Spirited Away Blu Ray rip problem
clchilde
Post by clchilde »
Every time I rip the title track from the Spirited Away blu ray, the video turns out to be a storyboard or something. Any ideas why/how to access the actual video?
Re: Spirited Away Blu Ray rip problem
How are you determining that it is the main movie title? What is the total time?
clchilde
Post by clchilde »
over two hours. The normal audio plays long with this storyboard thing
The "standard" cut for Spirited Away is 2:04:30. I don't have the BD version, so I can't comment on whether or not there are other cuts.
Check to see if there are multiple "angles" listed, and try ripping other angles listed. Different angles can have different video tracks, but you really only want one per MKV file.
