Hunger Games - Catching Fire
sandking
Post by sandking »
I've read numerous posts/threads about this and the security Lionsgate seems to put on these hunger game movies. I have the retail BR,dvd and Digital version of the disks and can't seem to get MKV to save a copy. I also downloaded AnyDVD to try and get the correct source file name which says 00778.mpls as others have previously posted.
That being said I feel like I have the correct version but it keeps failing at the end. Is there anything I am doing wrong? This is very frustrating, i want these movies on my media server.
Re: Hunger Games - Catching Fire
Play list discussion for Catching Fire: http://makemkv.com/forum2/viewtopic.php?f=1&t=7661
"Failing" as in error messages? Enable debug logging (link in my signature) and post the log here. We can only guess at what is going on from your description so far.
sandking
Post by sandking »
Thanks Woodstock. I've read that thread and many others from this forum and other forums. I am retrying now and will post the log file. Where can I find the log file once it fails? Is it the information located a the bottom section of MakeMKV?
sandking
Post by sandking »
Is this the log:
Saving 1 titles into directory E:/
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00501.m2ts' at offset '11805388800'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00501.m2ts' at offset '11805720576'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00501.m2ts' at offset '11807748096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00501.m2ts' at offset '11809320960'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '11809320960'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '11809325056'
DEBUG: Code 3221225628 at m\<}c9ZOfCO[p%-X"m:121262969
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00501.m2ts' at offset '11809320960'
DEBUG: Code 100864261 at m\<}c9ZOfCO[p%-X"m:121262969
DEBUG: Code 0 at ^sn-7'9lk#*zI%}tr!g-:121263291
DEBUG: Code 0 at n7~l+lH59WZ+0;g$ai?L:121262302
DEBUG: Code 0 at ^sn-7'9lk#*zI%}tr!g-:213130812
DEBUG: Code 5766270 at ^sn-7'9lk#*zI%}tr!g-:29393286
DEBUG: Code 0 at 4W~5;,qVF!rkp['%ZSgF\:29398967
Failed to save title 120 to file E://The_Hunger_Games_Catching_Fire_t120.mkv
0 titles saved, 1 failed
Yes, that's the log, and it says your drive is having a problem reading the disk in places.
Have you cleaned the disk? Fingerprints can cause these issues. Scratches, too.
sandking
Post by sandking »
I will check that out next. Ugh really something that simple lol. I tried burning an ISO with AnyDVDHd to see if I could use MakeMKV on the ISO but halfway through I got a bad sector message:
Error reading from drive D:!
Sectors: 12174848-12174879
sandking
Post by sandking »
Ok I completely give up on these Hunger Game movies. Still get the same problem after cleaning the disk. Decided to try the first Hunger Games movie. AnyDVD said version 665 was the right one. Ran MakeMKV and it skipps 665 because it says it's the same as version 76. So I burn an ISO of the disk and try and use MakeMKV on version 76 of the ISO. Still fails.
What the heck am I doing wrong here? This is ridiculous that these studios don't allow you to backup your own movies.
