Purchased Insurgent Redbox Blu-Ray
chadbh74
Re: Purchased Insurgent Redbox Blu-Ray
Post by chadbh74 » Sat Dec 05, 2015 4:42 am
enkofilon wrote:
chadbh74 wrote: If there is an interest in my MPLS compare/search tool I may create a share link for it.
absolutely there is. please, share. i assume it works only under Windows, right?
For anyone that might find my MPLS finder tool useful, a link to download it is here with the basic instructions on how to use it..
https://www.mediafire.com/folder/sp73p2 ... PLS_Finder
chadbh74
Post by chadbh74 » Sat Dec 05, 2015 4:56 am
Rich364 wrote:chadbh74,
I completed your procedure and came back with relatively the same result... \80000000000000040150000000000002\00286.mpls
How did you know it was not the 00286.mpls file that the result listed... and that it was actually the 0721.mpls file? I know you said you used a tool to compare... but what made you realize you were getting an incorrect outcome? Also, you don't mention needing a tool in your video.
And since I don't have the compare tool - is there a manual why to compare and find the true .mpls file?
It wasn't my video, it was by general1, I just created my own tool specifically for this task. I pasted in the FULL path for the \80000000000000040150000000000002\00286.mpls into my tool and it searched the bluRay BDMV/PLAYLIST folder for the real one that matched. It's that simple. I suppose you could use the built in windows FC at the command prompt to manually compare each file until you find the one that matches but it would be more time consuming than point-click-paste, browse-click using my tool or the one general1 was talking about.
tjovian
Post by tjovian » Mon Dec 28, 2015 2:42 am
MKV Won't load title 721. It keeps skipping it and using the *NOFILTER* rule didn't help.
Title 00721.mpls is equal to title 00229.mpls and was skipped
Is there any way to keep it from filtering these out? I'm using the latest version of MKV 1.9.8
preserve
Post by preserve » Sat Apr 09, 2016 4:08 am
Does anyone have a list of correct chapter times, or the mpls info for the Canadian bilingual retail release? Apparently this disc is not the same as the US releases. Between the crap bitrate due to jamming extras and the obfuscation... I almost want to give up and just return it as the POS that it is. Any help appreciated.
MrVideo
Post by MrVideo » Sat Apr 09, 2016 6:07 am
Obfuscation is not done on chapter boundaries. Doing obfuscation will not affect the bitrate as there are not extra segments because of it. At most there might be a 2 minute piece that informs you that this is a ripped copy. If it is a 50GB disc, you should not be having crappy bitrates.
preserve
Post by preserve » Sat Apr 09, 2016 2:41 pm
MrVideo wrote:Obfuscation is not done on chapter boundaries. Doing obfuscation will not affect the bitrate as there are not extra segments because of it. At most there might be a 2 minute piece that informs you that this is a ripped copy. If it is a 50GB disc, you should not be having crappy bitrates.
The reason I ask about the chapter times is because the segment and playlist numbers are different on Canadian disc than US disc. So unless someone can provide the Canadian-specific info, that was the only way I could think to get started to find the right one - to look at the chapter times, as they are different between all the playlists.
It is a physical disc that I purchased from Amazon.ca.
Unfortunately I have no use for software like PowerDVD, I don't wish to purchase it just so I can use the methods described to determine the right playlist.
And yes, the bitrate on this movie is crappy, and it was kind of a side comment, as I do realize the obfuscation itself doesn't affect the movie's bitrate - the movie is only given ~ 22 gigs total size, because this disc is crammed with bonus features all on the same disc as the movie, rather than putting them onto a second disc.
The disc I'm dealing with comes in UPC 774212005848.
MrVideo
Post by MrVideo » Sat Apr 09, 2016 8:12 pm
preserve wrote:The reason I ask about the chapter times is because the segment and playlist numbers are different on Canadian disc than US disc. So unless someone can provide the Canadian-specific info, that was the only way I could think to get started to find the right one - to look at the chapter times, as they are different between all the playlists.
If you are a M$ computer, get the free program called BDEdit. With it you can look at all of the playlists and you'll see the segment order and how long each segment is. When I was dealing with that movie, the chapter times were the same, no matter the playlist. Early on in the movie, if I jumped to the next chapter, I actully ended up missing a couple of the swapped segments.
The program will not look at an encrypted disc, so you will either have to have a decrypted copy or run a program like AnyDVD, or DVDFab Passkey, so that it will be decrypted on the fly.
gereral1
Post by gereral1 » Sun Apr 10, 2016 3:37 am
The movie insurgant was used in my videos but blanked out due to copywrite. This is the canada disk. Hope this answers your questions. As for mpls finder by rotty dog this requires you pm him the fingerprint code to unlock. We are weary on letting anyone use this tool as it will find the correct mpls with 2 clicks. Segment elimation of mpls files can be done within the first 4 segments if you do not own powerdvd! No need to use bdedit. If you want to see my detailed screenpass thread google gereral1 screenpass. This tool will work under all versions of windows. No mac versions.
MrVideo
Post by MrVideo » Sun Apr 10, 2016 6:39 am
gereral1 wrote:As for mpls finder by rotty dog this requires you pm him the fingerprint code to unlock.
Fingerprint code?
Sure, if you have your program. :mrgreen:
EDIT: Understand fingerprint code now.
preserve
Post by preserve » Tue Apr 12, 2016 10:07 pm
gereral1 wrote:The movie insurgant was used in my videos but blanked out due to copywrite. This is the canada disk.
Okay, can you post what the playlist number is then? That's what forums are for, and that's what people generally do in this forum - help other people.
general1 wrote:We are weary on letting anyone use this tool as it will find the correct mpls with 2 clicks. This tool will work under all versions of windows. No mac versions.
I don't understand the point of saying that it's for Windows, and advertising how great it is, if no one can use it.
PS, I think you mean "wary" instead of "weary" ;)
But I don't understand, what are you wary about?
Using: ASUS BW-16D1HT 3.00
fuzzfuzz
Post by fuzzfuzz » Tue Jun 07, 2016 2:34 am
I'm late to the party. Girlfriend bought this movie (UPC 774212005848) and I'm closing in on the right mpls:
00229.mpls is wrong (two scenes are flipped at the 33 mins mark, rest seems ok)
Segments: 506,502,510,504,511,507,509,501,505,503,508
00366.mpls is wrong (similar issue)
Segments: 506,504,502,510,511,507,509,501,505,503,508
Trying 00034.mpls right now
Segments: 506,502,504,510,511,507,509,501,505,503,508
preserve
Post by preserve » Wed Jun 08, 2016 5:01 am
fuzzfuzz wrote:I'm late to the party. Girlfriend bought this movie (UPC 774212005848) and I'm closing in on the right mpls:
Ah, if you find the right one on this UPC I will be grateful! Thanks for contributing your findings!
fuzzfuzz
Post by fuzzfuzz » Fri Jun 10, 2016 1:38 am
I think I've finally identified the right mpls:
00258.mpls:
506,502,504,510,511,501,505,507,509,503,508
It took about 8 separate mpls dumps + identifying which segments were flipped around. Ripping it right now to confirm.
fuzzfuzz
Post by fuzzfuzz » Fri Jun 10, 2016 2:03 am
00258.mpls:
It seems 00258.mpls is indeed the right playlist.
preserve
Post by preserve » Tue Jun 14, 2016 9:38 pm
fuzzfuzz wrote:00258.mpls:
Hmmmmmm... Even though we share the same UPC, my disc doesn't match this.
So I tried to find a playlist with the same segments, and I'm trying this playlist now:
00763.mpls:
16 chapters, 1:59:00
