The Last Witch HUnter playlist?
gamecaptor
Re: The Last Witch HUnter playlist?
https://www.youtube.com/watch?v=AlhBmIb ... Zu9rOI2aIP
I have the Red Version (USA) of "The Last Witch Hunter" and have checked all segments against the original Blu-ray. The correct playlist is 995. As stated by other posters, Playlist 190 is INCORRECT. I compared Playlist 190 to the original Blu-ray and have verified the segments are out of order.
Here is the Info for Playlist 995:
Name: The Last Witch Hunter
Source file name: 00995.mpls
Duration: 1:46:34
Chapters count: 16
Segment count: 20
Segment map: 511,522,505,506,510,523,525,524,519,507,512,502,503,509,504,501,521,508,520,513
Hope this helps.
Duration: 1:46:34
Chapters count: 16
Segment count: 20
Hope this helps.
Here's the script. Just make it executable and supply the path to the disc via the /Volumes folder. Just rename it to FindM2TS.pl
[Example]
./FindM2TS.pl /volumes/somebdtitle
[Example]
- FindM2TS.pl.txt
- (1.36 KiB) Downloaded 3153 times
Sorry. Was out shopping and just came home to find your info request.dashocker wrote: Can you provide the segment count, segment list and run time?
Here is the image from MakeMKV:
and here is the image of the rebuilt playlist as played by VLC for comparison with the original BD as played on my iMac in a BD player app:
As previously indicated, these images refer to UPC 0-31398-23471-5 as purchased on Amazon. Believe they contain all of the requested information even though there is a 2 second difference in runtime as reported by MakeMKV and VLC.
thanks!jrwalker4 wrote:Sorry. Was out shopping and just came home to find your info request.dashocker wrote: Can you provide the segment count, segment list and run time?
awesome! thanks!BlakHol wrote:I have the Red Version (USA) of "The Last Witch Hunter" and have checked all segments against the original Blu-ray. The correct playlist is 995. As stated by other posters, Playlist 190 is INCORRECT. I compared Playlist 190 to the original Blu-ray and have verified the segments are out of order.
Duration: 1:46:34
Chapters count: 16
Segment count: 20
Hope this helps.
Just saying 995 worked for me.
Should have been called the last pls hunter.
I really enjoyed the movie though it was beat up on Rotten Tomatoes (16%)
I didn't get the reviews either. Thought it was decent summer fair. Wasn't expecting Shakespeare. Hoping it gets another installment.
jrstickles
I tried both 216 and 995. 995 was the one that worked for me.... 216 was scrambled just like the others.
DJRumpy wrote:Here's the script. Just make it executable and supply the path to the disc via the /Volumes folder. Just rename it to FindM2TS.pl
[Example]
When I run this as described I eventually get an "out of memory" error and it kills itself. What may I be doing wrong?
DreamStatic
Thank you DJRumpy for the script. I was hoping it would fix me up on this disc but when I attempted to run it on OS X it came back with "Killed 9". I tried it on both the actual disc and a decrypted backup of the disc. Looks like this one may be a bigger pain than some. Just thought I would report the result in case it helps in troubleshooting the script. Let me know if there is anything more I can do to help test the script. Thanks again.
just purchased the last witch hunter to find the list of mpls. after procmon I confirm walker4 conclusion, 216, is correct for north american retail. Added because I see a post suggesting it rubbish, not for some bd, and that some late buyers like me will end up here down the road.
216mpls Segment map: 514,535,508,503,507,502,536,512,510,509,531,506,530,529,505
also, the last mpls is 997 for me, no 995.
997mpls is last and the Segment map: 514,533,508,503,507,502,534,536,512,526,510,538,531,530,529,527,505
I can confirm that from the Netflix disk, the correct title is 995.
Sounds like it's different from retail.
FatLibertarianDude
Thank you. This was the version I have and the info I needed.jrwalker4 wrote:Sorry. Was out shopping and just came home to find your info request.dashocker wrote: Can you provide the segment count, segment list and run time?
midnighwatcher
Anyone know the correct playlist for the Amazon Canada BD? UPC is 7-7421211312-3.
