Cancel or suppress the M2TS verification
Yugatha
Post by Yugatha » Thu Jan 07, 2016 4:20 am
I've got a Bluray disc that fails the M2TS verification. I've tried two discs of the same movie, and both fail at exactly the same spot, leading me to believe that there may be something wrong with the authoring of the disc itself. Does anyone know if you can suppress it for one disc, or temporarily? OR delete the hash table from the Bluray and try again?
Line in Make MKV: Loaded content hash table, will verify integrity of M2TS files.
Error: (This fills up a 20mb log file)
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 1209532416, attempting to work around
tp=ZeNr79/9/Cef/rTv+/f///1pkt++f7tY1QHZ8XPSLXEYGhpOH/4ueEGRgDMgQMGNifN0O450xZWJ8WQbUAxPoAQmkAvnd/0O73zS/0eh25QjujmAJ6y7gCO+u5dGu4Ol2ENjJwMDAqP3z4H8m5o/dYsw3e1t2gES6OVpPVnD0NjIB2a+Z+bcztF7qdP1TGhf8X/QC0PTuH63/O2s5SmKyGMLD/os6CAGFPrR+KwUAablTCw==
001003:0020 DEBUG: Code 0 at ZU@,UmpZ>+>mm<.a)ben:121262647
tp=ZeNqLtNy749///yWc/7eC6P/XIrt9/3S3rgGy4+OiX+QyMjCcPPxf9IQgA2NAhoAZE+PrdhjvjCkT48syoB6YQA9IIBXI7/4f2v2m+Y1GtytHcHcES1h3AUd4dy2PdgVPt4PATgYGBkbtnwf/MzF/7BZjvtnbsgMk0s3RerKCo7eRCch+zcy/naH1Uqfrn9K44P+iF4Cmd/9o/d9Zy1ESk8UQHvZf1EEIKPSh9VspAOsxVRI=
tp=PjX3c86uLRQiJRfChMNELAYXAx0XYJAAAAIld5HQUjU3YUWoF/9DrClf/FbwRAAGJdQiDfQgAdBGLVQj/dfxS/xXMEQABhcB1Cf91/FPopYYCAItNDF9eiQFbycIIAIv/VYvsg+wQoTiaCQGFwHQHPUC7AAB1TVaNRfhQ/xVoEwABi3X8M3X4/xVkEwABM/D/FWATAAEz8P8VtBIAATPwjUXwUP8VXBMAAYtF9DNF8DPGJf//AABedQW4QLs=
tp=PK2oIWY193POri0UIiUXwoTDRCwGFwMdF2CQAAACJXeR0FI1N2FFqBf/Q6wpX/xW8EQABiXUIg30IAHQRi1UI/3X8Uv8VzBEAAYXAdQn/dfxT6KWGAgCLTQxfXokBW8nCCACL/1WL7IPsEKE4mgkBhcB0Bz1AuwAAdU1WjUX4UP8VaBMAAYt1/DN1+P8VZBMAATPw/xVgEwABM/D/FbQSAAEz8I1F8FD/FVwTAAGLRfQzRfAzxiX//wAAXnUFuEC7
tp=ZeNqbxcn4/cJik1mcjCcPW/NaAOlSzu8HGRj+/y9lPNz9P7T7TeMbBWYGhvDFP/ZwM3byfgGRoh9ApOwbEGn6AkTaPgGSaT2iAntBFC8LmJJ9ABZkvQOmVG+AKd0rQGpOPysHUEm3K0uvL0vzQZZOXh4gdzEDkDjO6gFUwMjAyACU6vb8s5gFyF0Iclin65+FIIca/3cHMrMYOgGnOkS5
