I realise this is probably a permissions issue but I cant seem to work it out, other programs can create and save files to the mapped network drive OK. MakeMKV creates the appropriate directory and rips the disc but fails right at the very end of the rip, log:
Operation sucessfully completed
Saving 1 titles into directory Z:/TempMkv/TITLE
Failed to save title 0 to file Z:/TempMkv/TITLE/title00.mkv
0 titles saved, 1 failed
What is MakeMKV doing right at the end of the rip? Any ideas how I can fix this?
Failing to finalise files on Samba share
setarip_old
Re: Failing to finalise files on Samba share
Hi!
Please post the log in its entirety
Krobar
Debug log started at Thu Apr 15 21:27:57 2010 , written by MakeMKV v1.5.3 beta win(x64-release)
001005:0000 MakeMKV v1.5.3 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Krobar/MakeMKV_log.txt
DISCID=C16637FBBB3F210BB587C6C883072CCEDCD5B9C8
003025:0000 Title #00002.mpls has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00004.mpls was added as title #0
003025:0000 Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #1
003307:0000 File 00009.m2ts was added as title #2
003307:0000 File 00010.m2ts was added as title #3
003307:0000 File 00011.m2ts was added as title #4
003307:0000 File 00012.m2ts was added as title #5
003307:0000 File 00013.m2ts was added as title #6
003307:0000 File 00014.m2ts was added as title #7
003307:0000 File 00015.m2ts was added as title #8
003307:0000 File 00016.m2ts was added as title #9
003025:0000 Title #00017.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00022.m2ts was added as title #10
003025:0000 Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00024.m2ts was added as title #11
003307:0000 File 00025.m2ts was added as title #12
003025:0000 Title #00026.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00028.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00030.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory Z:/TempMkv/THIS_IS_ENGLAND_BD
001003:0020 DEBUG: Code 49 at "Ab)>3nf.#"H\,y3>P :29397426
FS ID=V_MPEG4/ISO/AVC C=49
C_00000=ZeNpjMBOLPp7MwPAfChigQGHOCgUQ/R8NMAPFmICYDYgZoWoZGdYyW8A4QGlOAyDJmvGSw1QVyBBkY+RhYGhgSLjQYMHAwMzA0QAUdHScxcQ7wT//36pQkBgCiQag8vEgoCEM9icXKNxk+fafbHNAhsg/yuAwc7TdT5Eh3F8o8hEA77Q5/A==
C_00001=ZeNpreL0j9HgyA8N/KGCAgYebFUDUfzTAAhRjgmJGqFJGhrXMloxwnUycAUCSNeMlh6kqkCHExsgDUsrMcKFBAkRxNABFHRnnsbA+EbwNEkAgzQWofPwIaAiD/ckHDnGOsvvJNgdkiPyjCgHxCe75FBnC/YUiHwEAZb0z0w==
C_00002=ZeNo7MCE94ngyA8N/KGCAggcF2xVA9H80wAIUYwJiEM0IUuDN0ACiLRhhOhmYOAOAJGvGSw5TVSBDkI2Rh4GxgYHhQoMGAwMzAweQyeDIOI+F84ngbZAAAmkuQOXjR0BDGOxPPnCY5yi7n2xzQIbIP6oQUJ/gnk+RIdxfKPIRAE0iNN0=
C_00003=ZeNo7oKqUfDyZgeE/FDBAwYM7mxVA9H80wAwUYwJiHiBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyAPSknChIYOBgZmBowEo6Og4i0XSRfj2v1WhIDEEEg1A5eNBQEMY7E8ucJziaLufbHNAhsg/yhBIFfDPp8gQ7i8U+QgAlbY6aQ==
C_00004=ZeNpzuH0k9ngyA8N/KGCAAofpKxRA9H80wAIUYwJiDiBmBCnwZmgA0RaMMJ0MTJwBQJI14yWHqSqQIcjGyMPA1MDAcKHBg4GBmYEDyGRwZJzHJvhE8DZIAIE0F6Dy8SOgIQz2Jx8kyjnK7ifbHJAh8o8qJNwnuOdTZAj3F4p8BADPATSE
C_00005=ZeNpraChOOJ7MwPAfChigICFnmwKI/o8GWIBiTEDMBcSMIAXeDA0g2pIRppOBiTMASLJmvOQwVQUyhNgYeRiYGYDoQkMEiOJoAIo6Ms5jE30ieJsBIgVFmgtQ+fgR0BAG+5MPEuMcZfeTbQ7IEPlHFRLhE9zzKTKE+wtFPgIAHPo0Dg==
