No sound from Blu Ray
Jokerman
Post by Jokerman » Tue Jan 12, 2016 5:00 pm
I converted a Blu Ray disc to mkv file. The picture quality is excellent but there is no sound on the movie. There is sound on the extras. It may be a DTS problem. I am using the Beta version. Any suggestions would be appreciated.
Re: No sound from Blu Ray
Post by Woodstock » Tue Jan 12, 2016 5:23 pm
What player are you using? Does it allow you to select audio tracks during playback? What happens if you play the MKV file with a player that understands more audio track encodings, such as VLC from Videolan.org?
Jokerman
Post by Jokerman » Wed Jan 13, 2016 6:01 pm
I copied the Blu Ray disc a third time. There is still no sound when I play it back on computer using Windows 7 Media Player. But there is sound when I play it back on the TV using Western Digital Media Player. Problem solved. Thanks for your help.
Krawk
Post by Krawk » Wed Jan 13, 2016 9:00 pm
Two solutions for your computer;
1) Get a Codec pack, such as K-Lite from free-codecs.com - This is one of the most complete and easy to install codec packs
2) Try KODI player. It is a player that uses minimal codecs.
