LIBMKV_TRACE: Exception: bad track type
weaverdm
Post by weaverdm » Mon Dec 28, 2015 8:20 pm
What would you do if you got this on v1.9.8 [win(x86-release)]? Brand new disc:
Saving 1 titles into directory //vmware-host/Shared Folders/HostE/tmp/TryAgain
DEBUG: Code 16295 at TDuE*|z+kR}CM"4JO/@ 7:29396345
DEBUG: Code 16312 at TDuE*|z+kR}CM"4JO/@ 7:29396345
... snip ...
DEBUG: Code 16281 at TDuE*|z+kR}CM"4JO/@ 7:29396345
DEBUG: Code 2 at pt4'8:0x$YWK7:121261704
DEBUG: Code 16319 at TDuE*|z+kR}CM"4JO/@ 7:29396345
DEBUG: Code 11113 at %#4E(L2Uoo[|@M4Q:213131134
DEBUG: Code 13651 at %#4E(L2Uoo[|@M4Q:121262946
DEBUG: Code 13651 at %#4E(L2Uoo[|@M4Q:213131456
DEBUG: Code 34560000 at %#4E(L2Uoo[|@M4Q:121263268
DEBUG: Code 11520000 at %#4E(L2Uoo[|@M4Q:121263291
DEBUG: Code 0 at ZnrqgMr.TU:1?cYEl[QT):213130559
DEBUG: Code 0 at ZnrqgMr.TU:1?cYEl[QT):213129823
DEBUG: Code 0 at %oPrpp&[AWt|vxiCbSG:29394620
DEBUG: Code 0 at %#4E(L2Uoo[|@M4Q:213130720
DEBUG: Code 0 at TDuE*|z+kR}CM"4JO/@ 7:121266902
DEBUG: Code 0 at %#4E(L2Uoo[|@M4Q:29394137
Failed to save title 1 to file //vmware-host/Shared Folders/HostE/tmp/TryAgain/Harry_Potter_and_the_Deathly_Hallows_Part_1_t01.mkv
weaverdm
Re: LIBMKV_TRACE: Exception: bad track type
Post by weaverdm » Tue Dec 29, 2015 2:06 am
I have some new info. If I turn off all the subtitle tracks, the rip completes without error. If I turn on with the video only English DTS 5.1 Audio and PGS English (forced only) subtitles, I get this:
The source file '/BDMV/STREAM/00040.m2ts' is corrupt or invalid at offset 188196864, attempting to work around
DEBUG: Code 0 at "GN~=kV8Y0|'U@Gv$08H:121262647
DEBUG: Code 0 at "GN~=kV8Y0|'U@Gv$08H:213134170
DEBUG: Code 23 at e#56/od ;01s.1bxi?C:121269340
DEBUG: Code 0 at e#56/od ;01s.1bxi?C:213135665
DEBUG: Code 0 at TDuE*|z+kR}CM"4JO/@ 7:29398967
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 1 to file //vmware-host/Shared Folders/HostE/tmp/TryAgainWithSubtitles/Harry_Potter_and_the_Deathly_Hallows_Part_1_t01.mkv
0 titles saved, 1 failed
And if I select with the video only "PGS English (forced only)" subtitles:
So it looks like the problem has something to do with the subtitles. Ideally I would like to find a way to include the subtitles with the rip.
Any ideas?
Post by Woodstock » Tue Dec 29, 2015 4:58 pm
Well, it looks to be an issue with a bad spot on the disk, in an area that only affects a couple of the tracks within the title.
But only Mike can say for sure... We'll have to wait for him.
weaverdm
Post by weaverdm » Tue Dec 29, 2015 9:23 pm
Thanks. I appreciate the theory that there's a bad spot on the disc, but the things that bother me with that theory are:
1) The discs are brand new, and appear undamaged (8 of them).
2) Both part 1 and part 2 of the 7th film have exactly the same problem: the rip succeeds without error if I turn off subtitles.
That's why I think it would be odd if there were bad spots that just happened to be in subtitles, especially when the two discs that have the problem would have been authored at the same time and in the same way. The six earlier films are fine. It makes me think there's something in the inherent structure of these subtitles that confuses makeMKV.
Post by Woodstock » Tue Dec 29, 2015 9:36 pm
I can only offer the data point that at least one version of the 8-film BD set of Harry Potter (11-disk set put out by Warner Brothers in 2011) did not have this issue. That does not mean much nowadays, when you have 40 versions of a set of disks that has the same UPC number on it... :roll:
