Benny Hill Megaset errors disc 17
Shocker00
Post by Shocker00 »
I bought the Benny Hill megaset and disc 17 was giving me errors and nothing I did seem to work. I then decided to exchange the set in for a new set thinking the disc was bad and I'm still getting errors on the new disc at the exact same spot on the disc. I have also tried dvdfab and clonedvd with no success.
Debug log started at Wed Jan 27 00:46:17 2016 , written by MakeMKV v1.9.9 win(x64-release)
001005:0000 MakeMKV v1.9.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Todd/MakeMKV_log.txt
003028:0000 Title #1 was added (9 cell(s), 0:50:39)
003028:0000 Title #2 was added (10 cell(s), 0:50:33)
003028:0000 Title #3 was added (10 cell(s), 0:50:34)
005014:0000 Saving 1 titles into directory G:/TV Shows/Benny Hill Show/Season 17
005001:0308 File G:/TV Shows/Benny Hill Show/Season 17/title00.mkv already exist. Do you want to overwrite it?
001003:0020 DEBUG: Code 117637351 at ~a>#F;zC~?ZK*A(;gy0$qXr5>:213131732
001003:0020 DEBUG: Code 117637351 at ?w!|R]:)Y2.z$@Q+:29393953
001003:0020 DEBUG: Code 100864261 at #8ZaNU.{RP#\,ecY:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '839372800'
001003:0020 DEBUG: Code 3221225628 at ~a>#F;zC~?ZK*A(;gy0$qXr5>:213131732
001003:0020 DEBUG: Code 3221225628 at ?w!|R]:)Y2.z$@Q+:29393953
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '839372800'
DEBUG: Code 3221225628 at m\<}c9ZOfCO[p%-X"m:213130904
001003:0020 DEBUG: Code 3221225628 at m\<}c9ZOfCO[p%-X"m:121262969
Re: Benny Hill Megaset errors disc 17
In general, errors like this mean that the drive itself has gone off-line:
Is it an internal or external drive? If it is external, make sure it has good power to it. A lot of USB powered drives do not get enough power to run at full speed if they aren't plugged into a powered USB hub, or into the computer itself.
It is rare for internal drives to have that kind of issue, but they can have other issues....
Shocker00
Post by Shocker00 »
Thanks for your response. It is an external hard drive plug into the computer with about 1 ft' usb cable. It strange because i wasy able to copy every episode except one and it had the same problem on both discs at the same spot. I tried to copy it on another computer with an internal hdd and it worked just fine. All is good now! Thanks for your help.