C_00006=ZeNprENXLPp7MwPAfChigoOH1DgUQ/R8NMAPFmIBYCIgZQQq8GRpAtAUjTCcDE6cBkGTNeMlhqgpkCLIx8jAwNzAkXGiYwcDAzMDRABR0dJzFppoifPvfqlCQGAKJBqDy8SCgIQz2JxckhTna7ifbHJAh8o8yJKZO8M+nyBDuLxT5CAAaiTuP
C_00007=ZeNpjOH0h9XgyA8N/KGCAgXubFUDUfzTAAhRjAmI+IGYEKfBmaADRloxwnUycAUCSNeMlh6kqkCHExsjDANTGzHChoQJEcTQARR0Z53HIPhG8DRJAIM0FqHz8CGgIg/3JB433HGX3k20OyBD5RxUK5RPc8ykyhPsLRT4CADwfNUs=
C_00008=ZeNpzKKjPOJ7MwPAfChigYMPJHQog+j8aYAGKMQGxABAzghR4MzSAaAtGmE4GJs4AIMma8ZLDVBXIEGRj5GFgaWBguNDQwcDAzMABZDI4Ms7jUHwieBskgECaC1D5+BHQEAb7kw+a5Bxl95NtDsgQ+UcVCu0T3PMpMoT7C0U+AgB67jVo
C_00009=ZeNpjSOguOJ7MwPAfChhg4OpmBRD1Hw0wA8WYgFgMiBlBCrwZGkC0BSNcJxOnAZBkzXjJYaoKZAiyMfIwsDIwOFxo2MHAwMzA0QAUdHScxaGjMO/+v1WhIDEEEg1A5eNBQEMY7E8uaDrE+fY/2eaADJF/lKGwoam6niJDuL9Q5CMAgFE85A==
C_00010=ZeNo7sOtO7vFkBob/UMAABQo3NyuA6P9ogAUoxgTEIkDMCFLgzdAAoi0YYToZmDgDgCRrxksOU1UgQ5CNkYeBtYGB4ULDCgYGZgYOIJPBkXEel+YTwdsgAQTSXIDKx4+AhjDYn3ywaJ6j7H6yzQEZIv+oQmP5BPd8igzh/kKRjwBMADcQ
C_00011=ZeNpzYLUqPp7MwPAfChhg4MZmBRD1Hw0wAcWYoEoYQdiboQFEl3DCdTJxCgBJrfQUBs01OksZH3DMn84YxMTE1MDA+IWBIfZASQCDwIYEBv318j0FZW08rg1A1awZLzlMVYEMPjYGzgaG2n4GBmYGBgeQlCAbIw8DGwODwoWGEyBRDqAgk0NqR4MCg9jtf9839jf6nvZwnW7VVSX/UHTjlwmBVRtvLkh5BTYAjlgb4ntWPCoAs/NBpNAFBgZ2DgYGFh0gjzkARKiAiA4Q8QMoDrSLI4OBQQDoF4kFDAzWaObxoPJH0ZBDwDTEYH+ig4mBMXf/aDIaReSmIflHSgwNDNH5o2loFJGbhri/jFZno4hcBAAyq6Zp
C_00012=ZeNpj+OpafTyZgeE/FDBAwYLrmxVA9H80wAwUYwJiNiBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyMPA0MCQcKHhBwMDMwNHA1DQ0XEWE+8E//x/q0JBYggkGoDKx4OAhjDYn1ygcJPl23+yzQEZIv8og8PM0XY/RYZwf6HIRwChYjyr
C_00013=ZeNprWPWi9HgyA8N/KGCAggXbVyiA6P9ogAUoxgTFjCAF3gwNINqSEaaTgYkzAEiyZrzkMFUFMoTYGHlASpkZLjTcAFEcDUBRR8Z5LKxPBG+DBBBIcwEqHz8CGsJgf/KBQ5yj7H6yzQEZIv+oQkB8gns+RYZwf6HIRwAQKTUo
C_00014=ZeNo74D+94ngyA8N/KGCAggf3NyuA6P9ogAUoxgTEIJoRpMCboQFEWzDCdDIwcQYASdaMlxymqkCGIBsjDwNjAwPDhYYXDAzMDBxAJoMj4zwWzieCt0ECCKS5AJWPHwENYbA/+cBhnqPsfrLNARki/6hCQH2Cez5FhnB/ochHANFTNhc=
C_00015=ZeNo78CSw+XgyA8N/KGCAggfF2xVA9H80wAwUYwJiHiBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyAPSknChUYOBgZmBowEo6Og4i0XSRfj2v1WhIDEEEg1A5eNBQEMY7E8ucJziaLufbHNAhsg/yhBIFfDPp8gQ7i8U+QgAW0U60w==
C_00016=ZeNpzmPWl9ngyA8N/KGCAgoSi7Qog+j8aYAGKMQExBxAzghR4MzSAaAtGmE4GJs4AIMma8ZLDVBXIEGRj5GFgamBguNAI1MTMwAFkMjgyzmMTfCJ4GySAQJoLUPn4EdAQBvuTDxLlHGX3k20OyBD5RxUS7hPc8ykyhPsLRT4CAK49NF4=
C_00017=ZeNprsF/ccDyZgeE/FDBAQcOHFQog+j8aYAGKMQExFxAzghR4MzSAaEtGmE4GJs4AIMma8ZLDVBXIEGJj5GFgZgCiC40SIIqjASjqyDiPTfSJ4G0GiBQUaS5A5eNHQEMY7E8+SIxzlN1PtjkgQ+QfVUiET3DPp8gQ7i8U+QgAxaw0dA==
C_00018=ZeNpruBLbfTyZgeE/FDBAgcKVFQog+j8aYAaKMQGxEBAzghR4MzSAaAtGmE4GJk4DIMma8ZLDVBXIEGRj5GFgbmBIuNAYwcDAzMDRABR0dJzFppoifPvfqlCQGAKJBqDy8SCgIQz2JxckhTna7ifbHJAh8o8yJKZO8M+nyBDuLxT5CACu/zvX
C_00019=ZeNpj6GJoO57MwPAfChigoOHdDgUQ/R8NsADFmICYD4gZQQq8GRpAtCUjTCcDE2cAkGTNeMlhqgpkCLEx8jAAtTEzXGi0AFEcDUBRR8Z5HLJPBG+DBBBIcwEqHz8CGsJgf/JB4z1H2f1kmwMyRP5RhUL5BPd8igzh/kKRjwBeJTSx
C_00020=ZeNpz0F/fcTyZgeE/FDBAgcKeFQog+j8aYAGKMQGxABAzghR4MzSAaAtGmE4GJs4AIMma8ZLDVBXIEGRj5GFgaWBguNDowcDAzMABZDI4Ms7jUHwieBskgECaC1D5+BHQEAb7kw+a5Bxl95NtDsgQ+UcVCu0T3PMpMoT7C0U+AgBTMTSL
C_00021=ZeNpjkN894XgyA8N/KGCAgoS3OxRA9H80wAwUYwJiMSBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyMPAysDgcKGxgoGBmYGjASjo6DiLQ0dh3v1/q0JBYggkGoDKx4OAhjDYn1zQdIjz7X+yzQEZIv8oQ2FDU3U9RYZwf6HIRwAEwz0x
