Pacific RIM
zorin1
Pacific RIM
Post by zorin1 »
I am trying to rip the Pacific Rim Blu-Ray movie and I am getting errors. I have tried clean the disk but get the same errors. Here is a copy of the log below. I am not sure if I have a bad disk or what and hope someone could help:
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176121344, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176127488, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176133632, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176145920, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176152064, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176158208, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176164352, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176176640, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176182784, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176188928, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176195072, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176201216, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176207360, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176213504, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176219648, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176225792, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176238080, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176250368, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176256512, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176262656, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176268800, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176274944, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176281088, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176293376, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176299520, attempting to work around
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '25670320128'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '25176305664'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '25176305664'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '25176305664'
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176311808, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176317952, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176324096, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176330240, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176336384, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176342528, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176354816, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176360960, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176373248, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176379392, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176385536, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176397824, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176403968, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176410112, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176422400, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176428544, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176434688, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176471552, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176483840, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176502272, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176508416, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176514560, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176520704, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176526848, attempting to work around
The source file '/BDMV/STREAM/00011.m2ts' is corrupt or invalid at offset 25176532992, attempting to work around
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '25176539136'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '25176539136'
AV synchronization issues were found in file 'D:/video/mkv/Pacific_Rim/Pacific_Rim_t00.mkv' (title #1)
AV sync issue in stream 1 at 1:28:02.058 with duration of 149.333ms : audio gap - 14 missing frame(s)
AV sync issue in stream 1 at 1:28:02.218 with duration of 202.666ms : audio gap - 19 missing frame(s)
Failed to save title 0 to file D:/video/mkv/Pacific_Rim/Pacific_Rim_t00.mkv
0 titles saved, 1 failed
Re: Pacific RIM
Going to have to suggest cleaning, because Pacific Rim had no errors when I ripped it.
zorin1
Re: Pacific RIM
Post by zorin1 »
Woodstock wrote:Going to have to suggest cleaning, because Pacific Rim had no errors when I ripped it.
Thanks, I tried to rip it with anyDVD HD and had the same type of issue. I have cleaned the Blu-Ray again. I can't see anything wrong with it though when I look at it. Guess, I will just have to rip the DVD instead which sucks.
Re: Pacific RIM
These errors could be related to this... this isn't an external drive, is it?
zorin1
Re: Pacific RIM
Post by zorin1 »
I finally got AnyDvd HD to rip it using slow mode. I wish there was a way to slow down the blu-ray player from MakeMVK. There are a few things that I would like to see added. I'll have to make to another thread with my wish list that will never be met. :)
Re: Pacific RIM
There are ways to slow MakeMKV down... point the output at a slow-to-write directory, either on a network or on a local drive. But that's no fun, really.... ;)
If it is an external drive, the usual problem is insufficient power to run at full speed. There are ways to address that, but yes, a "speed limit" for MakeMKV could help.
