MOVED: DVDs with LPCM and DTS fail
DVDs of concerts that have a LPCM audio track as well as DTS fail.  Process goes to the end then states "0 files saved, 1 failed"  This happens on both Eagles, Hell Freezes Over and Michael Buble Meets Madison Square Garden.
 - Contact:
Re: MOVED: DVDs with LPCM and DTS fail
Can you please check if it happens when you select only DVD, only LPCM or no audio tracks at all? Also, please enable debug output per http://www.makemkv.com/faq/item/8/catid/6 .
If you include the LPCM track, the process fails.  Selecting only the DD or DTS will create the mkv file.  Here is the debug:
Debug log started at Thu Apr 15 14:48:24 2010 , written by MakeMKV v1.5.4 beta win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.5.4 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\dtblair/MakeMKV_log.txt
003028:0000 Title #0 was added (18 cell(s), 1:01:16)
003028:0000 Title #1 was added (1 cell(s), 0:03:43)
003028:0000 Title #2 was added (1 cell(s), 0:05:11)
003028:0000 Title #3 was added (1 cell(s), 0:03:53)
003028:0000 Title #4 was added (1 cell(s), 0:03:37)
003025:0000 Title #5 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #6 was added (1 cell(s), 0:05:34)
003028:0000 Title #7 was added (1 cell(s), 0:04:22)
003028:0000 Title #8 was added (1 cell(s), 0:04:12)
003028:0000 Title #9 was added (1 cell(s), 0:03:12)
003028:0000 Title #10 was added (1 cell(s), 0:03:33)
003028:0000 Title #11 was added (1 cell(s), 0:03:55)
003028:0000 Title #12 was added (1 cell(s), 0:04:21)
003028:0000 Title #13 was added (1 cell(s), 0:05:10)
003028:0000 Title #14 was added (1 cell(s), 0:03:56)
003025:0000 Title #15 has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003033:0000 Cell 2 was discarded (structure protection?)
003028:0000 Title #16 was added (1 cell(s), 0:03:16)
003028:0000 Title #17 was added (1 cell(s), 0:03:00)
001003:0020 DEBUG: Code 60 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 1123 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 156 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 1347 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 456 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 675 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 108 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 3 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 360 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 899 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 384 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 451 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 396 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 372 at ^4&\sXm#;v+5Jct;!?y@r:29395747
001003:0020 DEBUG: Code 180 at ^4&\sXm#;v+5Jct;!?y@r:29395747
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory D:/Video/MICHAEL_BUBLE_MEETS_MSG
001003:0020 DEBUG: Code 4294967295 at "c%M(nS~J8/oD"=9L|9:121262003
001003:0020 DEBUG: Code 0 at <Zr43L,U*{|De(MQ/Rq*:213130513
001003:0020 DEBUG: Code 1931276 at <Zr43L,U*{|De(MQ/Rq*:213129639
005003:0000 Failed to save title 0 to file D:/Video/MICHAEL_BUBLE_MEETS_MSG/title00.mkv
005004:0000 0 titles saved, 1 failed
Application exited at Thu Apr 15 14:59:38 2010
