Rambo 2 & Rambo 3
terryzx
Rambo 2 & Rambo 3
Post by terryzx »
Rambo 2 & Rambo 3 from the trilogy box set both appear to convert but when they get near the end they get lots of errors and the file just disappears
The Closer You Get to The Meaning
The Sooner You Know that You're Dreaming
Re: Rambo 2 & Rambo 3
And without logs to show what errors occurred, we would have to start offering wild guesses. Electromagnetic interference from underground nuclear testing on the far side of the moon pops to mind, but that's just how my mind works at times... :)
See the FAQ in my signature for how to turn on debug logging, try the rip again, and post the log here, please.
terryzx
Post by terryzx »
I'll try it again later and add the logs Thanx
terryzx
Post by terryzx »
Just tried it again and got this...does the same with the Rambo 3
MakeMKV v1.9.9 darwin(x86-release) started
Optical drive "BD-RE MATSHITA BD-MLT UJ260AF 1.01d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'BD-RE MATSHITA BD-MLT UJ260AF 1.01' at offset '24360777728'
File 00008.mpls was added as title #0
File 00002.mpls was added as title #1
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #2
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #3
Title #00013.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/terry/Movies/RAMBO_II
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '24360777728'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '16962091008'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962091008'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962093056'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962097152'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962103296'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962109440'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962115584'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '16962127872'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '17005737984'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '17005737984'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '17005740032'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '17016029184'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '17016029184'
Failed to save title 1 to file /Users/terry/Movies/RAMBO_II/title01.mkv
0 titles saved, 1 failed
Your drive is having a lot of problems with this disk. The directory structure contains unreadable sections, as does the content area.
If disk 1 worked fine and it's the other two with problems, there is likely common damage between the other two disks.
There is no work-around for disks that can't be read, other than figuring out how to make them readable. Make sure you don't have cracks, scratches, or dirt on the disks, including fingerprints.
terryzx
Post by terryzx »
This is a brand new box set I just got. The first ripped ok but both 2 & 3 gave the same errors and in the end the file it made just disappeared. Any idea how to correct it an rip correctly?
If MakeMKV detects an error during the rip, it removes the output file, so the "fix" is getting the disk to read without errors.
I'd recommend getting the set replaced.
terryzx
Post by terryzx »
OK Thank You
WAYFLIX
Post by WAYFLIX »
Has anyone ever got this to work? I have tried 3 different Rambo 2 discs on 5 different computers and get nothing but read errors. This movie is truly copy proof.
yorgo
Post by yorgo »
Your assessment is not quite right. If the set was mastered or pressed with errors, then it will not rip as was described earlier. You'll need to find a different set, probably a batch mastered/pressed at another location or on another date, one with no errors. It stinks and is rare but happens and I'm guessing that there is an error-free set or disc out there. Having said that, the issue isn't one of encryption since the errors occur in the rip itself and not in de-encryption, technically making the set not "truly copy proof".
WAYFLIX
Post by WAYFLIX »
yorgo wrote:Your assessment is not quite right. If the set was mastered or pressed with errors, then it will not rip as was described earlier. You'll need to find a different set, probably a batch mastered/pressed at another location or on another date, one with no errors. It stinks and is rare but happens and I'm guessing that there is an error-free set or disc out there. Having said that, the issue isn't one of encryption since the errors occur in the rip itself and not in de-encryption, technically making the set not "truly copy proof".
Well if anyone can find one I will buy it off them. I have tried rentals and retail copies with no luck over the past 2 years.
jatr12
Post by jatr12 »
If this is some issue with the original master for the collection you're trying to rip from, then I'd try a different edition. Try a UK one, for example, 25 bucks for 1-4 from zavvi.
https://www.zavvi.com/blu-ray/the-ultim ... 70444.html
