MakeMKV only works with AnyDVD?
Hi guys,
I've been trying to use MakeMKV on my Macbook (both on Snow Leopard and Windows 7) but all I get are error messages when I use the "open" option.. so I just found out that it only works (for me) when I have AnyDVD loaded.. is this normal? I don't think so, because it even gives me a warning message that it should be able to decrypt on it's own without AnyDVD.. weird.. I tried to "open" a couple titles I just received from Amazon.com, here are the logs:
Debug log started at Sun Apr 4 06:42:27 2010 , written by MakeMKV v1.5.2 beta darwin(x86-release)
Using 458880KB for read cache.
001005:0000 MakeMKV v1.5.2 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/daniel/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0BA58F3D7E46C910B8ADA430DCA4FA3281D to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:213130789
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121262302
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..01D45A54468E907BC2F4CC7F417BA71DE9F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 1 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..09A7597CE17166BD186BEBEEF9A23C0D857 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 2 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..013AF8B923AA5410894D3B8DE20C22CA5 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 3 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0097C11F8B234B16F235B1D25BED432A550 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 4 at )Sw|7@%@Eju!+?U1<p:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..01D59C54D6606DDEDD5CA5C8833FA3D0F0A to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
001003:0020 DEBUG: Code 0 at t5&P$CB+K c+vdY9'U?S:121262026
001003:0020 DEBUG: Code 0 at )Sw|7@%@Eju!+?U1<p:213130835
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..08838C9E4E8B51F2E863F741012F84FB389 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..03513603BD684369578C60E2DE7DDBAE163 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..027C1004473AC1CCEC9781FF740783693AB to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0C081C077B0A79C217705094A8B82925B74 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at #M$w^=lTANnkMXW+xc`:29395402
001003:0020 DEBUG: Code 0 at #M$w^=lTANnkMXW+xc`:213133296
Here I ejected the disc and inserted another one...............
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..05A6C791FCF781A66508D412EE2CE3EA973 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..056767F2B55EF7B7BD59BB436D2F0446A66 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0A3E35E5DBD683464D67AD5BE7910466B1D to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..00E28E27CAC49B1D68B45A8FE1B23C8A5DC to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0F76159199E32C41876B131EF18A4677332 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..00C7CA1261EE9BEF4D58C3734E3DEB87075 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..081D54858E19B2AE16325B1E6A74CCAC68F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0D43B1D099A9067A69E7C710D349AB5346F to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0F1A91BDBCD43F508A6EC0D4722FD18BDCA to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0A16C4E139916862EF6DA2642E3B65C2985 to device 'IoKit:IOBDServices:4f809aae844180ab:Optiarc BD ROM BC-5500S4 1.Va'
Application exited at Sun Apr 4 06:45:54 2010
My system is a new MacBook Pro unibody, using a OptiArc BD-S55004 on a external USB enclosure.
Windows 7 64-bit was used, as well as Mac OS Snow Leopard.
Any help is appreciated Thanks!
Re: MakeMKV only works with AnyDVD?
Just tried another title.. this time on Windows, got pretty much the same thing Unfortunately these are the only three titles I have, they are all concerts, just got them from Amazon.com. LOG for this last one:
Debug log started at Sun Apr 04 07:37:59 2010 , written by MakeMKV v1.5.2 beta win(x64-release)
Using 451584KB for read cache.
001005:0000 MakeMKV v1.5.2 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Daniel/MakeMKV_log.txt
005050:0000 Evaluation version, 29 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..076FB1F330791B319E51044FE8049EFA360 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at i5t\Q!^{45,>I_pL{osB:213130789
001003:0020 DEBUG: Code 0 at @MKj0:<?bj&6^eQ+V>:121262302
001003:0020 DEBUG: Code 0 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..091A4036DA386D8645607E3755BFF950964 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 1 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0D197C6135A944C681D3EDF99F75CC200EA to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 2 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0C3CB2F0AF6D11487C7C47B2F45E1FDEB7C to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 3 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0274DA975D728C3AF3D431708EDEDF25A82 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 4 at @MKj0:<?bj&6^eQ+V>:121261727
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0AC0B6F2B3059D8DADF34FE39A803FD1AF5 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at i5t\Q!^{45,>I_pL{osB:121262026
001003:0020 DEBUG: Code 0 at @MKj0:<?bj&6^eQ+V>:213130835
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0DB97D1D5A1B82229500C642115B2B2493C to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0AAE876B6B65CCEF08FCD76F1FDFD4AF5F0 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0134654C9A707D35DA50E23ED7ED2F3C245 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0031729148C455DF521D7D5D27EA63861E8 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at ;#;~~Tb@]<;?%~L)H7D:29395402
001003:0020 DEBUG: Code 0 at ;#;~~Tb@]<;?%~L)H7D:213133296
Application exited at Sun Apr 04 07:38:21 2010
- Contact:
No, MakeMKV should be able to open any disc without any 3rd party software. Please do the following:
- upgrate to the latest 1.5.3 version
- on the first screen MakeMKV shows the "AACS version" for the disc, what is the version used on all 3 discs?