tp=ZeNpjYFhsMYuT8fuFxSZA6uRha14Qt5Tz+0EGhv//SxkPd/8P7X7T+EaBmYEhfPGPPdyMnbxfQKToBxAp+wZEmr4AkbZPgGRaj6jAXhDFywKmZB+ABVnvgCnVG2BK9wqQmtPPygFU0u3K0uvL0nyQpZOXB8hdzAAkjrN6ABUwMjAyAKW6Pf8sZgFyF4Ic1un6ZyHIocb/3YHMLIZOAEmfRZQ=
tp=ZeNpjPM76Yzc3IycLw4FO2z9A1n9RFmEGxowMcyYgswDEBMvtffDn////ojpAgYD/ojlAKv7k4TkJL+5V/fyfODerIKMAqOEFLxMDg/Htztg/va4NQGUlQGXN5/931v5Ja7RlYGBg9I0qVV9oA2T0NoC4jRYBrgwMpSL82z0kGn9yMzIwlCgAaaAhJaydsU9eqzfvaAGq4yv7ZHzScsYPIPM1X3NFCV/ZIxD/BQDceUOD
tp=ZeNrj/bOHm/E464/d3IycLAwHOm3/AFn/RVmEGRgzMsyZgMwCEBMst/fBn////4vqAAUC/ovmAKn4k4fnJLy4V/Xzf+LcrIKMAqCGF7xMDAzGtztj//S6NgCVlQCVNZ//31n7J63RloGBgdE3qlR9oQ2Q0dsA4jZaBLgyMJSK8G/3kGj8yc3IwFCiAKSBhpSwdsY+ea3evKMFqI6v7JPxScsZP4DM13zNFSV8ZY9A/BcANgZFUw==
tp=ZeNqberDT98lx1z+MDAwMWUz/RW1EGRgjO21VsngYO201gOR/UQ+gUDevwn5uxk6O/6IhYJ4MmLfQBcRhWKwDVPci9Ojf/5ayNrM4GUt5MtKbWYA6l4gADXtxgpmBIYNjEgNjBguQeLEZyF0oAdLveqfX9U7Af1MRIKfX9UpAr+sFID4T8F+UAaix0/VEBgNI14+JQF21QF3NR1QWsoiAbOx0fdBgoQQAebI70Q==
tp=ZeNpjYGDgn3qw0/fJcdc/jAwMDFlM/0VtRBkYIzttVbJ4GDttNYDkf1EPoFA3r8J+bsZOjv+iIWCeDJi30AXEYVisA1T3IvTo3/+WsjazOBlLeTLSm1mAOpeIAA17cYKZgSGDYxIDYwYLkHixGchdKAHS73qn1/VOwH9TESCn1/VKQK/rBSA+E/BflAGosdP1RAYDSNePiUBdtUBdzUdUFrKIgGzsdH3QYKEEAITJO+A=
tp=ZeNpzfdDFYXW6hLXhp1LpxwYLpVIWh05XuJhC2cdvrmsYSwT5t/tueM3XYKFQ9gQk//prFldkYEBwBgMDA+OLuod//3d/6Cw9Yhn7pJQ97L8ohwgD439RHiDZWfvntWG365tujm7OTt8bAYEvXjAxMERGHu5OfdFdeqO59gkDWIcIWIcEkGz2/fO/+9hrAeMDDiBFIO6O/0BrXuQAicP/VUtEgSpVc0AkACsMUFk=
Re: Cancel or suppress the M2TS verification
Post by Woodstock » Thu Jan 07, 2016 4:49 am
I can't answer whether or not Mike provided a way to turn off the hash check, but... Those error say the disk failed the read before it GOT to the hash check! It is likely the rip of the mentioned tracks aborted before the end was reached.
Is this happening during a "Backup" or "Open/Save" read of the disk?
Yugatha
Post by Yugatha » Thu Jan 07, 2016 6:33 am
This is of a backup, yes, but it was also happening straight from the disc. With both discs (tried 2 different discs, same show), it failed at the exact same spot (1039.1 MB)
Both discs were cleaned (and were clean before) - no visible markings
