"The Odd Life of Timothy Green" fails
lightsout
#1 Post by lightsout » Sun Jan 10, 2016 11:37 pm
I am getting a lot of errors on this title. Can't seem to rip it. Any thoughts? I have the "read retry count" set to 30 in the "IO" section of the app settings. Still didn't help.
MakeMKV v1.9.8 win(x64-release) started
File 00800.mpls was added as title #0
File 00250.mpls was added as title #1
Title #00000.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00255.mpls was added as title #2
Title 00813.mpls is equal to title 00800.mpls and was skipped
Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00527.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00874.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00875.m2ts was added as title #3
File 00876.m2ts was added as title #4
Title #00878.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00879.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00880.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00881.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00882.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00883.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00884.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00885.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00886.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00887.m2ts was added as title #5
Title #00888.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00889.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00890.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00891.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00892.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00893.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00894.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00895.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00896.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory J:/Rips/The Odd Life of Timothy Green
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6008537088'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6008537088'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6008537088'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6008733696'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6008733696'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6008733696'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6008733696'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009126912'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6009126912'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6009126912'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009126912'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009255936'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6009255936'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6009257984'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009323520'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6009323520'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6009323520'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009323520'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009452544'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6009452544'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6009454592'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6009520128'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6009520128'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6012991488'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6013581312'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6013581312'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6013583360'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6013583360'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6014828544'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6015614976'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6015614976'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6015614976'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6016204800'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6016204800'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6016204800'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '6016204800'
Failed to save title 0 to file J:/Rips/The Odd Life of Timothy Green/The_Odd_Life_of_Timothy_Green_t00.mkv
0 titles saved, 1 failed
Re: "The Odd Life of Timothy Green" fails
#2 Post by Woodstock » Mon Jan 11, 2016 2:08 am
Unfortunately, this has its roots in a Windows issue:
Windows claims it can't read the disk. Possibilities include Windows not communicating with the hardware, the disk is damaged or was manufactured incorrectly, or the disk is simply dirty.
The first thing to try in this case is resetting the computer. Not "just" rebooting, but powering it down, to make sure your hardware completely resets. This error does not normally show up for "just" a dirty disk, but it often occurs when the hardware is in an unstable state. If it were a USB external drive, I'd unplug it and power it down, then plug it in, but that's harder to do with internal drives, hence the "full reset" advice.
lightsout
#3 Post by lightsout » Mon Jan 11, 2016 5:18 am
Woodstock wrote:Unfortunately, this has its roots in a Windows issue:
Thanks man. It was an internal drive. I will give it a go tomorrow. The disc looks fine but it does have a tiny nick at the very edge. Doesn't seem like it should be enough to be an issue though.
#4 Post by Woodstock » Mon Jan 11, 2016 6:29 am
Test with a different disk, as well.
My opinion is that, while DVD is a mediocre media for storing data, BD took everything bad about DVD and made it less tolerant of damage. The need to focus on the (supposedly protected) media surface is critical to reading the data from the disk, so surface scratches and such can be critical...
But what some people never notice is when the edges (especially the hub area) get cracks or separations. The surface looks fine, but a slight separation can move the data surface out of focus. If you move the disk around while viewing it at an angle, the "rainbow pattern" of the reflective dots can sometimes show the discontinuity. If you see what looks like a "stress pattern" that points toward the nick... That is bad news.