C_00022=ZeNo7UMnTdzyZgeE/FDDAwPsVCiDqPxpgAYoxAbEIEDOCFHgzNIBoC0a4TibOACDJmvGSw1QVyBBkY+RhYG1gYLjQmMHAwMzAAWQyODLO49J8IngbJIBAmgtQ+fgR0BAG+5MPFs1zlN1PtjkgQ+QfVWgsn+CeT5Eh3F8o8hEAegw1zA==
C_00023=ZeNpzOJI5+XgyA8N/KGCAgW87FEDUfzTABBRjgiphBGFvhgYQXcwJ18nEKQAktdJTGDTX6CxlfMAxfzpjEBMTUwMD4xcGhtgDJQEMAhsSGPTXy/cUlLXxuDYAVbNmvOQwVQUy+NgYOBsYavsZGJgZGBxAUgJsjDwMbAwMChcaOIBO4gCKMTmkdjQYMIjd/vd9Y3+j72kP1+lWXVXyD0U3fpkQWLXx5oKUV2D9cMTaEN+z4lEBmJ0PIoUuMDCwczAwsOgAecwBIEIFRHSAiB9A8RNAmzKAlgO9IrGAgcEazTweVP4oGnIImIYY7E90MDMw5u4fTUajiNw0JP9IieEAQ3T+aBoaReSmIe4vo9XZKCIXAQCdRqdW
C_00024=ZeNpj2FI6+3gyA8N/KGCAgoRvOxRA9H80wAwUYwJiNiBmBCnwZmgA0eaMMJ0MTJwGQJI14yWHqSqQIcDGyMPA0MCQcKHBAmgkRwNQzNFxFhPvBP/8f6tCGRiYkZBoACofDwIawmB/coHCTZZv/8k2B2SI/KMMDjNH2/0UGcL9hSIfAQC2Ajv5
C_00025=ZeNpryJSYdjyZgeE/FDBAwQOVlQog+j8aYAGKMUExI0iBN0MDiLZghOlkYOIMAJKsGS85TFWBDEE2Rh6QUmaGCw0SQDM5GoCCjozzWFifCN4GCSOQ5gJUPn4ENITB/uQDhzhH2f1kmwMyRP5RhYD4BPd8igzh/kKRjwBTcTNB
C_00026=ZeNo7wHd8xvFkBob/UMAABQskVyqA6P9ogAUoxgTEIJoRpMCboQFEmzPCdDIwcQYASdaMlxymqkCGABsjDwNjAwPDhQYNoJEcQBaDI+M8Fs4ngrcZGJiRkOYCVD5+BDSEwf7kA4d5jrL7yTYHZIj8owoB9Qnu+RQZwv2FIh8BAIi6NHE=
C_00027=ZeNo7sLhx8fFkBob/UMAABQkKKxVA9H80wAwUYwJiHiBmBCnwZmgA0eaMMJ0MTJwGQJI14yWHqSqQIcDGyAPSknChIQNoJEcDUMzRcRaLpIvw7X+rQhkYmJGQaAAqHw8CGsJgf3KB4xRH2/1kmwMyRP5RhkCqgH8+RYZwf6HIRwBvmzpb
C_00028=ZeNpziFSZdzyZgeE/FDBAgYLcSgUQ/R8NsADFmICYA4gZQQq8GRpAtDkjTCcDE2cAkGTNeMlhqgpkCLAx8jAwNTAwXGjwABrJAWQxODLOYxN8InibgYEZCWkuQOXjR0BDGOxPPkiUc5TdT7Y5IEPkH1VIuE9wz6fIEO4vFPkIAJnrMyY=
C_00029=ZeNpr+HdpwfFkBob/UMAABQ7Z2xRA9H80wAIUYwJiLiBmBCnwZmgA0RaMMJ0MTJwBQJI14yWHqSqQIcjGyMPAzABEFxoigGZyNAAFHRnnsYk+EbzNAJGBIs0FqHz8CGgIg/3JB4lxjrL7yTYHZIj8owqJ8Anu+RQZwv2FIh8BAJvzNSU=
C_00030=ZeNprmNy7+ngyA8N/KGCAgoSfOxRA9H80wAwUYwJiISBmBCnwZmgA0eaMMJ0MTJwGQJI14yWHqSqQIcDGyMPA3MCQcKFhBtBIjgagmKPjLDbVFOHb/1aFMjAwIyHRAFQ+HgQ0hMH+5IKkMEfb/WSbAzJE/lGGxNQJ/vkUGcL9hSIfAQCs/Dy1
C_00031=ZeNpj8DRYdjyZgeE/FDDAwM8dCiDqPxpgAYoxATEfEDOCFHgzNIBoC0a4TibOACDJmvGSw1QVyBBkY+RhAGpjZrjQUAE0k6MBKOjIOI9D9ongbZAwAmkuQOXjR0BDGOxPPmi85yi7n2xzQIbIP6pQKJ/gnk+RIdxfKPIRAA3uNKU=
C_00032=ZeNpzeHdvxfFkBob/UMAABQt+7FAA0f/RAAtQjAmIBYCYEaTAm6EBRJszwnQyMHEGAEnWjJccpqoglWyMPAwsDQwMFxo6gEZyAFkMjozzOBSfCN5mYGBGQpoLUPn4EdAQBvuTD5rkHGX3k20OyBD5RxUK7RPc8ykyhPsLRT4CAFNnNr8=
C_00033=ZeNpjuPdqw/FkBob/UMAABQ4/diiA6P9ogBkoxgTEYkDMCFLgzdAAos0ZYToZmDgNgCRrxksOU1UgQ4CNkYeBFWjihQaQkRwNQDFHx1kcOgrz7v9bFcrAwIyERANQ+XgQ0BAG+5MLmg5xvv1PtjkgQ+QfZShsaKqup8gQ7i8U+QgAwoI+hA==
C_00034=ZeNo7YGGz7ngyA8N/KGCAAof3OxRA9H80wAIUYwJiESBmBCnwZmgA0eaMMJ0MTJwBQJI14yWHqSqQIcDGyMPA2sDAcKFhBdBIDiCLwZFxHpfmE8HbDAzMSEhzASofPwIawmB/8sGieY6y+8k2B2SI/KMKjeUT3PMpMoT7C0U+AgBDvDaF
C_00035=ZeNpzaJ65+XgyA8N/KGCAggcXVyiA6P9ogAkoxgRVwwjC3gwNILqUE6aTgYlTAEhqpacwaK7RWcr4gGP+dMYgJiamBgbGLwwMsQdKAhgENiQw6K+X7ykoa+NxbQCqZs14yWGqCmTwsTFwNjDU9jMwMDMwOICkBNgYeRjYGBgULjScADqJAyjG5Jja0SDAwLrt/7/vG/sbfU97uE636qqSfyi68cuEwKqNNxekvAIbAEesDfE9Kx4VgNn5IFLoAgMDOwcDA4sOkMccACJUQEQHiPgBFD8BtCoDaDvQLxILGBis0czjQeWPoiGHmBxSGexPdAATb3T+aDIaReSmIflHSgwODGK3R9PQKCIrDTmmMnB/Ga3PRhHZCACJUalo
C_00036=ZeNpjKF66+3gyA8N/KGCAAoU7mxVA9H80wAwUYwJiNiBmBCnwZmgA0eaMMJ0MTJwGQJI14yWHqSqQIcDGyMPA0MCQcKHhB9BIjgagmKPjLCbeCf75/1aFMjAwIyHRAFQ+HgQ0hMH+5AKFmyzf/pNtDsgQ+UcZHGaOtvspMoT7C0U+AgAX7jxp
