I can bring up either 152 or 153 fine and can use it to build an mkv from a disc fine. But if I use any menu option other than Preferences the program waits a few seconds and then disappears. I wanted to try out some of the File options but cannot get the interface to stay up and running long enough.
Some of the failing options:
File->Open Files
Help->Purchase
Anything I can do to help debug.
Bob
MakeMKV Dies on many menu options.
- Contact:
Re: MakeMKV Dies on many menu options.
Yes, please submit the log file per http://www.makemkv.com/faq/item/8/catid/6bobchernow wrote:Anything I can do to help debug.