Hello Mike,
Thanks for such good support. I updated to latest 1.5.3 and still get the same error, the AACS version displayed on the main screen is "AACS v7". Is there anything else I can do?
Oh, I forgot to mention that I just found out that I'm can't even play these disks without AnyDVD... so weird, my BD-ROM is useless without AnyDVD, I tried with PowerDVD v10 Ultra, Nero 9 Reloaded, WinDVD BD, ArcSoft Theather... jesus, all of them tell me my drive is not able to play these disks (doesn't say anything region related).
Any idea?
Any idea?
Is it a original or copy?
@danielponte
Sounds like you're trying to play .ISOs created by AnyDVD which are lacking the required key(s) , unlike those created by using MakeMKV in combination with IMGBurn...
Have you read the following thread (posted at the Slysoft Forum)?:
http://forum.slysoft.com/showthread.php?t=37885
I doubt it is an ISO.
Hi guys,
No it's not an .ISO, I'm trying to play three original disks I got from Amazon.com, they are:
- Chris Botti at Boston
- Tony Bennett
- Diana Krall live in Rio
I purchased the drive on eBay from a seller in Hong Kong, could that be the issue? Some sort of drive restriction? I'm clueless, the drive seems to be working fine, since when I have AnyDVD loaded I can play all of them in all programs and I can open them fine in MakeMKV..
I'm waiting for my PS3 to arrive this week, and I'll test these damn disks to see if they are somehow defective or what..
All hits, tips, suggestions are appreciated..
- Tony Bennett
Do you any recently released blu-rays that you tried to play? I mean very recent
BTW.
Do you have the latest version of your players, software and hardware ?
maybe your drive has high certificate.
but where you bough it has nothing to do with regions for blue-ray atleast.
BTW.
Those three are the only blu-rays I have.. I bought them all at once, and yes, the softwares are all very updated. I really don't think it's a software problem, since I tried FOUR of them:
- ArcSoft Theather
- Nero 9 Reloaded
- WinDVD BD Edition
- PowerDVD 10 Ultra
There is a new firmware for my drive, but the updater doesn't let me update because I do not have a Sony laptop.. damn stupid program! I'm running out of options...
http://esupport.sony.com/US/perl/swu-do ... 2&os_id=45
- ArcSoft Theather
- Nero 9 Reloaded
- WinDVD BD Edition
- PowerDVD 10 Ultra
@danielponte
I wonder if either "mike admin" or one of the BluRay ripping knowledgable folks (such as "kendoo", in the Doom9 "Decrypting" sub-forum) at the Doom9 Forum can tell you whether this is indicative of a drive whose "certificate has been revoked" - and, if so what, if anything can be done to resurrect it?
Also - Instead of selecting "Open", are you able to select the "Backup" icon - and get it to run successfully?
(I'm not near a machine with MakeMKV on it right now)
The drives certificate is not revocked, it is the players or in this case makemkv.
you have any blue-rays that play?
do you have a blue-ray that says AACS v17 in makemkv ?
No my friend, BACKUP gives the same error. I just googled and found 5 users having the same exact issue with this Sony Optiarc BC-5500S4 drive not being able to play disks (most of them found that it works with AnyDVD loaded). I'm sending all of them a private message to see if they got it fixed or found out something about it.
User: KevO
Link: http://forum.blu-ray.com/blu-ray-pcs-la ... 5500s.html
User: gasherburm
Link: http://www.avsforum.com/avs-vb/showthre ... st17723403
User: wot4man
Link: http://forums.whirlpool.net.au/forum-re ... ?t=1372842
User: Jason01
Link: http://www.arcsoft.jp/en/forum/forum_po ... 0521#20521
I'm about to FREAK OUT Damn drive! What really pissed me off too is that AnyDVD doesn't have a MacOS version...
User: KevO
User: gasherburm
User: wot4man
User: Jason01
dirio49 wrote:The drives certificate is not revocked, it is the players or in this case makemkv.
Hi there Dirio!
No I do not have any blu-ray that plays, since I just bought it and acquired my first three titles and NONE of them play (except when I use AnyDVDHD, heh).
I'm digging a lot of sites/google and msg'in people who have the same drive to see if I can find a solution...
