Hello, I have been trying to retrieve home video from "blu ray" discs but I am getting multiple failures of specific tracks. I was using a panasonic camera which burnt the hidef video onto DVDs in a blu ray format. They will play in several bluray players but the same tracks consistently fail when I try to extract them.
I tried copying it with Toast to see if it found / corrected the error but the same tracks will not write.
Any suggestions?
Here is the error output:
Saving 1 titles into directory /Users/sn/Movies/Rips/
DEBUG: Code 450 at k@^Z[*-zG}w9#'!HhJl:121268075
DEBUG: Code 0 at z-sX9`|-:qFE">u/rr>zX:29398967
DEBUG: Code 0 at 'edLt9)4bGcUFv2}d:213131893
DEBUG: Code 0 at 'edLt9)4bGcUFv2}d:121263406
DEBUG: Code 0 at 'edLt9)4bGcUFv2}d:29393907
DEBUG: Code 0 at `5^wSi&<I- d%Z,l>I:213137528
DEBUG: Code 0 at `5^wSi&<I- d%Z,l>I:121269800
Failed to save title 16 to file /Users/sn/Movies/Rips/20071221152209.mkv
0 titles saved, 1 failed
Failure to write Title on unencrypted disc
Re: Failure to write Title on unencrypted disc
If it is unencrypted, you SHOULD be able to copy the files directly off the disk, and play it with a number of different players. If something like VLC recognizes the files after copying them, you don't really need MakeMKV for this job.
