MOVED: DVDs with LPCM and DTS fail
dtblair
#1 Post by dtblair » Mon Apr 12, 2010 9:59 pm
DVDs of concerts that have a LPCM audio track as well as DTS fail. Process goes to the end then states "0 files saved, 1 failed" This happens on both Eagles, Hell Freezes Over and Michael Buble Meets Madison Square Garden.
Re: MOVED: DVDs with LPCM and DTS fail
#2 Post by mike admin » Thu Apr 15, 2010 8:07 am
Can you please check if it happens when you select only DVD, only LPCM or no audio tracks at all? Also, please enable debug output per http://www.makemkv.com/faq/item/8/catid/6 .
dtblair
#3 Post by dtblair » Thu Apr 15, 2010 3:21 pm
If you include the LPCM track, the process fails. Selecting only the DD or DTS will create the mkv file. Here is the debug:
Debug log started at Thu Apr 15 14:48:24 2010 , written by MakeMKV v1.5.4 beta win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.5.4 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\dtblair/MakeMKV_log.txt
003028:0000 Title #0 was added (18 cell(s), 1:01:16)
003028:0000 Title #1 was added (1 cell(s), 0:03:43)
003028:0000 Title #2 was added (1 cell(s), 0:05:11)
003028:0000 Title #3 was added (1 cell(s), 0:03:53)
003028:0000 Title #4 was added (1 cell(s), 0:03:37)
003025:0000 Title #5 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #6 was added (1 cell(s), 0:05:34)
003028:0000 Title #7 was added (1 cell(s), 0:04:22)
003028:0000 Title #8 was added (1 cell(s), 0:04:12)
003028:0000 Title #9 was added (1 cell(s), 0:03:12)
003028:0000 Title #10 was added (1 cell(s), 0:03:33)
003028:0000 Title #11 was added (1 cell(s), 0:03:55)
003028:0000 Title #12 was added (1 cell(s), 0:04:21)
003028:0000 Title #13 was added (1 cell(s), 0:05:10)
003028:0000 Title #14 was added (1 cell(s), 0:03:56)
003025:0000 Title #15 has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003033:0000 Cell 2 was discarded (structure protection?)
003028:0000 Title #16 was added (1 cell(s), 0:03:16)
003028:0000 Title #17 was added (1 cell(s), 0:03:00)
001003:0020 DEBUG: Code 60 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 1123 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 156 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 1347 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 456 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 675 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 108 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 3 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 360 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 899 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 384 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 451 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 396 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 372 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 180 at ^4&\sXm#;v+5Jct;!?y@r:29395747
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory D:/Video/MICHAEL_BUBLE_MEETS_MSG
001003:0020 DEBUG: Code 4294967295 at "c%M(nS~J8/oD"=9L|9:121262003
001003:0020 DEBUG: Code 0 at <Zr43L,U*{|De(MQ/Rq*:213130513
001003:0020 DEBUG: Code 1931276 at <Zr43L,U*{|De(MQ/Rq*:213129639
005003:0000 Failed to save title 0 to file D:/Video/MICHAEL_BUBLE_MEETS_MSG/title00.mkv
005004:0000 0 titles saved, 1 failed
Application exited at Thu Apr 15 14:59:38 2010
