Missing title Shaun the Sheep? (or how to get right one)
dlaugh
Post by dlaugh » Wed Jan 06, 2016 5:58 am
Working off a Mac. Netflix SD version of Shaun the Sheep. 6 choices, info below. VLC identifies title 23 as the right one. But title 23 does not show up as an option. It looks like it scans in the log, but then I don't see it. Here is the relevant portion of the log:
DEBUG: Code 10551308 at %8u5l1Se9YW0.B4]:213142128
DEBUG: Code 0 at %8u5l1Se9YW0.B4]:213143301
DEBUG: Code 0 at VsR=F^GxEK%?]z_"Li:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #23 was added (17 cell(s), 1:25:11)
Cells 2-6 were skipped due to cell commands (structure protection?)
(I wasn't sure whether the right text precedes or follows the "Title #23 was added" line, so I included both.)
Name: Shaun the Sheep
Source title ID: 1
Duration: 1:28:41
Chapters count: 17
Segment count: 1
Segment map: 8-25
File name: Shaun_the_Sheep_t00.mv
Source title ID: 20
Duration: 1:30:33
Chapters count: 17
Segment count: 3
Segment map: 4,5-8,9-26
File name: Shaun_the_Sheep_t08.mv
Source title ID: 21
Duration: 1:25:11
Chapters count: 17
Segment count: 1
Segment map: 2-18
File name: Shaun_the_Sheep_t09.mv
Source title ID: 22
Duration: 1:28:41
Chapters count: 17
Segment count: 1
Segment map: 8-25
File name: Shaun_the_Sheep_t10.mv
Source title ID: 24
Duration: 1:28:41
Chapters count: 17
Segment count: 1
Segment map: 8-25
File name: Shaun_the_Sheep_t11.mv
Source title ID: 27
Duration: 1:28:41
Chapters count: 17
Segment count: 1
Segment map: 8-25
File name: Shaun_the_Sheep_t12.mkv
Krawk
Re: Missing title Shaun the Sheep? (or how to get right one)
Post by Krawk » Wed Jan 13, 2016 8:54 pm
As title 22, 24 and 27 have the same segment map either one should work.
It has been my experience however that when VLC reports a specific title and the title is missing from makemkv, it is usually the next title UP. When you click on title 24 it might indicate it really is title 23.
