Bad Words
natearndt
Bad Words
Post by natearndt »
I have a brand new Blu-ray and I can convert it I get the below. There is no visible damage
Saving 1 titles into directory C:/Video/Bad_Words
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9328588800'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '9328588800'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9329049600'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '9329049600'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '9329049600'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9330683904'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9344778240'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '9344778240'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9345036288'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '9345036288'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '9345040384'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9345232896'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '9345232896'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '9345236992'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '9345236992'
DEBUG: Code 3221225488 at =sG:w=|XC:eA/229'?:121262969
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '9345232896'
DEBUG: Code 101016576 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 0 at VQ?KPz#O0.2t#((tB$W]:121263291
DEBUG: Code 0 at ZU@,UmpZ>+>mm<.a)ben:121262302
DEBUG: Code 0 at VQ?KPz#O0.2t#((tB$W]:213130812
DEBUG: Code 4563102 at VQ?KPz#O0.2t#((tB$W]:29393286
DEBUG: Code 0 at {)|99J8\#"anZMhP+JODd:29398967
DEBUG: Code 0 at S"[~`NJ+MyGfFJ./{o~:213132767
DEBUG: Code 3221225492 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 100806658 at =sG:w=|XC:eA/229'?:121262969
DEBUG: Code 0 at `/2rBcd~3KN\ORio4H*C:29403222
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:213131893
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:121263406
DEBUG: Code 0 at 7@_p;GnfDru]'Td@=:29393907
Failed to save title 0 to file C:/Video/Bad_Words/Bad_Words_t00.mkv
0 titles saved, 1 failed
Re: Bad Words
If you are able to read other Bluray disks, I'd return this one for replacement. The shear number and variety of errors indicates a manufacturing issue.
But you might try cycling the power on the drive (resetting the computer if it's an internal drive) first, to see if it is an issue with the drive.
