Handbrake and backed up BD disks?
RonJohn
Post by RonJohn »
After I've backed up a BD full of TV show episodes, I want to use Handbrake to transcode them into something smaller. With DVDs, I simply point it to the directory that holds the VIDEO_TS and AUDIO_TS folders, tell it to transcode track #3 into the output file "Gilligan's Island S2x03 The Little Dictator.mkv" and it successfully does it's thing.
However, I haven't been able to find a directory that HandBrake is happy with. Does anyone know, or will have have to go to the handbrake fora?
Thanks.
Registered user.
Linux x86_64 (Xubuntu)
Re: Handbrake and backed up BD disks?
Yes, you'd have to ask on the handbrake forum.
RonJohn
Post by RonJohn »
Woodstock wrote:Yes, you'd have to ask on the handbrake forum.
It seems that HB thinks that the bdmv files are corrupt.
[12:02:50] batch: scanning /Data/ron/rip_staging/LOTR_FOTR-decrypted/BDMV/MovieObject.bdmv
[mp3 @ 0x7f0c6c017200] Header missing
[12:02:51] hb_stream_open: open /Data/ron/rip_staging/LOTR_FOTR-decrypted/BDMV/MovieObject.bdmv failed
[12:02:51] batch: scanning /Data/ron/rip_staging/LOTR_FOTR-decrypted/BDMV/index.bdmv
[12:02:51] hb_stream_open: open /Data/ron/rip_staging/LOTR_FOTR-decrypted/BDMV/index.bdmv failed
[12:02:51] libhb: scan thread found 0 valid title(s)
Time for some debugging...
Registered user.
RonJohn
Post by RonJohn »
RonJohn wrote:Time for some debugging...
It was PEBKAC.
Registered user.
What did you end up finding?
I have a disk here that MakeMKV fails to convert 3 titles on (9 others are fine), but a backup worked just fine, so I'm waiting for Mike to look things over. In the mean time, I pointed handbrake at the top folder of the backup, and it found (depending upon the HB version) 23-42 titles.
