Missing Chunks of Video
mhoyt
Post by mhoyt »
I purchased a copy of MakeMKV and am really pleased with it but I'm having some trouble with my DVD of Planet 51. I am streaming it to my PS3 via PS3 Media Server and there seems to be a small chunk missing at the beginning of the movie about 15 seconds into the opening scene.
I've tried ripping the DVD using MacTheRipper's more exhaustive extraction engines and it never complains but that missing chunk is there if I point PS3 Media Server to either the MakeMKV output or the ripped DVD vob structure from MacTheRipper.
Why I am posting this here? Because MakeMKV does show some errors that I think may be related to the problem. I don't think the problem is with MakeMKV but rather it appears to know something is wrong with the source. I was hoping somebody here could help me understand what its trying to tell me and if it explains what I am seeing.
Here is what I see in the console when I run MakeMKV on the DVD source:
MakeMKV v1.5.2 beta linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occured while reading 'DVD+R-DL _NEC DVD_RW ND-3550A 1.05' at offset '1048576'
Title #0 was added (28 cell(s), 1:30:43)
Title #1 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 4 in VTS 1 is a Multi-PGC title
Title #3 was skipped
Title #4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cell 2 was discarded (structure protection?)
Title #5 was added (1 cell(s), 0:12:04)
Title #6 was added (1 cell(s), 0:03:18)
Cell 5 was discarded (structure protection?)
Title #7 was added (4 cell(s), 0:02:48)
Title #8 has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 was added (1 cell(s), 0:02:54)
Title #12 was added (1 cell(s), 0:02:11)
Cell 8 was discarded (structure protection?)
Title #13 was added (7 cell(s), 0:15:50)
Cell 3 was discarded (structure protection?)
Title #14 was added (2 cell(s), 0:02:22)
Title #15 has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 was added (2 cell(s), 0:03:04)
Title #17 was added (2 cell(s), 0:02:47)
Title #18 was added (2 cell(s), 0:02:18)
Title #19 was added (2 cell(s), 0:04:34)
Title 8 in VTS 1 is a Multi-PGC title
Title #20 was skipped
Title #21 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 was added (1 cell(s), 0:02:14)
Title #23 was added (1 cell(s), 0:02:18)
Title #24 was added (1 cell(s), 0:02:33)
Title #25 was added (1 cell(s), 0:02:15)
Title #26 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 was added (1 cell(s), 0:02:19)
Title #28 was added (1 cell(s), 0:02:17)
Title #29 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Here is what I see in the console when I run MakeMKV on the ripped DVD source:
Calculated BUP offset does not match one in IFO header.
Title #4 was added (1 cell(s), 0:12:04)
Title #5 was added (1 cell(s), 0:03:18)
Title #6 was added (4 cell(s), 0:02:48)
Title #7 has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 was added (1 cell(s), 0:02:54)
Title #11 was added (1 cell(s), 0:02:11)
Title #12 was added (7 cell(s), 0:15:50)
Title #13 was added (2 cell(s), 0:02:22)
Title #14 has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 was added (2 cell(s), 0:03:04)
Title #16 was added (2 cell(s), 0:02:47)
Title #17 was added (2 cell(s), 0:02:18)
Title #18 was added (2 cell(s), 0:04:34)
Title 7 in VTS 1 is a Multi-PGC title
Title #19 was skipped
Title #20 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 was added (1 cell(s), 0:02:14)
Title #22 was added (1 cell(s), 0:02:18)
Title #23 was added (1 cell(s), 0:02:33)
Title #24 was added (1 cell(s), 0:02:15)
Title #25 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 was added (1 cell(s), 0:02:19)
Title #27 was added (1 cell(s), 0:02:17)
Title #28 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Any idea what this means and if it's related to the missing chunk?
Thanks.
setarip_old
Re: Trouble
Post by setarip_old »
Hi!
Is the disc you're using to make the MKV from a copy (DVD+R) or the original, commercial DVD?
mhoyt
Re: Trouble
Post by mhoyt »
Its the original disc. That error would suggest otherwise but its the original. Sort of strange.
mhoyt
Re: Trouble
Post by mhoyt »
I just tried Handbrake and got some interesting results. Handbrake on Linux wouldn't even present Title 1 as an available selection whereas Handbrake on my Mac seems to have worked. The resulting MKV seems like it's intact including the missing chunk at the beginning.
MacTheRipper (Mac) -> No errors, Streamed (transcoded?) VOB has missing chunk
MakeMKV (Linux) -> Provocative errors/warnings. Streamed (transcoded?) MKV has same missing chunk
Handbrake (Linux) -> No errors but doesn't see Title 1
Handbrake (Mac) -> No errors, creates MKV file, Streamed (transcoded?) MKV is intact (no missing chunks)
What would cause this?
setarip_old
Re: Missing Chunks of Video
The only thing that comes to my mind would be different methods of decryption, but I would deferto "mike admin" for further insight - especially since I primarily purchase BluRays and have limited knowledge (spelled N_I_L ;>}) of both Linux and Macs...
Post by mike admin »
Looks like a problem in MakeMKV. Please submit IFO files per instructions at http://www.makemkv.com/faq/item/8 .
