Errors loading from blu-ray
sauron11
Post by sauron11 »
On trying to rip a disc (Terminator Genisys), I get a constant stream of debug messages logged, and the disk just pins endlessly when put in the blu-ray drive. I've tested this disc separately with two different USB connected blu-ray drives. This is the debug log messages, from MakeMKV 1.9.7:-
DEBUG: Code 1073741843 at O5MV!tJDDW2<\v">:213134676
MakeMKV just sits at the "Loading: please wait..." screen. Eventually the drive stops, but MakeMKV still thinks it's loading.
Re: Errors loading from blu-ray
Debug codes are something Mike would have to interpret.
Do you have debug logging turned on? Sometimes, much more information will be included in the log than displays on the screen. The FAQ in my signature explains how to turn it on and where to find the log.
sauron11
Post by sauron11 »
Woodstock wrote:Do you have debug logging turned on?
Yes, the above was with debug logging. However, since posting I've worked out that not all my USB ports are equal as far as my blu-ray drive is concerned. Plugging directly into a different port on the back of the machine got the disc to read happily.