C_00037=ZeNpr0PDYdjyZgeE/FDBAgcL3HQog+j8aYAGKMUExI0iBN0MDiLZghOlkYOIMAJKsGS85TFWBDEE2Rh6QUmaGCw03gGZyNAAFHRnnsbA+EbwNEkYgzQWofPwIaAiD/ckHDnGOsvvJNgdkiPyjCgHxCe75FBnC/YUiHwEAbWg0Mg==
C_00038=ZeNo7cPbbjuPJDAz/oYABChasWKEAov+jARagGBMQg2hGkAJvhgYQbc4I08nAxBkAJFkzXnKYqgIZAmyMPAyMDQwMFxpeAI3kALIYHBnnsXA+EbzNwMCMhDQXoPLxI6AhDPYnHzjMc5TdT7Y5IEPkH1UIqE9wz6fIEO4vFPkIAMJRNs0=
C_00039=ZeNo7kLTx8PFkBob/UMAABQnmGxRA9H80wAwUYwJiHiBmBCnwZmgA0eaMMJ0MTJwGQJI14yWHqSqQIcDGyAPSknChUQNoJEcDUMzRcRaLpIvw7X+rQhkYmJGQaAAqHw8CGsJgf3KB4xRH2/1kmwMyRP5RhkCqgH8+RYZwf6HIRwBrfTpJ
C_00040=ZeNpzkAjZdzyZgeE/FDBAwYJbmxVA9H80wAIUYwJiDiBmBCnwZmgA0eaMMJ0MTJwBQJI14yWHqSqQIcDGyMPA1MDAcKGRA2gkB5DF4Mg4j03wieBtBgZmJKS5AJWPHwENYbA/+SBRzlF2P9nmgAyRf1Qh4T7BPZ8iQ7i/UOQjAD2YNDw=
C_00041=ZeNpr2Mt08HgyA8N/KGCAgbc7FEDUfzTAAhRjAmIuIGYEKfBmaADRFoxwnUycAUCSNeMlh6kqkCHIxsjDwMwARBcaJYBmcjQABR0Z57GJPhG8zQCRgSLNBah8/AhoCIP9yQeJcY6y+8k2B2SI/KMKifAJ7vkUGcL9hSIfAQBJtzQ6
C_00042=ZeNprCNp7+ngyA8N/KGCAggffdyiA6P9ogBkoxgTEQkDMCFLgzdAAos0ZYToZmDgNgCRrxksOU1UgQ4CNkYeBuYEh4UJjBNBIjgagmKPjLDbVFOHb/1aFMjAwIyHRAFQ+HgQ0hMH+5IKkMEfb/WSbAzJE/lGGxNQJ/vkUGcL9hSIfAQAytD0D
C_00043=ZeNpj4Eg4djyZgeE/FDDAwO3NCiDqPxpgAYoxATEfEDOCFHgzNIBoC0a4TibOACDJmvGSw1QVyBBkY+RhAGpjZrjQaAE0k6MBKOjIOI9D9ongbZAwAmkuQOXjR0BDGOxPPmi85yi7n2xzQIbIP6pQKJ/gnk+RIdxfKPIRAKzLNFI=
C_00044=ZeNpzWMt38ngyA8N/KGCAgoRXOxRA9H80wAIUYwJiASBmBCnwZmgA0eaMMJ0MTJwBQJI14yWHqSpIJRsjDwNLAwPDhUYPoJEcQBaDI+M8DsUngrcZGJiRkOYCVD5+BDSEwf7kgyY5R9n9ZJsDMkT+UYVC+wT3fIoM4f5CkY8AMQ41Qg==
C_00045=ZeNpjmCt18XgyA8N/KGCAggUPNiuA6P9ogBkoxgTEYkDMCFLgzdAAos0ZYToZmDgNgCRrxksOU1UgQ4CNkYeBlYHB4UJjBdBIjgagmKPjLA4dhXn3/60KZWBgRkKiAah8PAhoCIP9yQVNhzjf/ifbHJAh8o8yFDY0VddTZAj3F4p8BABwKz2Y
C_00046=ZeNo78D373PFkBob/UMAABQ7HVyiA6P9ogAUoxgTEIkDMCFLgzdAAos0ZYToZmDgDgCRrxksOU1UgQ4CNkYeBtYGB4UJjBtBIDiCLwZFxHpfmE8HbDAzMSEhzASofPwIawmB/8sGieY6y+8k2B2SI/KMKjeUT3PMpMoT7C0U+AgBJSzcc
C_00047=ZeNpzcDp5+XgyA8N/KGCAggWfdiiA6P9ogAkoxgRVwwjC3gwNILqUE6aTgYlTAEhqpacwaK7RWcr4gGP+dMYgJiamBgbGLwwMsQdKAhgENiQw6K+X7ykoa+NxbQCqZs14yWGqCmTwsTFwNjDU9jMwMDMwOICkBNgYeRjYGBgULjRwODAwcADFmBxTOxpEGFi3/f/3fWN/o+9pD9fpVl1V8g9FN36ZEFi18eaClFdgA+CItSG+Z8WjAjA7H0QKXWBgYOdgYGDRAfKYA0CECojoABE/gOIngFZlAG0H+kViAQODNZp5PKj8UTTkEJNDKoP9iQ5GB4bo/NFkNIrITUPyj5QYAhjEbo+moVFEVhpyTGXg/jJan40ishEAAHSpIA==
C_00048=ZeNpjMLp6+3gyA8N/KGBAA//RADNQjAmI2YCYEaTAm6EBRJszwrUwcRoASdaMlxymqkCGABsjDwNDA0PChQYLBwYGjgagmKPjLCbeCf75/1aFMjAwIyHRAFQ+HgQ0hMH+5AKFmyzf/pNtDsgQ+UcZHGaOtvspMoT7C0U+AgDonToJ
001003:0020 DEBUG: Code 0 at >R~KYSg$Ab7Km^77ly11G:29397449
005003:0000 Failed to save title 0 to file Z:/TempMkv/THIS_IS_ENGLAND_BD/title00.mkv
005004:0000 0 titles saved, 1 failed
NomadCF
silly question, is this a Bluray your trying to backup to a network share ?
Krobar
Yessilly question, is this a Bluray your trying to backup to a network share ?
NomadCF
Can you try it with a DVD and see if you have the same issue. I'm thinking you won't, but it would be nice to know.
Krobar
I'm trying a series DVD now, the 800MB-1.1GB files it is creating seem to be working fine. I can copy 35GB Blueray files from a local drive to the same Samba share and they copy OK. I can rip blu-rays directly to my old Windows 2000 Server too.
