesting it rubbish, not for some bd, and that some late buyers like me will end up here down the road.
216mpls Segment map: 514,535,508,503,507,502,536,512,510,509,531,506,530,529,505
also, the last mpls is 997 for me, no 995.
997mpls is last and the Segment map: 514,533,508,503,507,502,534,536,512,526,510,538,531,530,529,527,505
spiceygas
Post by spiceygas » Mon May 16, 2016 11:36 am
I can confirm that from the Netflix disk, the correct title is 995.
Sounds like it's different from retail.
FatLibertarianDude
Post by FatLibertarianDude » Wed Jun 08, 2016 4:15 pm
Thank you. This was the version I have and the info I needed.
midnighwatcher
Post by midnighwatcher » Mon Dec 17, 2018 8:53 pm
Anyone know the correct playlist for the Amazon Canada BD? UPC is 7-7421211312-3.
