The Book Thief
happytinfoilcat
The Book Thief
Post by happytinfoilcat »
My first time using the forum, please be gentle. :wink: Sent dump file a few days ago. It's odd that I can see everything on the Blu-Ray except the actual movie. My wild guess is this is a new encryption thingy. Is there a list of titles that do not work?
MakeMKV v1.9.8 win(x64-release) started
Downloading latest SVQ(s) to C:\Users\Happy/.MakeMKV ...
Loaded 11 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 00501.mpls was added as title #0
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00250.mpls has length of 10 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00251.mpls has length of 8 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00252.mpls has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00253.mpls has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00254.mpls has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00255.mpls has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00257.mpls has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 00020.mpls was added as title #1
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title 00800.mpls is equal to title 00501.mpls and was skipped
Title 00850.mpls is equal to title 00501.mpls and was skipped
Title #00300.mpls has length of 10 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 00320.mpls(1) was added as title #2
File 00331.mpls was added as title #3
File 00332.mpls was added as title #4
File 00333.mpls was added as title #5
File 00334.mpls was added as title #6
File 00335.mpls was added as title #7
File 00342.mpls was added as title #8
File 00343.mpls was added as title #9
File 00344.mpls was added as title #10
File 00345.mpls was added as title #11
File 00341.mpls was added as title #12
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00234.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00220.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00157.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00161.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00174.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00177.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00178.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00181.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00184.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00133.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01288.m2ts has length of 0 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 01395.m2ts was added as title #13
Title #01290.m2ts has length of 9 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01291.m2ts has length of 0 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01524.m2ts has length of 10 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01525.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01526.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01527.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 01528.m2ts was added as title #14
File 01529.m2ts was added as title #15
File 01530.m2ts was added as title #16
Title #01531.m2ts has length of 35 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 01532.m2ts was added as title #17
File 01533.m2ts was added as title #18
File 01534.m2ts was added as title #19
Title #01535.m2ts has length of 17 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01536.m2ts has length of 8 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01537.m2ts has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01538.m2ts has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01539.m2ts has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01540.m2ts has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01541.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Title #01542.m2ts has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 01543.m2ts was added as title #20
File 01544.m2ts was added as title #21
File 01545.m2ts was added as title #22
File 01546.m2ts was added as title #23
Title #01547.m2ts has length of 6 seconds which is less than minimum title length of 59 seconds and was therefore skipped
File 01548.m2ts was added as title #24
File 01549.m2ts was added as title #25
File 01550.m2ts was added as title #26
File 01551.m2ts was added as title #27
Title #01552.m2ts has length of 5 seconds which is less than minimum title length of 59 seconds and was therefore skipped
Saving 28 titles into directory Q:/Video/The_Book_Thief
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4011847680'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4011847680'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4011851776'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4018796544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4018796544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4018798592'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4037996544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4037996544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4038000640'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4403294208'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4403294208'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '4403298304'
Failed to save title 0 to file Q:/Video/The_Book_Thief/The_Book_Thief_t00.mkv
Title 3 skipped
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
Forced subtitles track #13 turned out to be empty and was removed from output file
Forced subtitles track #15 turned out to be empty and was removed from output file
Forced subtitles track #17 turned out to be empty and was removed from output file
Forced subtitles track #19 turned out to be empty and was removed from output file
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01558.m2ts' at offset '786432'
Failed to save title 11 to file Q:/Video/The_Book_Thief/The_Book_Thief_t11.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01558.m2ts' at offset '0'
Failed to save title 12 to file Q:/Video/The_Book_Thief/The_Book_Thief_t12.mkv
24 titles saved, 3 failed
Re: The Book Thief
This is your drive saying it can't read part of the track. First step is to clean the disk... it does not take much of a finger print or bit of haze on the disk to produce errors like this.
happytinfoilcat
Re: The Book Thief
Thanks. I tried that a few times. Even used some Pledge wax the last time. Maybe the disc is defective, I'll return it.