Changing from the mapped drive to UNC doesnt seem to help either:
Debug log started at Thu Apr 15 22:36:43 2010 , written by MakeMKV v1.5.3 beta win(x64-release)
005014:0000 Saving 1 titles into directory //192.168.0.220/Data0/TempMkv/THIS_IS_ENGLAND_BD
C_00000=ZeNpjMBOLPp7MwPAfChigwEDgkAKI/o8GmIFiTEDMBsSMULWMDHeZLWAcoDSnAZBkzXjJYaoKZAiyMfIwMDQwJFxosGBgYGbgaAAKOjrOYuKd4J//b1UoSAyBRANQ+XgQ0BAG+5MLFG6yfPtPtjkgQ+QfZXCYOdrup8gQ7i8U+QgAn4w5yg==
C_00001=ZeNpreL0j9HgyA8N/KGCAggW1+xVA9H80wAIUY4JiRqhaRoa7zJYwDlCKMwBIsma85DBVBTKE2Bh5QEqZGS40SIAojgagqCPjPBbWJ4K3QQIIpLkAlY8fAQ1hsD/5wCHOUXY/2eaADJF/VCEgPsE9nyJDuL9Q5CMACnA0Sw==
C_00002=ZeNo7MCE94ngyA8N/KGCAggnJWxRA9H80wAIUYwJiEM0IUuDN0ACiLRhhOhmYOAOAJGvGSw5TVSBDkI2Rh4GxgYHhQoMGAwMzAweQyeDIOI+F84ngbZAAAmkuQOXjR0BDGOxPPnCY5yi7n2xzQIbIP6oQUJ/gnk+RIdxfKPIRAMMmNH0=
C_00003=ZeNo7oKqUfDyZgeE/FDBAgcGrLQog+j8aYAaKMQExDxAzghR4MzSAaAtGmE4GJk4DIMma8ZLDVBXIEGRj5AFpSbjQkMHAwMzA0QAUdHScxSLpInz736pQkBgCiQag8vEgoCEM9icXOE5xtN1PtjkgQ+QfZQikCvjnU2QI9xeKfAQAric5yA==
C_00004=ZeNpzuH0k9ngyA8N/KGCAgbr9CiDqPxpgAYoxATEHEDOCFHgzNIBoC0a4TibOACDJmvGSw1QVyBBkY+RhYGpgYLjQ4MHAwMzAAWQyODLOYxN8IngbJIBAmgtQ+fgR0BAG+5MPEuUcZfeTbQ7IEPlHFRLuE9zzKTKE+wtFPgIAcAw0Qg==
C_00005=ZeNpraChOOJ7MwPAfChigwKH2sAKI/o8GWIBiTEDMBcSMIAXeDA0g2pIRppOBiTMASLJmvOQwVQUyhNgYeRiYGYDoQkMEiOJoAIo6Ms5jE30ieJsBIgVFmgtQ+fgR0BAG+5MPEuMcZfeTbQ7IEPlHFRLhE9zzKTKE+wtFPgIAGe00DA==
C_00006=ZeNprENXLPp7MwPAfChigYAPHIQUQ/R8NMAPFmIBYCIgZQQq8GRpAtAUjTCcDE6cBkGTNeMlhqgpkCLIx8jAwNzAkXGiYwcDAzMDRABR0dJzFppoifPvfqlCQGAKJBqDy8SCgIQz2JxckhTna7ifbHJAh8o8yJKZO8M+nyBDuLxT5CAAoWTrm
C_00007=ZeNpjOH0h9XgyA8N/KGCAAoO3WxRA9H80wAIUYwJiPiBmBCnwZmgA0ZaMMJ0MTJwBQJI14yWHqSqQIcTGyMMA1MbMcKGhAkRxNABFHRnnccg+EbwNEkAgzQWofPwIaAiD/ckHjfccZfeTbQ7IEPlHFQrlE9zzKTKE+wtFPgIAmE41iw==
C_00008=ZeNpzKKjPOJ7MwPAfChigQKFpvwKI/o8GWIBiTEAsAMSMIAXeDA0g2oIRppOBiTMASLJmvOQwVQUyBNkYeRhYGhgYLjR0MDAwM3AAmQyOjPM4FJ8I3gYJIJDmAlQ+fgQ0hMH+5IMmOUfZ/WSbAzJE/lGFQvsE93yKDOH+QpGPAFAYNJg=
C_00009=ZeNpjSOguOJ7MwPAfChig4EHNYQUQ/R8NMAPFmIBYDIgZQQq8GRpAtAUjTCcDE6cBkGTNeMlhqgpkCLIx8jCwMjA4XGjYwcDAzMDRABR0dJzFoaMw7/6/VaEgMQQSDUDl40FAQxjsTy5oOsT59j/Z5oAMkX+UobChqbqeIkO4v1DkIwBZqT17
C_00010=ZeNo7sOtO7vFkBob/UMAABQkRVmD6PxpgAYoxAbEIEDOCFHgzNIBoC0aYTgYmzgAgyZrxksNUFcgQZGPkYWBtYGC40LCCgYGZgQPIZHBknMel+UTwNkgAgTQXoPLxI6AhDPYnHyya5yi7n2xzQIbIP6rQWD7BPZ8iQ7i/UOQjABRkNjY=
C_00011=ZeNpzYLUqPp7MwPAfChigoKFmvwKI/o8GmIBiTFA1jCDszdAAoks4YToZmDgFgKRWegqD5hqdpYwPOOZPZwxiYmJqYGD8wsAQe6AkgEFgQwKD/nr5noKyNh7XBqBq1oyXHKaqQAYfGwNnA0NtPwMDMwODA0hKkI2Rh4GNgUHhQsMJkCgHUJDJIbWjQYFB7Pa/7xv7G31Pe7hOt+qqkn8ouvHLhMCqjTcXpLwCGwBHrA3xPSseFYDZ+SBS6AIDAzsHAwOLDpDHHAAiVEBEB4j4ARQH2sWRwcAgAPSLxAIGBms083hQ+aNoyCFgGmKwP9HBxMCYu380GY0ictOQ/CMlhgaG6PzRNDSKyE1D3F9Gq7NRRC4CAANNppk=
C_00012=ZeNpj+OpafTyZgeE/FDBAwYSHuxVA9H80wAwUYwJiNiBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyMPA0MCQcKHhBwMDMwNHA1DQ0XEWE+8E//x/q0JBYggkGoDKx4OAhjDYn1ygcJPl23+yzQEZIv8og8PM0XY/RYZwf6HIRwCkKDyt
C_00013=ZeNprWPWi9HgyA8N/KGCAgob6/Qog+j8aYAGKMUExI0iBN0MDiLZkhOlkYOIMAJKsGS85TFWBDCE2Rh6QUmaGCw03QBRHA1DUkXEeC+sTwdsgAQTSXIDKx4+AhjDYn3zgEOcou59sc0CGyD+qEBCf4J5PkSHcXyjyEQCyczTn
C_00014=ZeNo74D+94ngyA8N/KGCAgg2vtyiA6P9ogAUoxgTEIJoRpMCboQFEWzDCdDIwcQYASdaMlxymqkCGIBsjDwNjAwPDhYYXDAzMDBxAJoMj4zwWzieCt0ECCKS5AJWPHwENYbA/+cBhnqPsfrLNARki/6hCQH2Cez5FhnB/ochHAJ71NfQ=
C_00015=ZeNo78CSw+XgyA8N/KGCAggUJhxVA9H80wAwUYwJiHiBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyAPSknChUYOBgZmBowEo6Og4i0XSRfj2v1WhIDEEEg1A5eNBQEMY7E8ucJziaLufbHNAhsg/yhBIFfDPp8gQ7i8U+QgA9SE6jA==
