Jurassic Park Blu Ray
awoell
Post by awoell »
Hey guys,
I've been trying to encode a BluRay of Jurassic Park, but I keep getting this Posix error. The disc looks flawless, so I'm not sure what's going on. Any help?
File 00300.m2ts was added as title #1
Title #50277.m2ts has length of 70 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #50278.m2ts has length of 72 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #50283.m2ts has length of 93 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #50284.m2ts has length of 37 seconds which is less than minimum title length of 500 seconds and was therefore skipped
File 00301.m2ts was added as title #2
File 00302.m2ts was added as title #3
File 00303.m2ts was added as title #4
File 00305.m2ts was added as title #5
Title #00306.m2ts has length of 129 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00307.m2ts has length of 380 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00308.m2ts has length of 119 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00309.m2ts has length of 184 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00310.m2ts has length of 441 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00311.m2ts has length of 392 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00312.m2ts has length of 85 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00321.m2ts has length of 78 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #00322.m2ts has length of 283 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Title #50285.m2ts has length of 290 seconds which is less than minimum title length of 500 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Seagate Backup+
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '24828377088'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '24828377088'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '24828379136'
Re: Jurassic Park Blu Ray
Internal or external drive?
A number of external drives have issues with power if you spin them at full speed, which few applications can. MakeMKV is one that can, so drives fail during rips. The errors in the log imply that the drive went off-line during a long read (about 24GB into the title), which is where it would be reaching maximum speed.
