The Martian - Canadian distribution
KaldrinX
#1 Post by KaldrinX » Wed Dec 30, 2015 2:31 am
It took a very long time to even recognize the disc, which usually takes only a few seconds. For the last 10 minutes it has been trying to open the disc. The top bar is titled 'Processing BD+ code' and the bottom one is 'Opening Blu-ray disc'. Shows 4 mins left and counting upward by a seconds per second.
The dialogue shows:
MakeMKV v1.9.8 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..084002400 to device 'SPTI:\Device\CdRom0'
Both disc and drive require bus encryption, but the bus key is not known.
Loaded 102 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Anyone have any ideas on what I can give a try?
KaldrinX
Re: The Martian - Canadian distribution
#2 Post by KaldrinX » Wed Dec 30, 2015 2:36 am
Finally failed outright with some FUT error. I tried to attach the dump file, but it is too large.
#3 Post by Woodstock » Wed Dec 30, 2015 2:47 am
Dump files should NOT be submitted to the forum, but emailed to svq@makemkv.com for evaluation.
New BD+ "protection" programs appear all the time. When you get the "No FUTs" warning, it's time to use email :) .
KaldrinX
#4 Post by KaldrinX » Wed Dec 30, 2015 6:12 am
The main problem is my mail doesn't allow sending zip or tgz files. I sent it, but took off the extension. Hopefully it is still usable by adding it again.
#5 Post by Woodstock » Wed Dec 30, 2015 2:47 pm
The alternative is using a "drop box"-type site, and sending Mike the link. I have a directory on one of my websites that I use for transferring big stuff to him, when needed. It's one of the "perks" of having your own web servers... :)
So long as your email told Mike what kind of file it was, removing the extension won't be an issue. I have a supplier that sends me ZIP files on a regular basis via email, but trying to send one back will cause your message to silently "disappear"... No bounce, but also no delivery. Change the extension to "piz", and it goes through!
KaldrinX
#6 Post by KaldrinX » Sat Jan 02, 2016 3:59 am
I'm getting the BD+ code was processed, but no FUTs were found. Errors may follow.
The rip went through the process, but the result is a horrible quality file. Smearing and artifacts constantly.