C_00016=ZeNpzmPWl9ngyA8N/KGCAggmvtiiA6P9ogAUoxgTEHEDMCFLgzdAAoi0YYToZmDgDgCRrxksOU1UgQ5CNkYeBqYGB4UIjUBMzAweQyeDIOI9N8IngbZAAAmkuQOXjR0BDGOxPPkiUc5TdT7Y5IEPkH1VIuE9wz6fIEO4vFPkIAJsKNQM=
C_00017=ZeNprsF/ccDyZgeE/FDBAQQDHIQUQ/R8NsADFmICYC4gZQQq8GRpAtCUjTCcDE2cAkGTNeMlhqgpkCLEx8jAwMwDRhUYJEMXRABR1ZJzHJvpE8DYDRAqKNBeg8vEjoCEM9icfJMY5yu4n2xyQIfKPKiTCJ7jnU2QI9xeKfAQAWDMzdg==
C_00018=ZeNpruBLbfTyZgeE/FDBAwYe3WxRA9H80wAwUYwJiISBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyMPA3MCQcKExgoGBmYGjASjo6DiLTTVF+Pa/VaEgMQQSDUDl40FAQxjsTy5ICnO03U+2OSBD5B9lSEyd4J9PkSHcXyjyEQAPHDzM
C_00019=ZeNpj6GJoO57MwPAfChig4ELtFgUQ/R8NsADFmICYD4gZQQq8GRpAtCUjTCcDE2cAkGTNeMlhqgpkCLEx8jAAtTEzXGi0AFEcDUBRR8Z5HLJPBG+DBBBIcwEqHz8CGsJgf/JB4z1H2f1kmwMyRP5RhUL5BPd8igzh/kKRjwApSTSM
C_00020=ZeNpz0F/fcTyZgeE/FDBAQULjfgUQ/R8NsADFmIBYAIgZQQq8GRpAtAUjTCcDE2cAkGTNeMlhqgpkCLIx8jCwNDAwXGj0YGBgZuAAMhkcGedxKD4RvA0SQCDNBah8/AhoCIP9yQdNco6y+8k2B2SI/KMKhfYJ7vkUGcL9hSIfAQB7fjSn
C_00021=ZeNpjkN894XgyA8N/KGCAgg+8hxRA9H80wAwUYwJiMSBmBCnwZmgA0RaMMJ0MTJwGQJI14yWHqSqQIcjGyMPAysDgcKGxgoGBmYGjASjo6DiLQ0dh3v1/q0JBYggkGoDKx4OAhjDYn1zQdIjz7X+yzQEZIv8oQ2FDU3U9RYZwf6HIRwCg4Dzr
C_00022=ZeNo7UMnTdzyZgeE/FDBAwYU3WxRA9H80wAIUYwJiESBmBCnwZmgA0RaMMJ0MTJwBQJI14yWHqSqQIcjGyMPA2gA0sjGDgYGZgQPIZHBknMel+UTwNkgAgTQXoPLxI6AhDPYnHyya5yi7n2xzQIbIP6rQWD7BPZ8iQ7i/UOQjALH2NqU=
C_00023=ZeNpzOJI5+XgyA8N/KGCAggPVhxVA9H80wAQUY4KqYQRhb4YGEF3MCdPJwMQpACS10lMYNNfoLGV8wDF/OmMQExNTAwPjFwaG2AMlAQwCGxIY9NfL9xSUtfG4NgBVs2a85DBVBTL42Bg4Gxhq+xkYmBkYHEBSAmyMPAxsDAwKFxo4gE7iAIoxOaR2NBgwiN3+931jf6PvaQ/X6VZdVfIPRTd+mRBYtfHmgpRXYP1wxNoQ37PiUQGYnQ8ihS4wMLBzMDCw6AB5zAEgQgVEdICIH0DxE0CbMoCWA70isYCBwRrNPB5U/igacgiYhhjsT3QwMzDm7h9NRqOI3DQk/0iJ4QBDdP5oGhpF5KYh7i+j1dkoIhcBAKNIp6Y=
C_00024=ZeNpj2FI6+3gyA8N/KGCAAoWawwog+j8aYAaKMQExGxAzghR4MzSAaHNGmE4GJk4DIMma8ZLDVBXIEGBj5GFgaGBIuNBgATSSowEo5ug4i4l3gn/+v1WhDAzMSEg0AJWPBwENYbA/uUDhJsu3/2SbAzJE/lEGh5mj7X6KDOH+QpGPALt2O0o=
C_00025=ZeNpryJSYdjyZgeE/FDBAwYRTWxRA9H80wAIUY4JiRpACb4YGEG3BCNPJwMQZACRZM15ymKoCGYJsjDwgpcwMFxokgGZyNAAFHRnnsbA+EbwNEkYgzQWofPwIaAiD/ckHDnGOsvvJNgdkiPyjCgHxCe75FBnC/YUiHwEA3iUzog==
C_00026=ZeNo7wHd8xvFkBob/UMAABQH7tyiA6P9ogAUoxgTEIJoRpMCboQFEmzPCdDIwcQYASdaMlxymqkCGABsjDwNjAwPDhQYNoJEcQBaDI+M8Fs4ngrcZGJiRkOYCVD5+BDSEwf7kA4d5jrL7yTYHZIj8owoB9Qnu+RQZwv2FIh8BABMcNNI=
C_00027=ZeNo7sLhx8fFkBob/UMAABQLHtiiA6P9ogBkoxgTEPEDMCFLgzdAAos0ZYToZmDgNgCRrxksOU1WQSWyMPCAtCRcaMoBGcjQAxRwdZ7FIugjf/rcqlIGBGQmJBqDy8SCgIQz2Jxc4TnG03U+2OSBD5B9lCKQK+OdTZAj3F4p8BAD57jq8
C_00028=ZeNpziFSZdzyZgeE/FDBAwYXDWxRA9H80wAIUYwJiDiBmBCnwZmgA0eaMMJ0MTJwBQJI14yWHqSqQIcDGyMPA1AA0ssEDaCQHkMXgyDiPTfCJ4G0GBmYkpLkAlY8fAQ1hsD/5IFHOUXY/2eaADJF/VCHhPsE9nyJDuL9Q5CMAke40hg==
C_00029=ZeNpr+HdpwfFkBob/UMAABR+eb1EA0f/RAAtQjAmIuYCYEaTAm6EBRFswwnQyMHEGAEnWjJccpqpAhiAbIw8DMwMQXWiIAJrJ0QAUdGScxyb6RPA2A0QGijQXoPLxI6AhDPYnHyTGOcruJ9sckCHyjyokwie451NkCPcXinwEAEf5Nk8=
C_00030=ZeNprmNy7+ngyA8N/KGCAAoX6wwog+j8aYAaKMQGxEBAzghR4MzSAaHNGmE4GJk4DIMma8ZLDVBXIEGBj5GFgbmBIuNAwA2gkRwNQzNFxFptqivDtf6tCGRiYkZBoACofDwIawmB/ckFSmKPtfrLNARki/yhDYuoE/3yKDOH+QpGPALJwPAY=
C_00031=ZeNpj8DRYdjyZgeE/FDBAwYG6wwog+j8aYAGKMQExHxAzghR4MzSAaAtGmE4GJs4AIMma8ZLDVBXIEGRj5GEAamNmuNBQATSTowEo6Mg4j0P2ieBtkDACaS5A5eNHQEMY7E8+aLznKLufbHNAhsg/qlAon+CeT5Eh3F8o8hEAgVM09Q==
C_00032=ZeNpzeHdvxfFkBob/UMAABQl1hxVA9H80wAIUYwJiASBmBCnwZmgA0eaMMJ0MTJwBQJI14yWHqSpIJRsjDwNLAwPDhYYOoJEcQBaDI+M8DsUngrcZGJiRkOYCVD5+BDSEwf7kgyY5R9n9ZJsDMkT+UYVC+wT3fIoM4f5CkY8AWNs2EA==
C_00033=ZeNpjuPdqw/FkBob/UMAAA3WHFUDUfzTADBRjAmIxIGYEKfBmaADR5oxwnUycBkCSNeMlh6kqkCHAxsjDwMrA4HChYQfQSI4GoJij4ywOHYV59/+tCmVgYEZCogGofDwIaAiD/ckFTYc43/4n2xyQIfKPMhQ2NFXXU2QI9xeKfAQAx/Y91Q==
