The Martian - US
egorss78
The Martian - US
Post by egorss78 » Fri Jan 15, 2016 8:30 pm
Saw a thread on the candian version, but I have a US version (bought from target). When attempting to rip, the log shows the information below. What else should I provide?
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from C:\Users\Shaun/.MakeMKV/00000175.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00350.mpls has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00351.mpls has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00352.mpls has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00227.mpls has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00231.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00230.mpls has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00020.mpls has length of 54 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00199.mpls has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00800.mpls and was skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #01756.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00957.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00233.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00952.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00197.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00192.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00193.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00194.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00195.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00196.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00727.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02167.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02168.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02169.m2ts has length of 5 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02166.m2ts has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02152.m2ts has length of 10 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #01757.m2ts has length of 6 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02195.m2ts has length of 84 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #00021.m2ts has length of 27 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #01780.m2ts has length of 9 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #01781.m2ts has length of 0 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02176.m2ts has length of 200 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02177.m2ts has length of 453 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02178.m2ts has length of 215 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02179.m2ts has length of 219 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02180.m2ts has length of 63 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02181.m2ts has length of 94 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02182.m2ts has length of 1038 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02183.m2ts has length of 663 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02184.m2ts has length of 853 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02185.m2ts has length of 175 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Title #02188.m2ts has length of 4 seconds which is less than minimum title length of 3600 seconds and was therefore skipped
Saving 1 titles into directory E:/Video/The_Martian
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/02175.m2ts' at offset '23618973696'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '23618973696'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '23618977792'
Failed to save title 0 to file E:/Video/The_Martian/The_Martian_t00.mkv
0 titles saved, 1 failed
Re: The Martian - US
Post by Woodstock » Sat Jan 16, 2016 12:15 am
First question is whether this is an internal or external drive? Many external drives can show similar hardware errors when they start spinning faster than their available power allows, but there have been cases where internal drives will do it, too.
egorss78
Post by egorss78 » Sun Jan 17, 2016 8:40 pm
Woodstock wrote:First question is whether this is an internal or external drive? Many external drives can show similar hardware errors when they start spinning faster than their available power allows, but there have been cases where internal drives will do it, too.
Internal drive, and tried another bluray right after and it ripped without issue. Tried the disk again this morning and same error.
Wondering if anyone else had tried yet and had any success?
buckwyld
Post by buckwyld » Wed Jan 20, 2016 10:18 am
I was able to rip the US version, also bought from Target. Here's my log. I have an Asus internal Bluray drive.
Loaded 111 SVQ file(s)
Processing BD+ code using disc-specific SVQ from C:\Users\chris/.MakeMKV/00000175.svq
Saving 1 titles into directory X:/Video
Forced subtitles track #2 turned out to be empty and was removed from output file
1 titles saved
egorss78
Post by egorss78 » Wed Jan 20, 2016 1:56 pm
Thanks for the reply, at least I know it is not a BR/SW thing. Will work on my drive to see what I can resolve.
