NEW Retail i just got unopened...No File available witg these Errors:
MakeMKV v1.9.9 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/terry/MakeMKV_log.txt
Optical drive "BD-RE MATSHITA BD-MLT UJ260AF 1.01d" opened in OS access mode.
DEBUG: Code 100864256 at !<t@/W*KKFu/M]@qE2:29396092
DEBUG: Code 100864256 at !<t@/W*KKFu/M]@qE2:29393930
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-RE MATSHITA BD-MLT UJ260AF 1.01' at offset '24977078272'
File 00000.mpls was added as title #0
Title #00002.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00003.m2ts was added as title #1
File 00004.m2ts was added as title #2
Title #00006.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/terry/Movies/LOGICAL_VOLUME_ID
DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:29396092
DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:29393930
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '24977078272'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '18651807744'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '18651807744'
DEBUG: Code 1073741829 at !<t@/W*KKFu/M]@qE2:121262969
DEBUG: Code 100864256 at !<t@/W*KKFu/M]@qE2:121262969
DEBUG: Code 0 at y0'(,k6zr!"t-8B-z*t<:121263291
DEBUG: Code 0 at _Z,(O/ A,th<R]rk8F>[:121262302
DEBUG: Code 0 at y0'(,k6zr!"t-8B-z*t<:213130812
DEBUG: Code 9107328 at y0'(,k6zr!"t-8B-z*t<:29393286
DEBUG: Code 0 at mG<:=b9W,P~ormm]K)|z[:29398967
Failed to save title 0 to file /Users/terry/Movies/LOGICAL_VOLUME_ID/title00.mkv
0 titles saved, 1 failed
TOTAL RECALL (Retain) 1080o BEYOND HIGH DEFINITION
terryzx
The Closer You Get to The Meaning
The Sooner You Know that You're Dreaming
Re: TOTAL RECALL (Retain) 1080o BEYOND HIGH DEFINITION
It looks like this is a plug-in laptop BD drive, and not particularly fast, so it should not be going off-line due to speed. Is it just this disk that you are having issues with, or have other disks started having errors?Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '24977078272'
Something is causing the drive to report an error, then go off-line. Fingerprints and other stuff on the disk usually won't take it off-line. It might be worth while to clean the drive by blowing out any dust.
terryzx
It's a new drive I just got and he DVD is new out of the shrink wrap and was only put in there for the fire time ever iused.