C_00034=ZeNo7YGGz7ngyA8N/KGCAgg3vtiiA6P9ogAUoxgTEIkDMCFLgzdAAos0ZYToZmDgDgCRrxksOU1UgQ4CNkYeBtYGB4ULDCqCRHEAWgyPjPC7NJ4K3GRiYkZDmAlQ+fgQ0hMH+5INF8xxl95NtDsgQ+UcVGssnuOdTZAj3F4p8BADdKjbw
C_00035=ZeNpzaJ65+XgyA8N/KGCAAoeswwog+j8aYAKKMUHVMIKwN0MDiC7lhOlkYOIUAJJa6SkMmmt0ljI+4Jg/nTGIiYmpgYHxCwND7IGSAAaBDQkM+uvlewrK2nhcG4CqWTNecpiqAhl8bAycDQy1/QwMzEBHgKQE2Bh5GNgYGBQuNJwAOokDKMbkmNrRIMDAuu3/v+8b+xt9T3u4TrfqqpJ/KLrxy4TAqo03F6S8AhsAR6wN8T0rHhWA2fkgUugCAwM7BwMDiw6QxxwAIlRARAeI+AEUPwG0KgNoO9AvEgsYGKzRzONB5Y+iIYeYHFIZ7E90ABNvdP5oMhpF5KYh+UdKDA4MYrdH09AoIisNOaYycH8Zrc9GEdkIAJ1/qHw=
C_00036=ZeNpjKF66+3gyA8N/KGCAAoeEwwog+j8aYAaKMQExGxAzghR4MzSAaHNGmE4GJk4DIMma8ZLDVBXIEGBj5GFgaGBIuNDwA2gkRwNQzNFxFhPvBP/8f6tCGRiYkZBoACofDwIawmB/coHCTZZv/8k2B2SI/KMMDjNH2/0UGcL9hSIfAQCrRzwd
C_00037=ZeNpr0PDYdjyZgeE/FDBAgUL9fgUQ/R8NsADFmKCYEaTAm6EBRFswwnQyMHEGAEnWjJccpqpAhiAbIw9IKTPDhYYbQDM5GoCCjozzWFifCN4GCSOQ5gJUPn4ENITB/uQDhzhH2f1kmwMyRP5RhYD4BPd8igzh/kKRjwDLUzPB
C_00038=ZeNo7cPbbjuPJDAz/oYABCg7U7VcA0f/RAAtQjAmIQTQjSIE3QwOINmeE6WRg4gwAkqwZLzlMVYEMATZGHgbGBgaGCw0vgEZyAFkMjozzWDifCN5mYGBGQpoLUPn4EdAQBvuTDxzmOcruJ9sckCHyjyoE1Ce451NkCPcXinwEANTwNto=
C_00039=ZeNo7kLTx8PFkBob/UMAABQ9SDyuA6P9ogBkoxgTEPEDMCFLgzdAAos0ZYToZmDgNgCRrxksOU1UgQ4CNkQekJeFCowbQSI4GoJij4ywWSRfh2/9WhTIwMCMh0QBUPh4ENITB/uQCxymOtvvJNgdkiPyjDIFUAf98igzh/kKRjwB/5zsK
C_00040=ZeNpzkAjZdzyZgeE/FDBAwYG4wwog+j8aYAGKMQExBxAzghR4MzSAaHNGmE4GJs4AIMma8ZLDVBXIEGBj5GFgamBguNDIATSSA8hicGScxyb4RPA2AwMzEtJcgMrHj4CGMNiffJAo5yi7n2xzQIbIP6qQcJ/gnk+RIdxfKPIRANDxM/A=
C_00041=ZeNpr2Mt08HgyA8N/KGCAggVphxVA9H80wAIUYwJiLiBmBCnwZmgA0RaMMJ0MTJwBQJI14yWHqSqQIcjGyMPAzABEFxolgGZyNAAFHRnnsYk+EbzNAJGBIs0FqHz8CGgIg/3JB4lxjrL7yTYHZIj8owqJ8Anu+RQZwv2FIh8BAH3oNF4=
C_00042=ZeNprCNp7+ngyA8N/KGCAgoam/Qog+j8aYAaKMQGxEBAzghR4MzSAaHNGmE4GJk4DIMma8ZLDVBXIEGBj5GFgbmBIuNAYATSSowEo5ug4i001Rfj2v1WhDAzMSEg0AJWPBwENYbA/uSApzNF2P9nmgAyRf5QhMXWCfz5FhnB/ochHAAu6PDU=
C_00043=ZeNpj4Eg4djyZgeE/FDBAQUPqYQUQ/R8NsADFmICYD4gZQQq8GRpAtAUjTCcDE2cAkGTNeMlhqgpkCLIx8jAAtTEzXGi0AJrJ0QAUdGScxyH7RPA2SBiBNBeg8vEjoCEM9icfNN5zlN1PtjkgQ+QfVSiUT3DPp8gQ7i8U+QgA0oE0bA==
C_00044=ZeNpzWMt38ngyA8N/KGCAgoCsLQog+j8aYAGKMQGxABAzghR4MzSAaHNGmE4GJs4AIMma8ZLDVBWkko2Rh4GlgYHhQqMH0EgOIIvBkXEeh+ITwdsMDMxISHMBKh8/AhrCYH/yQZOco+x+ss0BGSL/qEKhfYJ7PkWGcH+hyEcAXVs0rg==
C_00045=ZeNpjmCt18XgyA8N/KGCAggdJhxVA9H80wAwUYwJiMSBmBCnwZmgA0eaMMJ0MTJwGQJI14yWHqSqQIcDGyMPAysDgcKGxAmgkRwNQzNFxFoeOwrz7/1aFMjAwIyHRAFQ+HgQ0hMH+5IKmQ5xv/5NtDsgQ+UcZChuaquspMoT7C0U+AgAulz1q
C_00046=ZeNo78D373PFkBob/UMAABQ5V+xVA9H80wAIUYwJiESBmBCnwZmgA0eaMMJ0MTJwBQJI14yWHqSqQIcDGyMPA2sDAcKExA2gkB5DF4Mg4j0vzieBtBgZmJKS5AJWPHwENYbA/+WDRPEfZ/WSbAzJE/lGFxvIJ7vkUGcL9hSIfAQD78Tbm
C_00047=ZeNpzcDp5+XgyA8N/KGCAgoSKwwog+j8aYAKKMUHVMIKwN0MDiC7lhOlkYOIUAJJa6SkMmmt0ljI+4Jg/nTGIiYmpgYHxCwND7IGSAAaBDQkM+uvlewrK2nhcG4CqWTNecpiqAhl8bAycDQy1/QwMzAwMDiApATZGHgY2BgaFCw0cDgwMHEAxJsfUjgYRBtZt//9939jf6Hvaw3W6VVeV/EPRjV8mBFZtvLkg5RXYADhibYjvWfGoAMzOB5FCFxgY2DkYGFh0gDzmABChAiI6QMQPoPgJoFUZQNuBfpFYwMBgjWYeDyp/FA05xOSQymB/ooPRgSE6fzQZjSJy05D8IyWGAAax26NpaBSRlYYcUxm4v4zWZ6OIbAQAYyyocQ==
005003:0000 Failed to save title 0 to file //192.168.0.220/Data0/TempMkv/THIS_IS_ENGLAND_BD/title00.mkv
NomadCF
Yep, Your running into a speed (meaning network overflow, destination hard disk speed VS cache / OS caching VS writing) / sync issue. You'll be fine with the smaller files and such, but to be honest you really shouldn't be ripping directly to a share anyways. As at any time you could get a nic error and the file wont be "complete", yet the copy will tell you it finished with out errors. It's like trying to store a users maildir on a NFS mount... not a good idea.
