Problem creating title for BluRay "Spring"
Ben182
Post by Ben182 »
i'm having trouble creating the main mkv title for the german BluRay "Spring". I bought 3 different pieces of the BluRay at 3 different
stores, just to make sure it's not a problem with the disc itself, before I finally came here to find fault with it. The error is as follows:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '3140812800'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '3140812800'
DEBUG: Code 3221225628 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 100864261 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 0 at VQ?KPz#O0.2t#((tB$W]:121263291
DEBUG: Code 0 at ZU@,UmpZ>+>mm<.a)ben:121262302
DEBUG: Code 0 at VQ?KPz#O0.2t#((tB$W]:213130812
DEBUG: Code 1533600 at VQ?KPz#O0.2t#((tB$W]:29393286
DEBUG: Code 0 at {)|99J8\#"anZMhP+JODd:29398967
DEBUG: Code 0 at S"[~`NJ+MyGfFJ./{o~:213132767
DEBUG: Code 0 at `/2rBcd~3KN\ORio4H*C:29403222
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:213131893
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:121263406
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:29393907
Failed to save title 1 to file C:/Work/Ripping/title01.mkv
0 titles saved, 1 failed
What can I do about it? And no, the 3 discs are okay/clean, have no scratches and play in every player! :)
Greetings from germany
ben
Re: Problem creating title for BluRay "Spring"
This is your hardware saying it cannot read parts of the disk. If it occurs at the same place on all three disks, and other bluray disks work, then it is probable that the disks have been manufactured incorrectly. If it moves around, especially if it moves if you try the same disk a second or third time, it can be in the drive itself.
This error I've never seen reported:
It could indicate that the drive itself is going off-line, or that it is simply saying, "I told you there was something wrong, now go away!" :)
Is it an internal or external drive?
Ben182
Post by Ben182 »
Hi Woodstock,
thanks for your reply. It is an internal drive and it always occurs at the same place. I guess the disc has been manufactured incorrectly then :(
Greets
Ben
One last test, though - try the "Backup" option, rather than "Open/save as MKV". Sometimes this works where the normal method doesn't. It usually will not make a difference if it is a physical defect in the disk, but some logical defects can be overcome. It's worth a try.
