i'm having trouble creating the main mkv title for the german BluRay "Spring". I bought 3 different pieces of the BluRay at 3 different
stores, just to make sure it's not a problem with the disc itself, before I finally came here to find fault with it. The error is as follows:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '3140812800'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '3140812800'
DEBUG: Code 3221225628 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 100864261 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 0 at VQ?KPz#O0.2t#((tB$W]:121263291
DEBUG: Code 0 at ZU@,UmpZ>+>mm<.a)ben:121262302
DEBUG: Code 0 at VQ?KPz#O0.2t#((tB$W]:213130812
DEBUG: Code 1533600 at VQ?KPz#O0.2t#((tB$W]:29393286
DEBUG: Code 0 at {)|99J8\#"anZMhP+JODd:29398967
DEBUG: Code 0 at S"[~`NJ+MyGfFJ./{o~:213132767
DEBUG: Code 0 at `/2rBcd~3KN\ORio4H*C:29403222
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:213131893
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:121263406
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:29393907
Failed to save title 1 to file C:/Work/Ripping/title01.mkv
0 titles saved, 1 failed
What can I do about it? And no, the 3 discs are okay/clean, have no scratches and play in every player!
Greetings from germany
ben