Your best bet is always to rip locally, then copy with a verification (for this I use rsync, but for a normal windows app I'd recommend Fastcopy. As it can do a copy with a MD5/other file check & compare).
I've run into this issue allot, especially when I was using my PS3 to rip my bluray to my server. In order to resolve the issue, with the PS3 ripping to a mount (samba). I ended up upgrading my network to gigabit. This resolved the issue as the PS3 only has a 10/100 nic in it. So it was unable to "flood" the server. But this issue would still happen when I was ripping from my mini ripping/media station to the server. This was due to the new 1 GB nic, so I replaced it with a 10/100 and everything started to work issue free again.
This summer I'm planning on bonding to 1GB nics and try going back to 1GB nics in my ripping/media station.... and see what happens (I am worried about flooding the switch though, even it the specs do say it has a 4GB back plane.. I worry until the real world examples/tests prove it right
Krobar
Hi Nomad,
Interesting.... Strange that Windows 2000 server can handle it. Speed on samba is excellent, I get 100-108Mbyte/sec constantly without jumbo frames. I can also unreliably rip 3 blurays at full 8x speed directly to the same share. Destination is a raid6 array, it sustains 400Mbyte/sec+ with a full 512MB write cache so I dont think the destination disk would have trouble keeping up. I did notice that MakeMKVs method for sharing bandwidth is strange, if you start multiple rips then the first rips to start will work at full speed until the server at the other end cant handle any more and all rips started after saturation point are very slow (But the rips started first still run at full speed). With my old Win2K server I could sustain two rips at 30mbytes/sec each (Without errors) but the third rip to run simultaneously would be capped at 5-10mbyte/sec, Makemkv would use the full write bandwidth the server was capable of but would not share it evenly among the processes.
Is it some sort of checksum that is being done at the very end of the makemkv rip? I find it strange that it always fails right at the end and that I have no trouble copying these large files using windows explorer. Also, the 30ish mbyte/sec generated by a single makemkv rip is nowhere near the 100-110Mbyte/sec copying this NAS can manage.
I have two onboard Intel NICs on my new NAS and will probably do an 802.3ad bond once I have a suitable switch, I hardly need it though since max rip rate will only just exceed 120Mbyte/sec.
Anyway, nice to hear I'm not alone.
Krobar
Does code 49 mean a non compliant video stream?
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=1181
NomadCF
I think your right, as This is England has a video steam of 24/fps instead of normal 23.976. I wonder is that is screwing with it ?
There is a confirmed error in MakeMKV causing this error for SOME mpeg4/avc INTERLACED streams. The error will be corrected in the next version.
Krobar
Re: Problems with A Few Good Men & This Is England BD
Hi Mike,
Yes that is it, I was unlucky enough that the first 2 BD Rips I tried to my new Samba server are both incompatible with the current version. Just tried two different BDs and they ripped perfectly; there is no problem with Samba or ripping directly to a network drive with my setup.
